#1 |
Member # 26605
ignition coil gets hot and wont run?
i have and 88 zuk stock 1.3 and it will run for about an hour and then die so we check spark no spark at coil and the coil is boilin hot so we put on another coil and it did it again
i have 14.2 volts at the alternater and the battery also at the coil is there a resistor or something before the coil to regulate it to exactly 12v i cant figure it out so if someone could give me some clue i searched and drew a blank in the forums thanks |
#2 |
boulder buddha
Member # 3886
i dont know about zuks,
my toyota has a magnetic pickup in the distributer, has the same symtoms, would run for a while until it got hot and then die and no spark. just an idea. if they are a mag pickup style, check resistance across when cold, then check again when it hot and dies.
hold this... |
| Sponsored Links |
#3 |
This sounds like a distributor or grounding problem..run the factory service manual tests on your distributor.
I break zuks and my wife fixes them! |
#4 |
Member # 42415
Maybe the ballast resistor is shot and the coil is getting too much voltage ...
07 FJ - TRD SE - FOR SALE!!! / 01 XJ - 6.5"LA, 33" TSL's / 68 CJ-5 - In pieces ... |
#5 | |
Member # 26605
#6 | |
Member # 26605
if so where is it |
#7 | |
Member # 42415
First I'd suggest downloading the FSM form my site here: http://www.virtualsoapbox.com/vehicles.htm RUn all the tests on the coil and ignitor circuit to narrow the problem down. Good luck!
| Thread Tools | |
| Display Modes | |
