Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Classifieds > Misc. Stuff For Sale
Old 01-14-2006, 09:39 AM   #1
Derek K10
Member # 43420
Send a message via AIM to Derek K10
huge ass garage sale
Well as most of you know I am breaking down the pickup in order to build the blazer, a lot of stuff I am keeping for the blazer other things I am selling. First, everything is sold as is, I am a trustworthy guys as many of you know and I will describe everything as best as possible, but please ask questions. Second, I hate selling things, as we all want to get the most we can for stuff, but I don’t want to turn anyone away. Please shoot me ANY offers, reasonable or unreasonable, the reasonable ones will be considered and the unreasonable ones will at least give me a chuckle… ha I try and post one picture of everything, I have or can take more if need be. I will ship stuff on your dime, but for the large stuff I will need you to help me set it up as I have not really shipped big stuff.
Here we go
CUSTOM FRONT BUMPER $250
Should fit all 73-87(91) full size GM pickups, burbs, and blazers, maybe older also, I don’t know
Bolt on with factory holes, right now 3 on each side, I was going to drill out for 2 more on each side to give it more rigidity. Brackets are 3/16” plate, tube is 1.5” 120 wall DOM and braces for stinger and corners are 1” 80 wall chromo. Flat black. Has been used and has not deflected at all, including jacking off corners and banging into stuff. The best part is it is multifunctional with a bottle opener on the top of the stinger. No hardware. 2 light tabs.
CUSTOM REAR BUMPER AND HITCH $150
Should fit all 73-87(91) full size GM pickups, maybe blazers and burbs if the gas tank is raised, maybe older also, I don’t know
Bolts on with factory holes, The hitch was a summit hidden style one meant to mount up high to come out behind a plate on a roll pan, which means it hangs down a lot less then a standard hitch. 2” receiver. Tube is 3” 250 wall. Brackets are ˝ plate I believe. All brackets are welded right to the hitch brackets. Drilled and tapped holes for license plate. Mounts with 6 grade 8 bolts, not included. This was stout and never moved when jacked on and when Archie rammed me into trees hard.
ROCK SLIDERS $200 Pending
Weld on, the were welded onto my truck and I cut them off as close to the frame as possible (all within ˝”), so they will need probably need some fitment before welding. Box is 4x2 120 wall, tube is 1.5 120 wall DOM. As they were they were not the most rigid, I was going to gusset all the stingers at the frame but never got around to it, even as they were they held the truck up just fine when sliding over rocks and jacking up on them. Flat black.
LENGTHENED REAR DRIVESHAFT $100
Lengthened for a short bed pickup with 6” of lift and 14b rear, slip yoke for NP208, Joints have maybe 800 miles on them, rear joint is a conversion joint for ˝ ton shaft to 14b yoke. Flat black. Balanced, never gave any vibes even up to 90ish. I can get the length measured for you I just don’t have it off the top of my head.
S10 BUCKET SEATS WITH RISERS $30
Blue vinyl, not the best shape, but very comfy. Bolts into one stock hole each side, you drill 3 others. Has risers for the front made of 2x2 120 wall.
BLACK DASH $75
Perfect condition, no cracks or fading. New 4 years ago.
PAIR OF DOORS $150
Black with white pin stripe. Manual windows, tinted windows (35%). Maroon interior panels that were painted black and need new paint. Broken Drivers vent window pivot, but if left closed there is now problem with it. Drivers door has small dent of b-pillar side. Pass side has 2 small rust bubbles on bottom. Have 3 extra pieces of glass, and at least one extra window crank. I also have a pair of power doors, doors are pretty much junk but glass is good and I assume power stuff works fine, make offer on these or parts of these.
91 BLAZER FRONT END $75
For your front end conversion to the newer style, comes with grill, all lights and turn signals, radiator support, and light pig tails. I don’t believe anything else is needed for the conversion but if so im sure I can pull it for you.
HOOD $40
Should fit all 73-87(91) full size GM pickups, burbs, and blazers. Straight, non-dented stock hood. Shitty faded stock paint and sweet FTR tag.
FRONT BUMPER $30
Stock with bumper pad. Chrome is good shape
GIZZLY GRILL GUARD $50
Black, bolts to factory holes. 2 light tabs
NO NAME GRILL GUARD $15
Not for chevy full size but I machined 2 spacers and drilled 4 holes and it looked great. Chrome with dent in center of lower bar, 2 light tabs
Beat the Whore
Derek K10 is offline   Reply With Quote
Old 01-14-2006, 09:50 AM   #2
Derek K10
Member # 43420
BLAZER HARDTOP $100
Black and in good shape. Sliding rear windows, one window has crack but does not leak at all.
6” SUPERLIFT LIFT KIT $300
Front and rear springs. All bushings are in good shape. You can also have the shocks, they look like crap but work just fine.
4” RAISED STEERING ARM $25
For 10 bolt front.
4 15x10” 6 LUG BLACK ROCK CRAWLERS $80
1 has good rock rash around the lip, other have very little to none. Chevy 6-lug with 3.75” backspacing (I believe) I have chrome valve stems and caps with them if you want them.
ROLL PAN $40
Fits 73-87 full size pickups, hole cut behind the license plate for hidden hitch, can include flip up plate bracket for $5. Painted black and white like my pickup.
5 6-LUG RALLY RIMS $FREE$
15X8 painted black, comes with center caps, have chrome trim rings as well for a few bucks. Come and get them out of my way
3 37x12.5x15 SUPPER SWAMPER SSR’s
I have 3, have some tread left but not a lot. Would make perfect fullsize spares for you guys running 37s. bottom 3 in the picture
700R4 and NP208
These are only for sale if I can get a line on a th400 and 203/205. 700 was rebuilt about 25-30 k ago (I believe, I have paperwork at home and can check. I am also not really sure what they are worth so make me an offer.
AFTERMARKET BENCH BUCKETS $30
fits 73-87 pickups with not modification
arm rest / console flips up for 3rd passenger
may fit others
BUG SHIELD $20
clear, one mounting tab broke off but just drill new hole and will work fine
SOFT TONNEAU COVER $80
Extange Black Max, a few of the snaps are broken but can be fixed at any place that installs them, or for a bit more I can go get them fixed before hand.
Im sure ill add more is I look around my garage. If you are looking for anything specific let me know, I have both my pickup and the blazer which a pretty much getting striped.
Things im looking for
TH400, NP203 and NP205 for doubler, D60 locker, D60 shafts, Winch with remote mount controller, 63” chevy rear springs, various tube, sheet, and plate
CHECK BACK FOR UPDATES AS I FIND OTHER THINGS TO SELL AND MORE PICTURES
Beat the Whore
Old 01-15-2006, 09:34 AM   #3
b0mb
Member # 24895
i'm interested in the 37's, but I don't know how much it costs to ship tires. Also, would you consider just selling one 37?
b0mb is offline   Reply With Quote
Old 01-15-2006, 03:35 PM   #4
Red Chevy Girl
Red Chevy Girl's Avatar
Member # 504
Send a message via AIM to Red Chevy Girl Send a message via Yahoo to Red Chevy Girl
I'm interested in the rear driveline, what are its measurements?
Kristen
85 chevy, 350, T400, d60, corp 14 -4.56 gears, locked front & rear with 44" boggers
84 Toyota
02 F250 Diesel
Red Chevy Girl is offline   Reply With Quote
Old 01-15-2006, 03:41 PM   #5
nvrenuf
that guy...
nvrenuf's Avatar
Member # 10903
Will you part out the power mirror stuff from the '91? If so, how much?
John
06 Dodge 2500
06 Unlimited Rubicon
91 K5
nvrenuf is online now   Reply With Quote
Old 01-15-2006, 06:26 PM   #6
aztec777
aztec777's Avatar
Member # 4784
Send a message via Yahoo to aztec777
Interested in the 6" lift, the 15" trim rings and the aftermarket bench/buckets. Can you please get a better pic of the seat? Please email me at e308@hotmail.com so we can discuss. Thanks.
Steve
19ZB4K8
VENI VIDI VICI
aztec777 is offline   Reply With Quote
Old 01-15-2006, 08:41 PM   #7
shin
Member # 56016
Send a message via AIM to shin
i am interested in the factory trim rings... how much to ship to 54140... and how much would u like for them...
silly rice, racing is for V8's!!!
id rather be snorting coke off a hookers ass...
shin is offline   Reply With Quote
Old 01-15-2006, 09:27 PM   #8
SouthernK5
Member # 53382
Send a message via AIM to SouthernK5
interested in the 91 front clip. shipping to VA 22039?
also could u take some more pics of the front bumper.
thanks
'85 k30 with crawl ratio of 140:1
'88 k5 on 39.5 iroks
muddybuddy on ck5
SouthernK5 is offline   Reply With Quote
Old 01-16-2006, 11:39 AM   #9
Derek K10
Member # 43420
i am extremely busy today but i will get back to all of you tomorrow
Beat the Whore
Old 01-16-2006, 02:18 PM   #10
yernkie
yernkie's Avatar
Member # 37553
Price on the 15X10's and the 4inch steering arm shipped to 66071? Please PM me because I may not make it back to this thread.
I find that immaturity trumphs professionalism anyday
yernkie is offline   Reply With Quote
Old 01-17-2006, 03:39 PM   #11
Derek K10
Member # 43420
i have no problem selling just one
im not sure on the cut off but i know you can ship tires through UPS
if you send me your zip code i can check shipping this weekend when i go home
make me an offer on one
Beat the Whore
Old 01-17-2006, 03:40 PM   #12
Derek K10
Member # 43420
i will try to get someone at home to measure it but if not i can measure it this weekend
Beat the Whore
Old 01-17-2006, 03:40 PM   #13
Derek K10
Member # 43420
sure
how does 50 plus shipping sound?
Beat the Whore
Old 01-17-2006, 03:41 PM   #14
Derek K10
Member # 43420
2nd in line ill get back to you
Beat the Whore
Old 01-17-2006, 03:42 PM   #15
Derek K10
Member # 43420
thanks
shipping on that would probably have to be in pieces i will get back to you asap
Beat the Whore
Old 01-17-2006, 03:52 PM   #16
Derek K10
Member # 43420
i just cleaned out my inbox for who ever tried to send a message
Beat the Whore
Old 01-17-2006, 08:13 PM   #17
nvrenuf
that guy...
nvrenuf's Avatar
Member # 10903
Power Mirrors
Originally Posted by Derek K10
sure
Sold! PM sent.
John
06 Dodge 2500
91 K5
Old 01-24-2006, 12:35 AM   #18
luckydogz
luckydogz's Avatar
Member # 65453
Send a message via Yahoo to luckydogz
interested in front bumber,lift/have np203out of78 good shape,solid i'm at 83815 zip pm me or e-mail luckydogznid@yahoo.com if interested in trade thanks soon would be appreciated trying to finish 91 k5
[COLOR="Red"][/COLOR][COLOR="Red"][I][/I][/COLOR]PUT UR SEAT BELT ON, I WANNA TRY SUMPTHIN SAW IT IN A CARTOON,,BUT I THINK I CAN MAKE IT !!91k5builden/78k5trashen
luckydogz is offline   Reply With Quote
Forum Jump
