Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 09-28-2005, 03:14 PM   #1
slidewaysxj
Member # 33607
DIY Vehicle Painting
I have a 90 XJ that i just lifted and tired. Its a Wagoneer with the wood sides and all the bells/gadgets. Currently it has a gunmetal silver factory color with a good deal of lamination. I want to sand it down and shoot it gloss black (keeping the wood).
I'd just like to hear some advice to see what everyone thought i should do. I guess i have to take it down pretty far to get rid of the lamination. I'll be buying a sander and a gun to do this but i dont really know anything besides it has to be around 800 grit before i paint it.
I want it to be good looking so no spray bombs or rattle cans. I may Herculine the flares though
Thanks!
slidewaysxj is offline   Reply With Quote
Old 09-28-2005, 03:52 PM   #2
Dalec
Member # 26262
I think you should get your mind right, n00b.
Dalec is offline   Reply With Quote
Old 09-28-2005, 04:03 PM   #3
geberhard
Greasy Maderator
geberhard's Avatar
Member # 5861
check the thread on my sig
geberhard is offline   Reply With Quote
Old 09-28-2005, 04:26 PM   #4
slidewaysxj
Member # 33607
That was pretty helpful. I'm just wondering about the primer/sealer. If i need to sand it down to 800 or 1000 and then seal it or just shoot the primer.
PS: Screw Yew Dalec..
Old 09-28-2005, 08:37 PM   #5
RampageFSJ
Big FSJ
RampageFSJ's Avatar
Member # 50295
You`re awsome! I was also needing that info soon.
Dirt flies when you're having fun!
73 Jeep J 4000 (AKA, Rampage)
69 F-100 (AKA, Free Runner)
RampageFSJ is offline   Reply With Quote
Old 09-29-2005, 06:04 AM   #6
MrWillys
Member # 9991
Follow all directions to the "T". Shoot the primer first and sand that dry with 180 and a 17" board. If you've really got a rough surface such as 36 grit, then repeat this step. Then prime again and sand with 4, or 500 grit. Seal it with a sealer close in color to your topcoat and then apply topcoat. I would really try and discourage you from shooting black or any dark color or metalics for ones first paint job. Choose a light solid color as it will hide some of the mistakes a first timer will make.
[url]http://www.scotthansen.net[/url]
MrWillys is offline   Reply With Quote
Old 09-29-2005, 09:05 AM   #7
GiS
Rock Posse Racing
GiS's Avatar
Member # 31285
1. Rough up the old paint with the BBQ brush from the backyard.
2. Dont mask a thing...
3. Spray bomb till you can longer use your index fingers.
-Joe
Rock Posse Racing #686
Driver: Joey Weber
Special thanks to our sponsors!
Evolution Machining and Fabrication
www.evolutionmachine.com
GiS is offline   Reply With Quote
Old 09-29-2005, 01:37 PM   #8
braxton357
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
-Joe
This is my preferred method too, but I got lazy and bought a scotchbrite thing for a drill and a trigger/handle for the spraypaint cans. Works well.
In vino veritas
70 turbocharged 351w fastback mustang
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
98 locked beater xj on N20.
braxton357 is offline   Reply With Quote
Old 09-29-2005, 02:13 PM   #9
SHINTON
Member # 9504
Send a message via AIM to SHINTON Send a message via Yahoo to SHINTON
This might be of interest to you, I wrote it a year or so ago, my $80 paint job.
http://www.off-road.com/jeep/tech/cheap_paint/
Just as an update, it has held up really well with the trail abuse over the last year or so. I need to touch up a couple small places on my bumpers (from beating in/out ujoints, heh) but otherwise it all looks decent.
If I really cared I could probably wax it now and make it really stand out. We also "wish" we would have located Rustoleum clear in quart size...but then again it is a TRAIL rig paint job so...
Sam
SHINTON is offline   Reply With Quote
Old 09-29-2005, 03:14 PM   #10
RampageFSJ
Big FSJ
RampageFSJ's Avatar
Member # 50295
I have painted a couple of trailers before so I`m not exactly a beginner. The truck that I`m working on has been primered by the last owner.
http://img.photobucket.com/albums/v6...J/100_0652.jpg
Does it look any good to you guys? It is a little ruff in some places but I can sand that down. And there is some surface rust on the top of the bedsides that I can take care of.
Old 09-29-2005, 07:58 PM   #11
Eskimo
Eskimo's Avatar
Member # 10429
It's a 1990 XJ. WHy spent all that time to try and get glossy paint? Rustoleum the bitch so that touch-ups are just a spray-bomb away...
We used Rustoleum on my whole rig and it looks great from 5 feet..
Rich Q.
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/42's
Eskimo is offline   Reply With Quote
Old 09-29-2005, 08:02 PM   #12
77'/85'scottspecial
Member # 25085
Send a message via MSN to 77'/85'scottspecial
www.autobody101.com
'85 K20. 383/700R4/205
77'/85'scottspecial is offline   Reply With Quote
Old 09-29-2005, 09:13 PM   #13
Halogrinder
i win bish
Halogrinder's Avatar
Member # 16980
no. it looks like the primer you have on the vehicle is waterbased...
i.e. the rust coming thru it. the only way to "Seal" the metal is with a non water based primer. water based primer "breathes", meaning the rattle can primer you get at VatoZone is not what you want on a truck that is going to get a paint job better than maaco or earl shieb. if your going to rattle can it, scuff and shoot it. if your actually attempting a decent paint job, the ONLY way your going to get decent results is to sand it down COMPLETLY to the metal, and shoot it with a acid etching primer or solvent based primer. it would be reccommended to go buy a gallon of primer, like dupont or something quality. prime, 220 sand, prime again over body work, 400 wet sand, prime entire vehicle again, 400 sand everything and then shoot it with a tough paint like Imron paint. this is the same shit used by the UPS trucks, aircrafts and bigrigs. its a single stage, so dont worry about clearcoating it, and it is tough as HELL..... you can eat bush with it all day and it comes out great. i would prolly go with white as a first paint job. the darker the paint the harder it will be. take your time on the body work and prep. it will make or break your paint job.....
hell look at what i did to my old farm truck..lol
took 3 months after work and weekends for the body work after the tree and i had a fight.
took 3 days to get the door handles (or lack of) to look right....
3 hours to get rid of the antenna
the flames took over 10 hours to tape off and mask.
about 4 hours to shoot it.
take your time!
BIGUGLYFABRICATIONS.COM
YouTube - Ron Paul's What If ? Remastered
please watch. it will make goosebumps.
Halogrinder is offline   Reply With Quote
Old 09-29-2005, 09:27 PM   #14
RampageFSJ
Big FSJ
RampageFSJ's Avatar
Member # 50295
I don`t need it to be real pretty. It ain`t a show truck. I was wanting to do a rattle can job and keep it simple. Do I need to sand down some on the primer, and re-primer it, then shoot my color on it and then clear coat?
Old 09-29-2005, 09:30 PM   #15
Halogrinder
i win bish
Member # 16980
if your gonna rattle can it, sand off the rust with 400 or 600 and shoot it. dont try to rattle clear it. it will come out even more shittier. im gonna be shooting my fj40 w/ rattle can....buy the best rattle can you can get too...lol
i got a few pics of shit painted in my thread on my cruisah
Old 09-29-2005, 09:35 PM   #16
RampageFSJ
Big FSJ
RampageFSJ's Avatar
Member # 50295
Allright, thanks for the info.
Forum Jump
