#1 |
Pirate4x4 Addict!
Member # 4821
Paint: Flat, Glossy, Satin???
My brother is about to paint his chasis black. He likes the look of flat black but not how it seems to absorb mud. Gloss seems to be too shiny and he has read that the cheaper paints he will use will get a wierd sheen over time.
So then he was thinking satin or something in between but cant find any of the readily available paints in a mid gloss or satin finish. I used rustoleum bare metal primer and gloss paint sprayed through a cheap gun and thinned with acetone. He is worried that with gloss black that same set up will look to 'bling-bling' for the tough, simple look he is going for. The Hammerite Rust Cap Hammered finish says it is a "glossy paint" but looks to be nicly dull from the pictures we have seen. Any pictures or experience applying that stuff with a gun? I know it is a spray can favorite. Is there any other mid glossy finish paints that are readily available and easy to apply? Somewhere in between a flat and a glossy so that it does not absorb mud but it does not look all bling bling. |
#2 |
Registered "User"
Member # 21064
John Deere Blitz Black looks good. More of a Satin black i think. Its not quite as flat as the 'Krylon Flat Black' used in the Camo System. Used it on my Toyota. Dunno about absorbing mud but the shit washes right off for me. Dont foget cheap; I shopped around and found it for $18 a gallon but ive seen it as high as $35. Also comes in aerosol cans.
move along, nothing to see here |
| Sponsored Links |
#4 |
Member # 1655
Semi for sure
72 COMMANDO/454/TH400/39.5 BOGGERS/DANA 60's/203/300 Doubler......sold |
#5 |
bullshit detector
Member # 21765
rustoleum satin black, or rustoleum hammered finish, real hammerite is great, but a bitch to work with, you have to spray a whole can all at once, and the caps get plugged all the time, and the cans get plugged also, if you can deal with this, its a great finish
#6 | |
rock midget
Member # 13880
rusto flat is better
84runner with tons,r151,duals with 4.7s in the rear, a little tube and some tenderized sheetmetal. Lucky13 CLICK HERE TO SIGN UP FOR BLUEHOST.COM NOW |
#7 |
Member # 3273
rustoleum satin black is the ONLY way to go
#8 | |
Member # 12695
My hood is Rustoleum satin black and my axles are Krylon semi-flat black. Dan
"We live in the Land of the Free because of the brave." Please remember our Troops! |
#9 | |
awshifting.com awshifting@gmail.com |
#10 |
Check out Eastwood:
http://www.eastwoodco.com/shopping/p...iProductID=128 Semi-gloss epoxy chassis black paint.
GET INVOLVED - Join the Blue Ribbon Coalition '93 Chevrolet 6.5TD 2500 NV4500 4x4 Std. Cab Longbed 146K '85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild) |
#11 |
Member # 30549
I used VHT's satin black chassis paint in the spray can. If it's a tube buggy then I would use a spray gun and a booth if possible. Big problem with overspray on mine. I know your not building a show truck, but niether am I. If your going to paint it then you might as well make it look good. The gloss is way easy to keep clean and looking good. Maybe go with a flat black paint and shoot some clear over it.
Let me know what you end up using. |
#12 |
Member # 9994
Tractor Supply co. has a paint that is called "low gloss black". i use it on all kinds of stuff and really like the color. you should be able to find it on their website.
1984 CJ-8 1986 CJ-7 1981/1992 CJYJ 1994 RAM 1500 4x4 Custom Fabrication Parts: [url]www.troutindustries.com[/url] |
#13 |
Member # 15400
rustoleom satin black
92 YJ, 383TPI,700r4,60's |
#14 | |
Member # 17103
spray your frame with PAM before you go wheeling, you hose the mud right off, and the paint wont absorb and of the mud's color.
If i have to breathe your second hand smoke, I get to hock chew spit in your mouth. Deal? Quote:
#15 |
Member # 22906
John Deere Blitz black is flat, it's the big rage with the Rat Rod guys. For your chassis I vote semi black.
Drunk again. 1976 Terra. 2X4, 196, 4 speed. Restored trailer queen. 1995 Ranger 4X4, 6 cyl, auto. Current project. |
#16 |
Member # 52028
A buddy of mine and I repainted his trailer with a cheap two part paint from the auto paint store... required the paint, plus a reducer. Sprayed it through a cheap gun... the second quart we mixed came out with a different sheen than the first which really pissed us off, but we discovered that we could vary the reducer and get just the right look we wanted....
both the paint and reducer were under $30, and we still have over 1/2 the product left, which should be more than enough to paint the top half of my suburban... |
#17 |
Member # 20092
I just painted my front axle with Hammerite and I am getting ready to do the rear. I am impressed with the finish, and yes, the paint was a PIA to work with. The nozzles plugged up several times on the spray can. I had to rob one from another can to finish the job, and repeatedly had to place the spray nozzle on a can of brake cleaner to loosen the jammed up opening.
Click on my link and you can see how it turned out.
1985 Jeep CJ7, Ford 5.8l SEFI, C6, Atlas II 4.3, linked, 60/14b, detroits, 42s w/stauns. |
#18 |
any gloss black paint , just add a flattner to it
85 cj 7 for sale 304 t 18 dana 20 dana 30 front arb locker and 456 gears amc 20 rear 456's and arb locker 6 inch lift and new 33's on eagle 589's and 36 tsl's $4200 |
| Thread Tools | |
| Display Modes | |
