#1 |
Square Tube vs. Round???
Ok, i have herd mixed things about bolth, hoping someone on here can give me an actual answer. is square or round tubing stronger(from resisting a bend). eg. if you put a piece of .120 wall 1" round tube in a press, would it bend easier or harder than a piece of .120 wall 1" square tube?
reason i ask, is i want to make an anti wrap bar and some folks say go square and some go round, and they each claim there way is less likely to bend(i know i wouldnt bend either but it really got me thinking which is stronger) please! someone! help me, i need to put this one to rest.
1 Ton TJ(ish) Buggy on 40's |
#2 | |
The cake is a lie
This tech is making my head hurt.
| Sponsored Links |
#3 |
Member # 25028
The square tube is stronger as it has more material farther from the centoid.
[SIZE="1"][URL="http://www.pirate4x4.com/forum/showthread.php?t=385253"]My Buggy Buildup Thread[/URL] [url=www.we-rock.cc]W.E.Rock Stock Mod #4[/url][/SIZE] |
#4 |
Everyday is Tuesday.
Member # 47
You want Grade 12 tubing. Square or round. Possibly solid, though if it's solid, you could make a grade 12 wooden driveshaft that would work for backup.
#5 | |
Run B100, SVO or WVO year round. dinofuelalternatives.com |
#6 | |
back in Cali
Member # 30530
Tina |
#7 |
Member # 37519
"Most" trailer hitches are made out of square so think about that..
[COLOR="Black"]..............[/COLOR]/´¯/) [COLOR="Black"]............[/COLOR],/¯../ [COLOR="Black"]...........[/COLOR]/..../ [COLOR="Black"].....[/COLOR]/´¯/'...'/´¯¯`·¸ [COLOR="Black"]..[/COLOR]/'/.../..../......./¨¯\ [COLOR="Black"].[/COLOR]('(...´...´.... ¯~/'...') [COLOR="Black"]....[/COLOR]\.................'...../ [COLOR="Black"]......[/COLOR]''...\.......... _.·´ [COLOR="Black"].......[/COLOR]\..............( [COLOR="Black"].........[/COLOR]\.............\ |
#8 |
Member # 39974
i would think anything with corners(edges)would bend first.but i dont know shit.
#9 | ||
The cake is a lie
Admitting your a dumbass makes you better than the 75% of the PBB who doesn't know shit, but won't own up to it. And for this, I congradulate you with my e-cookies. Please, clean the crumbs off the floor. Thank you and God Bless.
#10 |
I'd say square, but you have to have the folded sides facing the area that needs to be strong.
For example, If you were trying to bend a tube sidways, it would be really hard to break it if it were set up like this <> than a round tube like this o |
#11 |
Put the round in the square and run it
#12 |
Pirate4x4 Addict!
Member # 26382
the 1" square tube would better resist bending than the 1" round tube. the square tube would also be heavier. if you used a square tube with the same weight as the 1" round tube (just a wild guess, around 3/4" square) the round would be stronger.
87 4runner d44f/9"r full width, 5.38/5.43/ARBs, superior shafts, ctm's, twin stick 4-1 dana 300 behind toy t-case, allpro springs f/r, 39.5 iroks on aluminum trail ready bead locks ΜΟΛΩΝ ΛΑΒΕ I'm just a peckerwood who lives in the hills with too many guns. |
#13 |
There is no such thing as square TUBE. I learned that here.......somewhere
Laughing and crying I ran the Rubicon on 31's. Now Gatekeeper is gone. Make it stop
#15 |
Square IS stronger.............
[FONT="Comic Sans MS"]Catch your Dreams, before they slip away........[/FONT] [FONT="Arial Black"]Current vehicles[/FONT] 67 Bronco 69 Bronco 81 Bronco 81 Bronco 75 F-250 (highboy) 77 F150 78 F150 70 F100 (2wd) 93 F350 95 F350 (Blown Crazy") 95 F350 ("Crazy Too") 87 Ranger (2wd) 00 Excursion 04 Navigator |
#16 |
Member # 11425
just my opinion here, but the reason square is thought to be stronger is that is has sides that are straight up (vertical), when hit from underneath with a rock, will keep the flat (horizontal) sides from bending. on the other hand, round tube distributes the blow around the circumference, which could, actually, make IT stronger. check the tech tables and metal fab info here on PBB somewhere, or search. the truth is out there.
[I][SIZE="1"][COLOR="Silver"]"do what thou wilt shall be the whole of the law"[/COLOR][/SIZE][/I] |
#17 |
Member # 4363
Round tube is more aerodynamic.
'92 XJ- Stroked, Lifted, Bumpered, 44ed, Geared, Locked, LEDed, Scratched, Dented, Tired, and Exhausted. [QUOTE=fullygruntled]People have sex with furniture, too. I can't explain it, I just report it.[/QUOTE] |
#18 | |
SchuitOverBuilt
you are high as a kite. WTF is it then?? square PIPE?
#19 |
Zues of the Juice...
This is square tubing
![]() This is not...it's round ![]() There is the difference ![]() DOM round is stronger than HREW square...end of story Last edited by Benzz0; 04-06-2006 at 07:44 AM. |
#20 | |
Member # 2175
If my memory serves me correctly from that thread many years ago....grade 12 space tubing is what NASA uses on the shuttle n' crap. |
#21 | |
Member # 54
Do you still want to do anything like NASA does?
#22 | |
Member # 13786
#23 | |
Member # 4363
#24 |
Member # 2175
After multiple discussion I believe that the colletive wisdom of the PBB decided that square was strong in specific direction while round was stronger overall in multi-directions.
#25 | |
Member # 144
Square will deflect less. Try it yourself.
That's because you're a pinko fascist. - Haole I know what antidisestablishmentarianist means |
| Thread Tools | |
| Display Modes | |
