Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 02-10-2006, 09:25 AM   #1
saprobe
Member # 6596
need buick 455 info
been searching,all forums,and have found lots of hits,but no real info.
basically i need to know how to positively ID an engine out of a car. its supposedly a a 455 4bbl from a 72 buick electra.
any links to ID,or general info would be appreciated.
also,where do i find a flywheel? will one from a buick 350 work? if i do this swap,theres no way in hell im goin back to a slushbox.
thanks...
scotty
85 grand wagoneer(whats left of it)
77 scout II truggy
84 "home made crew cab"
Mindless
Entertainment
saprobe is offline   Reply With Quote
Old 02-11-2006, 04:20 PM   #2
420willys
i got my avator back
420willys's Avatar
Member # 23452
i to are looking for specs for this motor, i found one this week for short money and was wondering if its better for me to grab this motor or look for a a 454, jason.
420willys is offline   Reply With Quote
Old 02-11-2006, 06:51 PM   #3
roy jones
Baaaaaby ruths
roy jones's Avatar
Member # 50585
buickkkk
these moters when tinkered with make well more than 500 ft pd of tourqe at 2000 rpm so give it a try. a few years back hot rod mag done a motor dyno and the buick was the had the most power oh well just my 2 cs
roy jones is offline   Reply With Quote
Old 02-12-2006, 11:34 AM   #4
Brutpwr
Brutpwr's Avatar
Member # 481
The Chevy will make cost less $$$ for the same power. The advantage of a Buick is it weighs about the same as a small block Chevy and has a long stoke so it makes a lot of HP/torque at a low RPM where it does a lot of good for wheeling.
Jason
Brutpwr is offline   Reply With Quote
Old 02-12-2006, 11:57 AM   #5
LCAC_Man
LCAC_Man's Avatar
Member # 35307
Here's a good site for buick casting numbers. I'm sure you found the big 455 stamped at the top of the bell housing area of the block.
Both head and block numbers will steer you straight, the vin is also stamped on the block the sixth digit is the year 2=72.
http://www.atlantabuick.com/CastingNumbers.htm
Spent plenty of time on mine. Though it's still in a Buick.
Len Barron
72 Commando/LS2/4L65e/NP241
DRWHP60-ARB/14B-Detroit/4.56/H1's/37's
Bullnose Build in Progress
Stretched Bullnose
LCAC_Man is offline   Reply With Quote
Forum Jump
