#1 |
Member # 481
77 Ford Granada with running 302 complete $50
77 Granada 4 door yellow with only around 70000 miles! Has not been used since like 92 or so but was started and run occasionally. Hell the last time I had it running one of the radiator hoses blew up when the engine started to heat up. So now I know the hoses all need to be replaced! This is a 302 small block with a 2 barrel carb and automatic transmission. Lots of good parts. I stole the battery out of my Toyota truck and its starts a bit weak but starts the Toyota fine so its best to jump start or bring a battery. One tire was replaced as it dry rotted and would not hold air and one other tire has the tread begining to separate/rot off so it needs another tire there too! Engine was running good until the last time I ran it--was running a bit rough I think the carb may have a passage blocked--seemed to be running on one barrel of the carb starving some cylinders for gas... I put some carb/fuel cleaner in the tank along with some gas and that seemed to make it worse so it will need a carb clean for sure! Car was parked as it was my Moms extra car and a self service gas station attendant put engine oil in the tranny when it was low on engine oil so the car has been parked ever since. Tranny still works fine but has some engine oil in it. I tried once to pull the tranny pan but could not get it off as the exhaust crossover is right under the pan so I bolted it back on and now the transmission cover leaks a bit. Car is complete and has a flawless low miles yellow/tan colored cloth interior. Engine would be great for a buggy etc. Only asking $50--just for my time, gas, gas treatment, tire and mounting, battery reimbursement etc... Car will need to be trailered as brakes are weak...fluid was empty so I topped it off and I'd guess it needs to be bled. Lost pink slip but my Mom is going to the DMV in the next few days to get tags for her Tahoe so she may have a junk slip if thats any cheaper...I don't think the car is the DMV system anymore as I don't think it was ever non-oped.
Jason |
#2 |
Member # 481
To the guy whom PM'ed me about the spindels...I accidently deleted your message before responding... I do not wish to part this out at this time. Wish I had the time and space to do so right now but I don't. Prefer to just have this gone and should I have to dispose of this myself I want to be able to just drive it onto my trailer!
Jason
| Sponsored Links |
#3 |
Member # 481
ttt
| Thread Tools | |
| Display Modes | |
