#1 |
Member # 21143
Satchel link vs. triangulated 4 link
As the title says. I was reading a suspension book of mine and it said the ideal 4 link for the rear is a satchel link. Looks a little easier to build that a triangulated 4 link. What are the advantages of one of the other?
#2 |
Member # 7988
Bump to get an answer for myself too. I couldn't find anything that answered the question on Google, but I did notice that everything was aimed at roadracing. It might have something to do with articulation or funky geometry at the limits of travel.
But on a side note, if you give it some thought before you start, building a 4 link is about as easy as they come for link style suspesions, as far as building is concerned. I mean you have 8 simple mounts and 4 link that you can buy premade or cut and weld yourself, what is hard about that. Designing it right is where it gets tough. What book are you reading?
Tim '06 Honda CRF230F Hare-Scramble bike '85 Nissan PU '91 Cherokee '93 Mitsu Expo LRV (Which is still running some how) Elkton, VA Last edited by Tim Smith; 05-26-2005 at 08:37 AM. |
| Sponsored Links |
#3 | |
Member # 16789
The Parts Pimp. I'm looking for highpinion TTB Dana44 gears in a 3.08. Let me know if you've got some. Collision Parts warehouse San Diego for replacement fenders and radiators: http://www.1800bodyparts.com/ |
#4 | |
chicken fucker
Member # 2931
is a 'satchel' link like a watts setup?
http://www.diamondaxle.com http://www.F-O-A.com http://www.12voltguy.com http://www.addictedoffroad.com wanted: (2) 12''x3''x250# coilover springs 2002 diamond axled coilover/linked tacoma v6 4door rock taxi with dual cases and beadlocked 37s |
#5 |
Low Range Drifter
Member # 7903
If this is a real satchell setup, then it looks like a 4-link with the uppers parallel to the frame and the lowers triangualted with the convergance at the frame end.
You should be able to do a comparison to a traditional 4-link (triangulation top), the XX or James link (uppers & lowers triangulated) and the Satchel (lowers triangulated) using the 4-link calculator.
2001 TJ Now with 4.7 V8 power : 1975 Wagoneer Last edited by JohnnyJ; 05-26-2005 at 12:09 PM. Reason: better link |
#6 |
Member # 21143
That's it johnny. Where can I find the 4-link calculator?
#7 |
Low Range Drifter
Member # 7903
2001 TJ Now with 4.7 V8 power : 1975 Wagoneer |
#8 |
Member # 21143
Any FAQ or guide for this? I still trying to figure out the orientation of the x,y, and z-axis. Trying to figure out how to orient the grid with the vehicle. Never really designed a suspension so I'm trying to figure out where to orient the ends etc. Any suggestions, sample suspensions etc.? Also what is the graph? Don't really get that.
#9 |
Member # 10
I built a similar arrangement before, but with longer links than that guy used on his Jag, naturally. It worked great, the only real downside is that it has as fairly low roll center--which can be moved up easily, just by triangulating the upper links to the top of the diff, and keeping the lowers triangulated. Sometimes the more-parallel uppers might clear stuff above more easily though, so it's a decent option to keep in mind.
Carl Whitmore |
#10 |
Red Dragons!
i know nothing about inverted 4 links (satchell)
BITD #4401 ![]() 2010 Partners: Bilstein Shock Absorbers, Trail-Gear, Shaffer's Offroad, S&N Fab, Superior Axle & Gear, Raceline Wheels, Big Country Customs, PSC Motorsports, Vision X Lighting.I Wanna Go Fast! |
#11 |
Member # 21143
If triangulating the uppers or lowers will locate the axle, then why does the 4runner have a panhard bar? I looked at my links and the uppers definately look triangulated.
#12 | |
Grocery Getter
Member # 59
What DSI really meant to say is read this thread: http://www.pirate4x4.com/forum/showt...ight=dsi%2Famj Around here it got nicknamed the "DSI/AMJ" link setup. If you do a search on "DSI/AMJ" you will find several other threads discussing it. |
#13 | |
Red Dragons!
:whistle:
#14 | |
Grocery Getter
Member # 59
The panhard makes for DIRECT lateral control, so that's why the factory uses it. The panhard will fight the triangulated uppers because the panhard wants the axle to swing in an arc, but the tri-uppers want it to move straight up and down. This causes bind. The rubber bushings throughout allow for this bind though, to a certain extent. Plenty for the factory-designed amount of travel anyway. |
| Thread Tools | |
| Display Modes | |
