#1 |
Member # 49334
Pinion carnage twice What is the cause?
Below is a set of 4.88 genuine gears for a toyota 8 inch diff. I run an arb and stock axleshafts with 33's as a daily driver and 36's when I roll to the trails. I have dual cases both with stock gearing. I run my rig pretty good but I dont beat on it hella hard.
I had my gears set up by a pro diff shop. I broke in the gears properly and always had oil in there. But I have blown out two sets of gears both in my rear end. Both of my pinions snapped off 4 teeth. Right at the root of the tooth. The first one i was doing burnouts in the rain on a slicker than cat sh*t street and i heard kapow. That was about 2 weeks ago. The second one I took out of my front and was set up by the same builder. I moved this diff to the back so I could drive around on the freeway. I have only had the gears in the back for two weeks and took them out on a mild trail 2 days ago. Yesterday when I was driving up to my friends house at about 10 miles an hour in first gear up a slightly steep hill i hear another kapow. At this point I knew exactly wut it was. Another freakin set of gears went bad on me. And after i took it apart promptly found out i had snapped another 4 teeth off of the pinion directly from the root of the tooth. Now im looking for your guys opinions on why this is happening. Bad batch of gears? or bad install? I have my suspicions with the builder but both of the sets had a perfect pattern set up on them? I need a clue Here is a pic of the pinion. If you look closely you can see how deep the break was. ![]() Another picture before i took them apart. ![]() And heres the teeth I pulled out
[FONT="Century Gothic"][/FONT]89 Yota Pickup Straight Axle, 3RZ, Chromo longs, 5.29's, Arb's, Dual cases. |
#2 |
Member # 19325
part of the problem is probably the genuine gears.
| Sponsored Links |
#3 |
get Bobby to freeze ane bake your next set.
what could be better than blowing things up for a day job? [B]IYAOYAS[/B] |
#4 | |
Member # 3273
#5 |
Member # 65966
I've run Genuines in all of the 14 axles I've built and never had any problems. From Dana35s up to 14 bolts.
[U]Is that Jeep stuck in my tire?.[/U] 92 SAS Burban (SOLD) 85 4Runner (SOLD) |
#6 |
Member # 49334
Yeh ive had a feeling its the gears and the installer. When he put them together he didnt use a crush sleeve or any shims for the pinion. My friend told me he did it wrong when he took my gears apart for me and built my new ones.
The builder swears he builds bomb proof stuff. The first diff was a little bit loose. But the second one I broke was perfectly fine. I will have pictures of that soon. I was trying to figure out why the gears were breaking at their strongest point because at that point it couldnt just be the installer but also the integrity of the gears. Luckily i already do have a warranty on these gears through 4 wheel parts and i can keep blowing up as many as I want. But i was thinking about going to a set of Yukon or precision gears. Driving around town on the front is a pain in the ass specially when you cant go over 50 because of a square driveshaft.
#7 | |
Member # 19325
well there you go, the problem. |
#8 |
Member # 49334
Yeah but i did see like one spacer between the last bearing and the pinion head. I said isnt that a shim right there. And he told me no i guess its just the bearing spacer. But the pattern he set up on the gears was pretty damn good almost close to perfect.
My friend told me the only problem with the way he set it up is that it will come loose easier. Well my last diff wasnt loose at all. So thats what leads me to suspect the gears.
#9 |
Member # 65966
There's only a few companies that produce their own gears. Not all the gear companies have their own foundry. I don't which, but they just slap their name on a manufacture's gear. Just the same as some companies get the same shocks from the same manufacturer. It's all the same, pretty much, IMO
#10 |
Member # 49334
Yeh ive heard that before also. I wasnt quite sure if it was true but since many people are saying it I guess it is.
Well im on the verge of making a decision based on your guys opinions. And I dont think ill be taking my gears to the old installer again. Obviously he builds exploding pinion diffs. Thanks for the input.
[FONT="Century Gothic"][/FONT]89 Yota Pickup Straight Axle, 3RZ, Chromo longs, 5.29's, Arb's, Dual cases. Last edited by OakieOffroad85; 04-30-2006 at 12:30 PM. |
#11 |
Member # 12486
call up marlin crawler and have Rocky build you a diff.
#12 |
Member # 3475
just because there are no shims doesn't mean it is set up wrong..
was the pinion loose? Like I mean side to side..like you could shake the yoke? if he didn't use a crush sleave did he use a solid shim? like a little peice of pipe looking thing? IF gears were setup right, I would guess that the wrong yoke was used, and the crushsleave wouldn'tget enough crush, or the solid shim didn';t get shimmed right do you have the stock yota gears? if so stand both pinions up side by side and compare
FREE LED LIGHT http://pirate4x4.com/forum/showthread.php?t=851171 RC CAR Parts http://www.pirate4x4.com/forum/showthread.php?t=851196 ELECTRONICS DEALS.. examples at http://pirate4x4.com/forum/showthread.php?t=830142 Custom Gauges - Billet hotrod parts - Suspension -Batteries-Camera-Car Audio-GPS-Security-Photo-Appliances - Telecom Tvs-Video Game |
#13 |
i dont think its the brand, cause ive ran cheap ass 5.29's and I can light up the tires on dry ground and no breakage...same on the trail when I use my
37's. I second the backlash answer.
81yota 5.29's locked f/r 40's Dual cases Longs |
#14 |
Member # 25697
Most of the time it's installer error. Genuine gears aren't the greatest in the world...there is a reason they can lifetime warranty them. Cheap gear sets.
Too much backlash, not enough crush on the sleeve or if he used a solid spacer he might not have had the pinion depth set correctly. I second the buy a dial indicator and a torque wrench and do them yourself and leave that "pro" along. You might also consider using a different brand of gears. Beat on my Yukon 5.29's all the time with a ARB and 37's...they are holding up fine. Just take your time and get a great pattern and make sure your backlash is within tolerance and they will treat you right. It's not rocket science, you can do it.
72 FJ40 |
#15 | |
Member # 3273
#16 |
Pirate4x4 Addict!
Member # 26382
my genuine gears didn't even last through the break in period in my 9". the pinion wore away like it was not hardened at all. i could still see the set up paint on the ring gear. when i replaced them with a more reputable gear set i also replaced my front d44 genuine gears. they showed wear all ready and only had a couple trail runs on them.
sure some people get away with running genuine gears but it wasn't me. never again will i run them. also, 4wp sure asked a lot of questions for a "no question asked warranty". they almost didn't exchange them because i didn't want to buy another set up kit from them. the replacement gear sets were sold new in the box after that.
87 4runner d44f/9"r full width, 5.38/5.43/ARBs, superior shafts, ctm's, twin stick 4-1 dana 300 behind toy t-case, allpro springs f/r, 39.5 iroks on aluminum trail ready bead locks ΜΟΛΩΝ ΛΑΒΕ I'm just a peckerwood who lives in the hills with too many guns. |
#17 |
Member # 49052
These guys are more than likely right w/the cheap gears/improper gear setup answers, but something else that could be the problem....is your axle bent?
Exo'ed 83 yota with some stuff. |
#18 |
Member # 49334
Im pretty sure the guy didnt set them up right. The first time i broke the pinion I didnt have a Pinion spacer. All there was was a shim behind the main pinion bearing to set the backlash. There was nothing inbetween where the crush sleeve goes and yes the first one did come loose and broke on me.
The second one was set up the same way. But was not loose at all. In fact it was still as good as the day he built it. So thats what i thought it might be the gears. Thanks for all your input guys. Very helpful.
#19 | |
Member # 21858
a ritchmond pro gears should put end to your problems
cj5 76 SOA,OBA,OBW,LPG 14b & 60RC W/detroits High steering and ram assisted ford t18 and 205 , rear Fox air shocks new toy Cj7 82 on 33's setuped to mall crawling :D Last edited by MCgiver4x4; 05-01-2006 at 01:39 AM. |
#20 | |
rockiller is right, though. Do it yourself and you can be sure it's done right.
#21 | |
Member # 65966
#22 | |
Member # 25697
You don't set the backlash with the pinion shims either(that is done with the spaners). If the first 3rd he setup had the spacer missing (he's a FOOL, Toy thirds are simple to setup!) I'm going to guess he fawked the front 3rd up JUST as bad...which is why they both broke under conditions they shouldn't have. Good luck.
72 FJ40 |
#23 |
sometimes you have to hit the carrier side to side after putting in the adjusters, to make sure the carrier bearing's races are in there straight and not cock eyed. this could cause too much back lash after the third is installed and driven on. and you will not notice it until something breaks.
I have fawked one up like that. first third member I ever built. pull it apart...too much slop. it was good when I put it in..I thought. bearing caps were tight, adjuster locks in place. but too much backlash. I double check everything now. |
#24 | |
Pirate4x4 Addict!
Member # 30
Location: Roseville, CA,To many Yuppies, Not enough Hippies
Not that far to drive if you live in Pin-Hole, CA and well worth it.
David & Theresa, Roseville, CA, Excellent Parts Source http://www.davezoffroadperformance.com/ http://www.marlincrawler.com/ http://www.12voltguy.com/web/ Last edited by OOP'S; 05-01-2006 at 10:31 AM. |
#25 |
I do believe that Bobby's friend that tests stuff for him (red truck on 42s) it running some baked and frozen Genuine Gears.
Yep. you'll have that.... |
| Thread Tools | |
| Display Modes | |
