#1 |
Member # 33685
Custom Snorkel. 2nd Gen 4Runner. PICS
What you need, One Safari Snorkel Head, Two 45 Degree angle PVC Adapters, 1 90 Degree PVC Adapter, One 6ft length of pipe, Grinder, Sawsall, Welder, Steel, Caulking
Here is what I have put together so Far for my Custom Snorkel Installation More pics to follow as they come First off you need to buy the Safari Snorkel Head, You can buy JUST the head for $80 Canadian. (Pricey I Know But its what makes the snorkel look good. and not a TOTAL Ghetto hack job) After you take off your Fender, you will notice there is already a hole in the Frame leading to the air box, all you need to do is enlarge it a bit to fit both a 2" PVC Pipe and the Wire loom. Cut a hole in the air box and fit the Pipe into the box Big Pic: http://www.mudrunner.ca/snorkel/snorkel1.jpg Heres a Pic Of the Piece that goes into the air box Big Pic: http://www.mudrunner.ca/snorkel/snorkel_b.jpg Attached to the 90* Elbow Big Pic: http://www.mudrunner.ca/snorkel/snorkel_a.jpg In to Air Box Next mock the pipe up where you would like it, You will need to cut the outter part of the fender and weld a plate in. for strength. Big Pic: http://www.mudrunner.ca/snorkel/snorkel2.jpg Heres the Cut.. sorry bad pic Big Pic: http://www.mudrunner.ca/snorkel/snorkel3.jpg Heres the mock up of how the pipe will Run. THIS IS THE MOCK UP. you need to bend the pipe in order to get the fender lining back on. Big Pic: http://www.mudrunner.ca/snorkel/snorkel5.jpg Here's the PVC Pipe all bent and the piece that goes into the airbox attached Big Pic: http://www.mudrunner.ca/snorkel/snorkel_e.jpg Here is How I bent the PVC Pipe. I heated up the plastic with a torch, (Just keep turning the pipe, and bend it over an old rim. Big Pic: http://www.mudrunner.ca/snorkel/snorkel_d.jpg Next Cut a Hole in the Fender. THIS PART IS SCARY, ![]() Big Pic: http://www.mudrunner.ca/snorkel/snorkel6.jpg
MudRunner Last edited by 4Hummer; 08-30-2005 at 08:12 AM. |
#2 |
Member # 33685
Okay and here's the finished product.
I still need to bend the top a Tiny bit more. But Im fairly happy with it. I Used a peice of interiour trim to cover the hole in the fender around the pipe Big Pic: http://www.mudrunner.ca/snorkel/snorkel_f.jpg Big Pic:http://www.mudrunner.ca/snorkel/snorkel_g.jpg Big Pic: http://www.mudrunner.ca/snorkel/snorkel_h.jpg Ill post some better pics when I get a chance
MudRunner Last edited by 4Hummer; 08-30-2005 at 08:14 AM. |
| Sponsored Links |
#3 |
Accurate to 1/10th
Member # 30965
Looks like you did a great job. The install looks pretty clean!
#4 |
Member # 2102
whats with the rack on the hood, do you actually strap shit on there?
#5 | |
Member # 33685
Hood protector (We see lots of forest driving in this neck of the woods) Lots of branches and tree's = lots of scratches and dents. The Hood guard will eventually tie into the rock rails, and sliders, when I get them done. I just finished the rear bumper. (New baby = not allot of time to play in the garage) If they do it on a Hummer why not a Runner ?
MudRunner |
#6 | |
Accurate to 1/10th
Member # 30965
When I first saw it on your 4Hummer I thought it was a hunting rack, kinda like what they put on the front of ATVs. *EDIT* If you have larger pictures of the snorkel install, please post them! It's really tough to make out what's happening in those little pictures. Last edited by TheBandit; 08-29-2005 at 02:50 PM. |
#7 | |
evil twit
Member # 52443
Sound interesting for using the hood as a step to get to the roof... edit: higher up towards the windshield of course...
Matte Black TOYOTA 86 4Runner // Technics ST-9600 - RS-1506 - Turntable BL3 Linear - to SU-8600 as preamp into 2x SE-9060 driving SB-6000s. From 1977. Quote:
#8 | |
project 90 4runner under construction: 3.0 delete 22re w56 2.28^2 SAS 4.88 locked 35 TSL |
#9 | |
Accurate to 1/10th
Member # 30965
#10 |
Pirate4x4 Addict!
Member # 26382
few questions:
doesn't the 2" pipe and all the 90*'s restrict air flow into the air box quite a bit? is it realy needed considering the distributer is going to be under water about 2' before the inlet to the snorkle? isn't your computer also going to be under water long before that?
87 4runner d44f/9"r full width, 5.38/5.43/ARBs, superior shafts, ctm's, twin stick 4-1 dana 300 behind toy t-case, allpro springs f/r, 39.5 iroks on aluminum trail ready bead locks ΜΟΛΩΝ ΛΑΒΕ I'm just a peckerwood who lives in the hills with too many guns. |
#11 |
Pirate4x4 Addict!
Member # 30
Location: Roseville, CA,To many Yuppies, Not enough Hippies
Nice clean install, but I personally do not like the "sewer pipe" look and I feel that it is just asking to be knocked off by low hanging branches. That is why I built mine like this. If I am up to water this deep, I have more things to worry about then the engine!!!!!!!!
Disreguard the K&N drop-in, I got rid of that POS a couple of years ago.
David & Theresa, Roseville, CA, Excellent Parts Source http://www.davezoffroadperformance.com/ http://www.marlincrawler.com/ http://www.12voltguy.com/web/ Last edited by OOP'S; 08-29-2005 at 06:47 PM. |
#12 |
Member # 29850
Sewer pipe rawks!
2" is too small though, need at least 3" or the engine will starve for air, that's the mistake I made.As for the distributor getting wet, ...uh silicone. Can't find any deeper pics, but I regulary drive through water over 5 feet deep. It's just part of wheelin in Ontario. Here's one where I'm already 4 feet deep & just starting the crossing. Last edited by Canadian_Zuk; 08-29-2005 at 08:15 PM. |
#13 |
Member # 29850
Goin Back!
Btw, nice job Michael! |
#14 |
Pirate4x4 Addict!
Member # 26382
now, how about the same depth but with a current strong enough to push you down stream. it's just part of wheeling in northern california
#15 | |
Member # 19325
#16 |
Accurate to 1/10th
Member # 30965
When you guys are doing these 5ft crossings, does water flood into the cab pretty bad? To the level of the outside water?
Just curious since I suppose the door weatherstrip might offer some sealing and it might take a while for water to flood in through all the firewall passthroughs. I just have no idea
#17 |
Member # 37026
looks to me like sniper could care less since it appears to me he has no doors on.
#18 | |
Pirate4x4 Addict!
Member # 26382
we got wet. the water was flowing over the seats. at least it was a warm weekend
#19 | ||
Cardboard Killer
Member # 5776
It took about 5 minutes to roll down the back window, crawl through the back of the 4 runner and fling a towstrap back to a buddy on shore, and get pulled back. That whole time my passenger was holding it at ~2500 RPM. Under that much water a lot of engine power is required just to push the exhaust fumes all the way out the pipe. In 5 minutes, there was water up to the bottom of the front seats - about 4 inches or so. But that was it. Opening the door & letting the lake out had my buddies on shore ROFL. I was very surprised how slow it leaked in. But that was with a 4" IFS lift & 33s. Now I've got 8 2.5" holes in the floorboards for drainage when you're hosing mud out of the interior. I think it'd leak in a little faster.
#20 | |
Member # 33685
I've posted the larger images in the first 2 post's as links Truck doesn't seem to be starving for air. Run's allot better than with the K&N Cone filter. The Stock Intake silencer pipe is 2" ABS plastic so ?? I'm trying to come up with a way to use the front intake (behind the headlight) for everyday use, and than shut it closed somehow when Im gonna hit some water, and breath threw the snorkle. (Right now the stock intake has been siliconed shut. ANY IDEAS ? The Hood guard is Phase 1 of that build. It will tie into the Rock rails and sliders when its complete, Kinda a mini Exo. Got the Idea for the hood guard here: http://www.roadarmor.com/ra3/index.html and the Original H1 had one too. Like I said that Hood Guard is PHASE ONE. it will be rebuilt when I make a new front bumper. (First is sliders, and a rear rock rail... I JUST finished the rear bumper)
MudRunner Last edited by 4Hummer; 08-30-2005 at 08:22 AM. |
#21 | |
Stag Beer for life
my .02 |
#22 | |
word. |
#23 | |
Member # 29850
#24 |
Banned
Member # 3933
Nice work on the snorkel other than you should of use bigger material.....
![]() As for the hood rack / guard thingy..... Thats ! The forest around her would eat that thing alive! Heck I've gotten dents from small branches getting in between my sliders / wheel hoops and my sheetmetal on my 4runner. and on my previous vehicle I would get stuff caught inbetwwen my roof rack and the top of the cab. That thing you got on there would just cause branches to get pinned in between the hood and that small tubing. Then all hell is going to break loose when you keep driving as the branch denting the hood and bending those little tubes. I've even seen one roof rack ripped right off a set of yakima rain gutter mounts totally trashing the rain cuts and the top of the cab.With nothing but smooth sheetmetal, braches and shrubery can slide right over it without causing damage other than some some brush pin stripping. But I guess everyone got to learn on there own..... |
#25 | |
Arizona Trail Riders
Member # 1418
You need a Thneed 84 Toyota CJ2a Get Propane |
| Thread Tools | |
| Display Modes | |
