#1 |
Red Dragons!
Vroom Vroom Vroom
well she came back to life and fired in under 2 seconds... bought a 60k long block from a part's trader locally for a sweet deal and it had been in dry storage for roughly 10 yrs... dropped a lil more oil in the cyl's and she purr's like a kitten... didn't even need to adjust the valves... feels like it's got alot more balls than teh alst motor too
now if it would just stop smoking
BITD #4401 ![]() 2010 Partners: Bilstein Shock Absorbers, Trail-Gear, Shaffer's Offroad, S&N Fab, Superior Axle & Gear, Raceline Wheels, Big Country Customs, PSC Motorsports, Vision X Lighting.I Wanna Go Fast! |
#2 |
Bomber Fab
Member # 3069
dont blow it up
| Sponsored Links |
#3 |
Member # 3129
sweet, that is awsome. Hope the rings are good. Turbo right, could be the turbo that is smokin.
Keep it toyota, better yet, make it TURBO TOYOTA-------------------------- [url="http://www.supracharged.com"]www.supracharged.com[/url] No trucks right now!!! 1993 Toyota Supra - big single 1993 SC400 - M90 Supercharged, 1994 GS300 - 916whp 4door family car sleeper 2002 Sequoia - wifes car |
#4 | |
Red Dragons!
i'm kinda sure it is after we ran it 30 min it would still puff a bit... i felt teh endplay on teh turbo and it wasn't real stiff.... and there was oil in teh crossover tube, so i have a felling a CT26 is in my future!
#5 | |
Pirate4x4 Addict!
Member # 30
Location: Roseville, CA,To many Yuppies, Not enough Hippies
David & Theresa, Roseville, CA, Excellent Parts Source http://www.davezoffroadperformance.com/ http://www.marlincrawler.com/ http://www.12voltguy.com/web/ |
#6 |
Member # 10796
Buy a Garret T3/T4
why ct26 you can get a garrett T03 or T04 for $450 brand new! the Garrett turbos are much better than the std CT20 and are much cheaper to buy and rebuild. They are also less prone to cracking in the exhaust housing. You can adapt one to your stock toyota turbo manifold with a piece of 3/4" steel plate drilled out as an adapter flange.
Go here: http://www.turbochargers.com/current...ls/T4turbo.htm |
#7 |
im going to call a garrett t66 for the old girl
someone who has everything has everything to lose. BEN HARPER www.outerlimits4x4.com |
#8 | |
Member # 3129
#9 | |
Member # 3129
Re: Buy a Garret T3/T4
#10 |
Member # 3129
Holy cow, they offer the T3/T4 hybrid for $450 too, can barly get the ct-26 upgraded for that.
Dude, DSI go witht eh T3/T4 hybrid. Good turbo for smaller engines. Good for 300-350hp. The hybrid gets really good spool, and has the wasgate built in. Great deal there. Dang, still wish I had my 4A MR2. I wanted to turbocharge that. The ct-26 is too big for the 22R. If the 22R could rev to 7000rpm, then it could use the ct-26.
Keep it toyota, better yet, make it TURBO TOYOTA-------------------------- [url="http://www.supracharged.com"]www.supracharged.com[/url] No trucks right now!!! 1993 Toyota Supra - big single 1993 SC400 - M90 Supercharged, 1994 GS300 - 916whp 4door family car sleeper 2002 Sequoia - wifes car Last edited by SuperRunner; 03-28-2002 at 10:53 AM. |
#11 | |
Member # 11799
Re: Vroom Vroom Vroom
What exactly did you do to prepare this motor to run for the first time in 10 years? I've got an '86 22re with 125,000 on it, hasn't been started in 5 years. It has the same oil, gasoline, coolant and everything that was in it when I parked it. My plan was to put Mystery Oil in the cylinders, drain the gas tank, drain the oil and put fresh in. Then what, just crank the main pulley around? Or stick a flathead screwdriver bit in the distributor hole to run the oil pump with a drill? That may sound fawked, I remember it from an 80s Hot Rod about resurrecting old engines. |
#12 | |
Member # 6588
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR] [COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR] |
#13 | |
Re: Re: Vroom Vroom Vroom
We put some oil down the cylinders, cranked it over by hand for a bit and fired the bitch off.
#14 | |
Member # 8565
![]() Sorry i know it works in clevo's and windsors and a few other engines but the oil pump on a 22RE is driven by the crank. The dizzy is driven by the cam shaft.
www.outerlimits4x4.com www.werockaustralia.com SAVE THE HAMMERS Post #749 Do illiterate people get the full effect of Alphabet Soup? If electricity comes from electrons, does morality come from morons? |
#15 | |
sorry fast and ferious had the best of me that time. NICK
#16 |
Shit ... A T3 would be plenty for a 22R - It will support abit over 300 hp and over 20 psi of boost - can always upgrade the wheels while ur at it too
Im prolly gonna go hybrid in my car and 300 hp im thinkin good for 12's in the 1/4 Wish I hada supercharger or a 4.3 turbo engine for my toy
'80 Toyota '55 IH COE Truck '70 W100 4 Coots - '90 cummins 15 tractors and still collecting |
#17 | |
Member # 11799
Re: Re: Re: Vroom Vroom Vroom
Thanks, that's what I needed. Yeah, it was old V8s they were talkin about. Guess it's time for the ratchet. I may d/c the coil, pull all the plugs, and crank the starter for a few 10 second runs. |
#18 | |
Member # 11799
#19 | |
Member # 2798
i would be willing to be that is the turbo. if i run mine hard (up to 5,000) it will puff a little what are you doing with the old parts motor???? keep in mind that there are hundreds of different turbos, just because they ar t3's or t4's they differ alot.
go marlin and dont support the china. dont trust unhonest vendors that lie to you and play games |
#20 | |
i can get you a toyota MR2 super charger for about 250USD shipped. NICK
#21 |
hmmmm I wonder how one off those would work - I guessim gonna have to research it
| Thread Tools | |
| Display Modes | |
