Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Land Rover
Old 10-07-2005, 07:52 AM   #1
Greg Davis
Greg Davis's Avatar
Member # 11066
LT230 1.003 High Range Gears
My DII has a high range ratio of 1.211, and I'd like to swap in the 1.003 set to lower my highway revs. Anyone have a set or know a good source for the East Coast?
Oh, will this be a stright drop in, or will other mods be required?
"Wrinkles Only Go Where Smiles Have Been"
Greg Davis is offline   Reply With Quote
Old 10-08-2005, 07:07 PM   #2
Greg Davis
Greg Davis's Avatar
Member # 11066
Unhappy
C'mon now. With all the collective Pirate wisdon here, no one knows about these gears?
I was told that they were in the units that were mounted behind the 727 Trannies, but I haven't been able to confirm this.
Old 10-08-2005, 07:55 PM   #3
red90rover
red90rover's Avatar
Member # 20109
As I understand it, the answer is no. The 1:1 high range was only used on early RRs which used an early version of the box using a different input gear, But I could be wrong.
There is always an overdrive.
1991 D90 ex-MOD
red90rover is offline   Reply With Quote
Old 10-08-2005, 09:59 PM   #4
Leafsprung
Member # 12663
Send a message via AIM to Leafsprung
Doable
I have a q case with 1:1 gears in it.
I am what I am - Popeye
Leafsprung is offline   Reply With Quote
Old 10-09-2005, 12:39 PM   #5
ashtrans
Member # 30584
Yes you can fit the 1.003 ratio gears in place of the 1.211, you will need 3 gears and a selector outer hub, if you get suffix C ones you can fit the later cross drilled input gear,
regards
Dave
www.ashcroft-transmissions.co.uk
ashtrans is offline   Reply With Quote
Old 10-11-2005, 07:14 PM   #6
Greg Davis
Greg Davis's Avatar
Member # 11066
Thanks guys. I'm in FL for the week, but I'll be in touch when I return.
Forum Jump
