Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Miscellaneous > General Chit-Chat
Old 02-14-2006, 12:08 PM   #1
CaryW
WALKING AMOK
CaryW's Avatar
Member # 22104
Science Fair again. Will it work?
OK, dear old dad does not have much faith in my sons project. He is making a steam boat. In pre-production testing late last nite I did generate a fair amount of steam but I am not sure it is going to propel the boat.
Plan 4" wide balsa plank 1/4" thick. Will cut to length depending on how well it floats.
2 tea lite candles sitting on balsa under a glass test tube half full of water with cork. Small hole in cork. This will be like a piggy back jet for propulsion. I am not sure it will generate enough to move the boat.
I just googled and a "put-put" boat is the same theory but it shoots the steam out under the waterline. The water would seem to have lots more resistance to the steam, therefore providing more propulsion.
Is this damn thing gonna work or are we in for some late night renovations?
Oh yeah, parents. If you live in a small town explain to your kids that balsa sheets are not a common thing and it will piss your dad off to have to drive an hour each way and spend 20.00 in gas for a $3.00 sheet of wood.
And of course it is DUE TOMORROW
CaryW is online now   Reply With Quote
Old 02-14-2006, 12:10 PM   #2
pkhart
pkhart's Avatar
Member # 5199
Send a message via AIM to pkhart
shoulda just used a foam cooler,
i think the tube under hte water will work better.
P.K.
pkhart is offline   Reply With Quote
Old 02-14-2006, 12:14 PM   #3
MattS
Pirate4x4 Addict!
MattS's Avatar
Member # 386
Send a message via ICQ to MattS
If you build a boat as good as you post you will be the first person to sink a balsa boat.
MattS is offline   Reply With Quote
Old 02-14-2006, 12:15 PM   #4
CaryW
WALKING AMOK
CaryW's Avatar
Member # 22104
Sheet, the first 2 were foreplay.
Old 02-14-2006, 12:27 PM   #5
Binford
Member # 34249
I agree, run a plastic flex tube out the cork to the back of the boat and under water. That should get you moving.
Save a Horse, Ride a Cowboy
Binford is offline   Reply With Quote
Old 02-14-2006, 01:06 PM   #6
Myanarchy
Myanarchy's Avatar
Member # 14059
Just build something tried and true like a meth lab
"free 71PA_Highboy!"
Myanarchy is offline   Reply With Quote
Old 02-14-2006, 01:42 PM   #7
WindRider
Member # 17366
Do NOT use a glass test tube if you run the tube out under the water line. When it blows all of the steam out of the tube it will then suck COLD water back into the tube and bang! Test tube all over the room.
That said, I do not think it will produce enough thrust in air to drive the boat very well.
There are no problems that can not be solved with the proper application of high explosives.
WindRider is offline   Reply With Quote
Old 02-14-2006, 06:01 PM   #8
Pazuzu
Member # 54
Just remember...
part of experimentation is trials and failures. If the boat doesn't work, have your son write a page about what he wanted to happen, why he thought his attempt would work, what he thinks went wrong, and how he would change things next time.
Even if he doesn't win a ribbon, he learned what he needed to.
Pazuzu is offline   Reply With Quote
Old 02-14-2006, 06:05 PM   #9
7.62FMJ
Loner
7.62FMJ's Avatar
Member # 66780
Heh...I cant believe this. I did this same experiment for my 9th grade science fair. I used copper pipe however with a hole drilled in one end. It moved along pretty fast too...
Sorry I dont remember much else....its been a long time
1985 'Yota -- For offroad and stuff
7.62FMJ is offline   Reply With Quote
Forum Jump
