Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 09-22-2005, 12:22 AM   #1
JR
JR's Avatar
Member # 8524
Flipped 9" pinion oiling pics
I thought I'd start a new thread so that it could be easy to search.
If you run plan on building hybrid Ford 9"/'mog axles, then you are going to need to address pinion bearing oiling issues because the pinion no longer will be bathing in oil.
I recently changed gear ratios in my 'mog 9s. I was able to inspect the pinion bearings for any signs of excessive ware or heat. Except for some marks left from when water got into the differentials (tank trap), there wasn't any.
I'm sure people have done it other ways. This is not a debate, it's just how I did it in '01.
Note: I am not a pro welder, not even a good welder. I used a mig because that's what I have and, anyway...I didn't think anybody would ever see it. It really should be done with a tig.
The first pic is from the front end. It runs off the coast side of the ring gear. The ring gear is rotating downward where it meets the pinion. You will want to catch the oil as ring and pinion mesh and funnel it down to the pinion bearings through a drilled hole. I don't remember the size of the hole, but it's as big as you can get away with. The hand made sheet metal scoops are welded to the pinion support where the R/P converge. The leading edge can be .020~.050 away from the pinion.
JR is offline   Reply With Quote
Old 09-22-2005, 12:26 AM   #2
JR
JR's Avatar
Member # 8524
Different view. The scoop needs to fit inside the differential housing.
Old 09-22-2005, 12:32 AM   #3
JR
JR's Avatar
Member # 8524
In this pic, you can see where the old pinion oiling galley was welded up ( between the two races) This needs to be done to keep the oil from exiting before it has done it's work oiling the bearings.
Old 09-22-2005, 12:37 AM   #4
JR
JR's Avatar
Member # 8524
Here you can see where the new hole is drilled from the scoop to the pinion bearings. It ends up between the two pinion bearing races.
Old 09-22-2005, 12:39 AM   #5
JR
JR's Avatar
Member # 8524
Drain holes will also need to be added. You can see the two of them towards the bottom ( in the pink)
Old 09-22-2005, 12:41 AM   #6
JR
JR's Avatar
Member # 8524
This pic shows the old drain hole (right) and the new ones (left)
Old 09-22-2005, 12:51 AM   #7
JR
JR's Avatar
Member # 8524
Now, here is how I did the rear end. It is the same except for how the oil is caught. The ring gear runs off the drive side and is rotating upward where it meets the pinion so a "tang" is welded in catch the oil and funnel it into the trough. A drilled hole (not shone) leads to the center between the pinion bearings.
Old 09-22-2005, 12:55 AM   #8
JR
JR's Avatar
Member # 8524
Here's another view of the scoop. The tunnel (drilled hole) from the scoop can be seen just below the bearing race . (you can also see the marks left on the race from water in the oil)
Old 09-22-2005, 12:59 AM   #9
JR
JR's Avatar
Member # 8524
Top view. Notice the drain holes ( at the bottom)
Old 09-22-2005, 01:05 AM   #10
JR
JR's Avatar
Member # 8524
Another pic of the relation between the scoop and pinion. This is right where the ring gear meshes and makes a wake of oil.
That's it.
Old 09-22-2005, 01:29 AM   #11
BrettM
Member # 11998
Send a message via AIM to BrettM
Originally Posted by bulfrog3
Sweet write up and pics. Do you think this could be done in normal 9" axles and be reliable driving the rig to trails? I would think someone could come up with the parts like you did and have a hi9 at 1/10th of the cost of a truehi9 unit.
1/10th the cost?!
he's running these upside down to deal with the rotation reversing portals, try building 9" portals for less than a Hi9. and the Hi9 isn't a crazy amount more than a Strange 3rd, gears, locker, and gear setup.
awshifting.com
awshifting@gmail.com
BrettM is offline   Reply With Quote
Old 09-22-2005, 03:33 AM   #12
mike
Member # 144
Nice solution. 4 years of use without damage proves that
mike is offline   Reply With Quote
Old 09-22-2005, 07:47 AM   #13
CartsXJ
Crawlin Rookie
Member # 24709
Send a message via AIM to CartsXJ Send a message via Yahoo to CartsXJ
That's it.
You either have child like hands or that pinion is huge !!! What ratio is that 2.00:1?
"Being a man take years of fightin, screwin, drinkin, and whorin. Then more drinkin and then more whorin...if there's time" -Trippin the Rift
CartsXJ is online now   Reply With Quote
Old 09-22-2005, 08:26 AM   #14
TNToy
Cardboard Killer
TNToy's Avatar
Member # 5776
Ever looked at a 9" R&P uninstalled? They ARE huge.
Heck, even an 8.8" R&P dwarfs a 44. The pinions in these axles are big.
TNToy is offline   Reply With Quote
Old 09-22-2005, 09:27 AM   #15
Gozuki
Gozuki's Avatar
Member # 3088
The reduction happens out at the portal box, and is multipled, so it probably is reeaally high ratio...
Buy my new Victor regulators!
Gozuki is offline   Reply With Quote
Old 09-22-2005, 09:45 AM   #16
truehi9
Member # 37651
EXCELLENT write up and pics. Sometimes simple cheap solutions work the best. No oil pumps or moving parts to wear out. Ingenuity at its finest. And it works at ALL speeds. So simple it has no choice but to work. Here is another example of such a system. http://www.truehi9.com/oilingsystem2.html
www.truehi9.com
DIFFERENTIAL BUILDER
truehi9 is offline   Reply With Quote
Old 09-22-2005, 10:48 AM   #17
Aggro
Member # 2587
Location: 38*45.859N 120*34.534W (N. Ca) Future location of beachfront property.
Looks a little butch for your rig, but it will be functional.
Did you ever have oiling issues with just a modified (drilled) pinion support?
Highly UnStAbLe with nothing to lose.
Aggro is offline   Reply With Quote
Old 09-22-2005, 11:03 AM   #18
TheNerple
Member # 2816
I dont' know about childlike, as far as the hands go, but damn they sure are hairy!
The ratio was 2.something but the new ones are 3.0 or close to it. I wonder how that setup would work with 6-7:1 R&P ratio? I'm putting electric oilers on mine so I can just be done with it. I assume that scraper works as well as it does as the pinion and ring gear rotate close to the same. On Herman's 7.33's that pinion is moving a whole lot faster than the ring gear so I still worry about whether the ring gear would sling enough oil for the pinion to catch and oil the bearing. Anyway good tech for your mog freaks John.
We tried the aftermarket custom upside down pinion support from currie and it didn't last 1 mile of slow going. I suppose you could waaaay over fill the diffs and have it work fine for competition style rockcrawling but I have my doubts for prerunning through the desert.
Big Girls Don't Climb...
TheNerple is offline   Reply With Quote
Old 09-22-2005, 12:33 PM   #19
truehi9
Member # 37651
Quote: "On Herman's 7.33's that pinion is moving a whole lot faster than the ring gear so I still worry about whether the ring gear would sling enough oil for the pinion to catch and oil the bearing."
If the ring gear scraper is positioned right it will pull oil off the ring gear at any rpm. It's not depending on oil being slung off.
Quote: "We tried the aftermarket custom upside down pinion support from currie and it didn't last 1 mile of slow going. I suppose you could waaaay over fill the diffs and have it work fine for competition style rockcrawling but I have my doubts for prerunning through the desert."
1. Do you have a part number on that pinion support from Currie? I can't seem to find it in Currie's catalog or website.
2. We have a customer with an 800 h.p. (customer supplied info) prerunner style desert racer that has been running this oiling system on his for 1 year and has had no issues.
www.truehi9.com
Old 09-22-2005, 01:00 PM   #20
JR
JR's Avatar
Member # 8524
I went from 2.50 to a 3.00 gear set. They're both about the same size, ring gear is a little bigger on the 3.00.
I didn't know about the custom pinion support, not even sure it was available 4 years ago.
I think the way I did it would work on any gear ratio. But, since it works with gravity, steep pinion angles are not going to work.
The other part of the solution is to use Red Line Synthetic Heavy Shockproof
gear oil 75W250. It's used in the diffs and portal boxes.
I have some pics that were originally taken on film (remember that stuff?). Can't figure out how to use the scanner, so Marilyn will need to help.
The pics show bench testing at slow speeds.
I think at high speeds it just a blizzard inside the diff housing and probably doesn’t matter much.
Old 09-22-2005, 01:39 PM   #21
XJGPN2
Member # 11808
Send a message via AIM to XJGPN2
Is there any reason that your custom pinion support and extended shroud system couldn't be used in a standard Ford 9" Third Member to permit it to be used upside down for rear engined buggies, or portals where they have to run backwards? I know you are pretty much saying that you did the same thing as what JR has done... but I don't know enough about your True Hi9 to know if all of the parts would physically fit using a standard 9" Flipped upside down.
XJGPN2 is offline   Reply With Quote
Old 09-22-2005, 02:08 PM   #22
truehi9
Member # 37651
It is pretty much the same system but we have to custom fit each scraper to each gear ratio. The pinion support we use is actually from Currie part #94031 and we just add the scraper. Ours may not work with the 3.00 range gear ratios since the pinion gets so large. I hope this somewhat answers your question.
www.truehi9.com
Old 09-22-2005, 03:36 PM   #23
KYcrawler
Member # 9829
Send a message via AIM to KYcrawler
why are the drain holes between the races needed wouldnt the oil just dissipate between spaces in the inner bearing and in turn keep the bearings cooler beacuse they are then running in oil
85 cj 7 for sale
304 t 18 dana 20 dana 30 front arb locker and 456 gears amc 20 rear 456's and arb locker 6 inch lift and new 33's on eagle 589's and 36 tsl's $4200
KYcrawler is offline   Reply With Quote
Old 09-22-2005, 04:30 PM   #24
truehi9
Member # 37651
In our setup and I believe also JR's (posts #5 & #6) the drain holes are out the front not between the races.
www.truehi9.com
Old 09-22-2005, 07:03 PM   #25
pmurf1
Member # 2463
Alright, I'll be the first one to look stupid and ask. Why could you overfill them enough completely saturate the pinion bearings in oil? Only reason I can think of is you would have to put a fill plug on top somewhere and allow for extra expansion? Or is that bearing tilted so far back by the time you rotate your pinion up that it makes this pointless?
pmurf1 is offline   Reply With Quote
Forum Jump
