Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Classifieds > Vehicles and Trailers For Sale
Old 03-02-2006, 09:09 AM   #1
THE_OWL
Member # 14850
Built XJ Part out ABQ NM
Never found time to finish this project, and 2 house payments now means no extra $$$.
Thinking of parting out the Jeep.
Atlas 21spline 3.8 with XJ shifters, Never had fluid. $1700
5 Allied 17x9 5-5.5 Beadlocks with MT/Rs. tires have ~500miles, rims new. $1500
Edelbrock Pro-Flo Fuel Injection for SBC. All new sensors $950
(comes with nice motor but has water jacket crack in block.)
700R4 with 21 spline output(AA) $750 0 miles
HD 4x4 Case
Corvette Servo
Deep ribbed trans pan
Transgo Stage II Shift Kit
Super Street Raptor 1800rpm Converter
Extreme Beast Reactor Shell
TV .500" Boost Valve
Manual Lock-up kit. Brake/Switch Defeat
Kevlar Band
13 Vane Pump
Borg Warner 3-4 Clutches
4 Sway-a-Away RaceRunner Dual Rate Coilovers with 2" Body, Remote Reservoirs and 250lb springs /200lb springs (14")(16") $1000 ??
Xj Dana 44 rear 0 miles on rebuild $1000
ARB Locker RD06(0 miles)
4.56:1 Precision Gear
HD Diff Cover
Warn Full Float Kit 5 on 5.5" (TJ)
Full Float Drive Flange Kit
Warn Disc Brake Bracket Kit
Disc Brake CJ Rotors Caddy Calipers
Porsche Red Calipers
Stainless ARB lines
Brand New Timken Bearings / Seals
Blue torch fab 4-link setup with cover
Dana 44 HP from '77 F-150 "0miles" $1500
WMS 60"??
ARB Locker RD06
Dynatrac Diff Cover
CTM U-Joints
Cryogenically Treated Warn Axle Shafts
Wild Horses Disk Kit #3005 Super Delx
Wilwood Calipers
HD Ball Joints top and Bottom "0-Miles"
Seals and Bearings all New
Redneck Hydro assist with tapped box
Or maybe someone is brave enough to buy the whole basket case.
recent pics http://owlie.omgwtfpwnage.com/xj_/new/
My friend moved his fab shop so I had to tow the Jeep back to my house.
No more excuses.
[url]http://heavyhog.com[/url]
THE_OWL is offline   Reply With Quote
Old 03-02-2006, 11:23 AM   #2
XJ99
Member # 64731
that's one sick XJ, you should definatley finish It, whats It all need to be done?
are u parting with the tail lights? would they work on a 97+ XJ?
XJ99 is offline   Reply With Quote
Old 03-02-2006, 12:17 PM   #3
weridodude13
weridodude13's Avatar
Member # 10410
also wondering what still needs completed. Possibly interested in the whole shebang, or just the Coilovers.
Brett
'91 YJ "Short Bus" -- 4.0HO, AX-15, D300 4:1, D60's Lock-rite/Detroit, 38.5 SX's, Caged, Winched, OBA.
Coming Soon: Hydro Assist and Beadlocks
weridodude13 is offline   Reply With Quote
Old 03-02-2006, 01:16 PM   #4
COVEJEEPSXJ
Rigless.
COVEJEEPSXJ's Avatar
Member # 36128
Are you interested in selling just the beadlocks?
"132 and Bush I've got him at gun point, OK gun point, 132 and bush, cover is code 3"
Originally Posted by 87manche View Post
just color it in with a sharpie.
COVEJEEPSXJ is offline   Reply With Quote
Old 03-03-2006, 08:43 AM   #5
THE_OWL
Member # 14850
to finish:
The rear crossmember needs a tad more reinforcing, the brake lines need to be run, a little bit of under hood plumbing, the water jacket leak needs to be JB welded, or addressed, interior rhino lined and re assembled (all 97+ interior components) driveshafts made, atlas linkage setup, roll cage welded in (fully cut and ready). Misc assembling of bolt up stuff. I havent worked on the vehicle in over a year. So Im not as up-to-date as I should be on it.
Ill look it over this weekend and take some pics of the areas that arent done.
It has all the linkage with big heims and bushings already to go. Everything on this truck is new.
As far as breaking up the wheels and tires, it cost me so much to have this stuff shipped in and mounted, I think its better to sell together, It would cost just as much to ship forward air with or without tires (mostly).
the tires are 37"
Heres a link to more details about the truck:
Old 03-04-2006, 11:10 PM   #6
ACHASE6002
ACHASE6002's Avatar
Member # 54836
How Much For Everything
ACHASE6002 is offline   Reply With Quote
Old 03-05-2006, 01:23 AM   #7
cherokee kidd
Nor-cal transplant
cherokee kidd's Avatar
Member # 27832
1200.00 and I'll take that atlas off your hands. I gots cash in hand and ready to finish my spendin for EJS
DAMAGE CONTROL INDUSTRIES
Nor-Cal hardcore offroad fabrication
Tube bending, mig and tig welding, rollcage design, and cnc plasma cutting avaliable. For info call (570) 466-5748
cherokee kidd is offline   Reply With Quote
Old 03-05-2006, 09:15 AM   #8
THE_OWL
Member # 14850
sounds like a great deal. A 0miles atlas II for 1200.
pass
Old 03-05-2006, 10:12 AM   #9
weridodude13
Member # 10410
Still looking for a quote on the whole deal. PM me if you wish to not post.
Thanks,
Brett
Old 03-05-2006, 10:27 AM   #10
THE_OWL
Member # 14850
his is a brief breakdown of what needs to be done:
brake lines run / line lock installed.
4 link rear needs axle brackets and rock bushings (included)
roll cage needs to be welded in (pre cut)
rear coilovers mounted to roll cage
track bar cut to size (chromo with heim/bushing)
various underhood plumbing / hydro assist
interior is out. have 2 gallons of noise killer. Interior is all 97-01 tan
needs driveshafts (not included)
strut bar made between shock hoops
engine has a water jacket leak. Can be JB welded, doesnt affect compression
Frame sleeving completed on driver side
various tightening / reinstalling of shit
transfer case shifters
diffs have never had oil
surface rust on new parts that havent been painted
needs engine tune with edelbrock pro flo.
Im sure theres more, I havent worked on it in over a year
Basic list of parts:
It now has a 4-link rear instead of springs
Hansen Front Bumper with warn winch
C4x4 rear bumper with tire carrier
snorkel
Iron Cross tailights in metal housings
conferr rack with hi lift, and 10 lights
Wilwood calipers up front
spare axles for full float rear
spare axles for front D44
Redneck racing Hydro Assist. with tapped and rebuilt box
Hard Mount GPS Antenna for laptop use (USB)
Be cool radiator
trans/steering and oil coolers front mounted
New black floor carpet, new black headliner in the bag
Line lock for brakes
rear suspension is almost complete. Has 1-1/4 heims/ rock bushings/chromo
Laser cut brackets for axle side, rear crossmember tabs.
designed to mount to roll cage inside of vehicle
Theres $23k in new parts on this truck. with no miles. some installed some in the box.
I think I want 7k
EDIT: the bolt pattern is 5 on 5.5 if I didnt mention that
Old 03-06-2006, 06:21 AM   #11
COVEJEEPSXJ
Rigless.
Member # 36128
How much for the front bumper?
Old 03-06-2006, 09:43 AM   #12
edubreuil
Member # 28567
I'm interested in your spare 44 front shafts. how much, and are they stock or what?
thanks
2007 Rubicon Unlimited, Rescue green,
Rock Krawler 3.5", 35"MTZ's
edubreuil is offline   Reply With Quote
Old 03-06-2006, 09:59 AM   #13
Bedolan
Member # 68423
Im intrested in the box and redneck ram,be cool and wilwood brakes if you end up breaking it all up.
Bedolan is offline   Reply With Quote
Old 03-06-2006, 10:05 AM   #14
sr5trd99
Member # 56206
Did you ever get my PM of the front axle, arms and shocks?
sr5trd99 is offline   Reply With Quote
Old 03-07-2006, 06:24 PM   #15
Lithic
Lithic's Avatar
Member # 67222
Wheels only????
Would you seperate the rims and tires and sell just the rims? Local 505.
Lithic is offline   Reply With Quote
Old 03-08-2006, 08:35 AM   #16
COVEJEEPSXJ
Rigless.
Member # 36128
Helllooo? I am still interested in the front bumper. I sent a PM on Monday. THANKS.
Old 03-08-2006, 05:49 PM   #17
areyouliving
areyouliving's Avatar
Member # 41017
Pm'd ya
areyouliving is offline   Reply With Quote
Old 03-10-2006, 02:11 PM   #18
GREEN XJ
Member # 42133
Pm'ed you about the Atlas but no response.
GREEN XJ is offline   Reply With Quote
Old 03-12-2006, 02:29 PM   #19
tobster
Member # 55562
hey is this still avaiable? are you interested in partial trades with cash? thanks
tobster is offline   Reply With Quote
Old 03-15-2006, 10:46 PM   #20
tobster
Member # 55562
does anyone know if this is has been sold????
Old 01-26-2007, 09:58 AM   #21
THE_OWL
Member # 14850
theres another thread on it.
Still for sale.
No parting tho
Old 01-26-2007, 09:36 PM   #22
desertboy
Member # 2363
If parting very interested in the axle and whats listed w/ it. Does the front axle have mounts for an XJ already there or no? Is it all installed and setup ie gears and locker? Is it still full width? Let me know i'm in fresno, ca so shipping would have to be worked out but i'm willing to work.
"I think it raises the confidence level if you wrench on your own shit"
95 Jeep Grand Cherokee 4 link rear radius front, cromo full width 44 front, 9" chromo rear locked for enjoyment, 37's (Trade for pickup?)
desertboy is offline   Reply With Quote
Old 01-27-2007, 07:41 PM   #23
XJ4THEKICKIN
Member # 23829
reading wasn't a highlight for you was it? read right above your post.
XJ4THEKICKIN is offline   Reply With Quote
Forum Jump
