Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > Shop and Tools
Old 11-18-2005, 07:05 AM   #1
CPOM
Member # 21000
Send a message via AIM to CPOM
air curtians, plastic dividers they use in doorways of freezers
Where could I find this type of thick vinyl to make my own curitain? You know the stip type ones you can walk through. I have a swing out garage door made out of plywood and for the winter I don't need vehicle access in and out. It's getting cold.. My assumption is that this would be easier than trying to insulate the door and all its gaps etc. I am open to suggestions if there are alternate ideas for insualting a door cheaply.
[COLOR="DarkSlateGray"]Chris
92 Isuzu Pup, 3800>r150f>dual toy cases
toy 8", isuzu 12bolt, not done yet[/COLOR]
CPOM is offline   Reply With Quote
Old 11-18-2005, 08:39 AM   #2
Kendo
Kendo's Avatar
Member # 635
Like this http://www.randmh.com/php/page.phtml?0329
Maybe this http://www.randmh.com/php/page.phtml?0170
[b][color=yellow]2004 Polaris Sportsman 700, my replacement crawler. [/color][color=green] Ex Jeep owner.[/color][/b]
[b][color=red]The artist formerly known as [i]Putzboy[/i]![/b][/color]
Kendo is offline   Reply With Quote
Old 11-29-2005, 11:03 AM   #3
CPOM
Member # 21000
looking for a cheap way to build my own. or a way to get that vinyl for cheap. thanks though.
Old 11-29-2005, 11:08 AM   #4
Lil Toe
Member # 28900
http://www.teksupply.com/webapp/wcs/...sion=TekSupply
Check under doors and hardware, they usually have some precuts cheap too.
I can roll anything!
Lil Toe is offline   Reply With Quote
Old 11-29-2005, 06:45 PM   #5
LittleBlackSambo
turd polish a-go-go
LittleBlackSambo's Avatar
Member # 49404
Send a message via Skype™ to LittleBlackSambo
http://www.pvcstrip.com
http://www.thtindustries.com
thanks for the compliment, but it's not a jeep.
LittleBlackSambo is offline   Reply With Quote
Old 12-02-2005, 04:40 PM   #6
badasshybrid
badasshybrid's Avatar
Member # 15956
reply
Dont know if this will help you or not, I was looking for the exact same thing for my dog house. I found a place that sells it but will only sell it in rolls of 50' sections. And that shiat is high, its like 3 bucks a foot. And that was the cheapest place I could find.
Throw some attic insulation on the door and find a good heater.
badasshybrid is offline   Reply With Quote
Old 12-04-2005, 02:11 PM   #7
ZJim
ZJim's Avatar
Member # 24099
Send a message via AIM to ZJim
Virtually any thick/heavy plastic will work.
ZJim is offline   Reply With Quote
Old 12-05-2005, 03:37 AM   #8
Bansil
Member # 25557
Cheapest way is to get a roll of plastic from the home improvement store and staple it up. It will keep out the air and is cheap if you need to get out and then you just put new up.
Rool the last couple inches on each edge and staple or nail a pc of dowel/wood down so the edges of the plastic are sealed.....this is probable under $10 for plastic and staples.....it'll keep the wind out and that's what's cold.
Good luck
Bansil
Bansil is online now   Reply With Quote
Old 12-06-2005, 11:16 AM   #9
cwest
Member # 58100
If it's cheap you want, Bansil's method works great. And to add to that, you can buy a zipper that works with this method. You just stick it in the middle of the plastic and you have in/out access. Been doing this for years on construction jobs, and I'm in a cold climate (0 degrees F. as I type this). I use the thickest plastic I can find...usually 6 mil. Both can be found at home improvement stores.
tip: put the zipper on in a warm room and reinforce with duct tape
hope this helps, good luck.
cwest is offline   Reply With Quote
Forum Jump
