#1 |
Member # 47169
1971 F100 Swb 4x4 For Sale Or Trade
1971 FORD F100 SWB 4X4
390 C.I. ENGINE PURCHASED IN MARCH 2005 (HAS LESS THAN 3K MILES) 4BBL INTAKE,HOLLEY 670 CFM TRUCK AVENGER CARB,K&N AIR CLEANER,MOROSO AIR LID,NEW DISTRIBUTOR W/PERTRONIX IGNITION,BLASTER COIL,NEW 2-1/2 “ EXHAUST WITH “H “ PIPE AND FLOWMASTER 40 SERIES MUFFLERS, OPTIMA RED TOP BATTERY, DUAL 16” PERMACOOL ALUMINUM ELECTRIC FANS SET ON 180 DEG.THERMAL SWITCH, HD DEEP SUMP OIL PAN, MELLING OIL PUMP, NEW WATER PUMP,NEW RADIATOR HOSES,NEW HEATER HOSES, ARP STAINLESS STEEL BOLTS , POWDERCOATED PULLEYS,BRACKETS AND THERMOSTAT HOUSING. NP435 MANUAL TRANSMISSION 6.69:1 GRANNY LOW (HAS LESS THAN 3K SINCE SERVICE) DANA 21 TRANSFER CASE (HAS LESS THAN 3K SINCE SERVICE) HIGH PINION DANA 44 SOURCED FROM A 76’ F100 4X4 (HAS ALL NEW PARTS: ALL NEW HUB AND ROTOR ASSY’S ,NEW CALIPERS, NEW BEARINGS,RACES AND SEALS,NEW BALL JOINTS, NEW BRAKE PADS,WARN PREMIUM HUBS,POWERTRAX “NO SLIP” LOCKER, 3.50:1 RING AND PINION, NEW SPICER U-JOINTS IN BOTH DRIVELINES. FORD 31 SPLINE BIG BEARING 9” REAR DIF. ( NEW BEARINGS,SEALS, NEW DETROIT LOCKER, ALL NEW DRUMS,NEW BRAKE HARDWARE,NEW WHEEL CYLINDERS,NEW BRAKE SHOES, 3.50:1 RING AND PINION. SUSPENSION – ROUGH COUNTRY 4” SUSPENSION LIFT INCLUDING SHOCKS, DROP PITMAN ARM,TRAC BAR DROP BRACKETS,RADIUS ARM DROP BRACKETS, TRAIL PROOF TIEROD AND DRAG LINK W/GRADE 9 HARDWARE AND HEIMJOINT ROD ENDS,SUPERLIFT ADJUSTABLE TRAC BAR, ALL NEW JD POLY BUSHINGS IN COMPLETE SUSPENSION, 4”COILS. TIRES/WHEELS- 33X12.50X15 PROCOMP MUD TERRAINS (UNDER 3K MILES ON THEM) ON 10X15 STEEL BLACK POWDER COATED WHEELS, NEW SPARE 33X12.50X15 PROCOMP MUD TERRAIN ON 10X15 STEEL BLACK POWDER COATED WHEEL (HAS SEEN NO USE) VINYL SPARE COVER. INTERIOR- HERCULINED FLOORBOARD AND ADDED RUBBER PLUGGED DRAINS, NEW PADDED AND UPHOLSTERED BENCH SEAT,GRANT WOOD GRAIN STEERING WHEEL, POWDER COATED STEEL DOOR PANELSW/ STAINLESS SCREWS ,NEW INSIDE DOOR HANDLES,POWDER COATED DOOR LATCHES, POWDERCOATED CENTER INSECTION COVER W/STAINLESS BOLTS, SLIDING REAR WINDOW, AUTOMETER PHANTOM WHITE FACED GAUGES( 3-3/8” SPEEDO AND TACH, 2-5/8” FUEL,VOLT,WATER TEMP,OIL TEMP, OIL PRESSURE) MOUNTED IN GAUGE CUPS ABOVE DASH, MOROSO 5 FUSED TOGGLE PANEL, MIDLAND 40 CHANNEL C.B. RADIO, NEW WINDSHEILD/REAR WINDOW /DOOR RUBBER, NEW FELT WINDOW CHANNELS AND RUBBER SCRAPERS , POWDER COATED STEERING COLUMN, NEW TURN SIGNAL SWITCH AND STEERING COLUMN BEARINGS , NEW PAINLESS 18 CIRCUIT WIRING HARNESS, TRAILER BRAKE SETUP ,DIAMOND PLATE KICKPLATES AND DASH BEZEL. STEERING-BORGESON STEERING SHAFT, NEW POWER STEERING GEAR BOX AND PUMP. BRAKES- NEW POWER BRAKE BOOSTER, NEW ADJUSTABLE PROP VALVE. EXTERIOR- NEW PAINT(INDIGO BLUE) HERCULINER BEDLINER IN BED,ALL GRADE 8 HARDWARE USED,ALL OF THE FOLLOWING WERE POWDERCOATED BLACK STOCK FRONT BUMPER, CUSTOM REAR BUMPER, ALL EMBLEMS, GRILLE AND HEADLIGHT,FRAME RADIATOR SUPPORT, INNER FENDERWELLS, HOOD SPRING ASSY’S. HALOGEN LAZER BLUE HEADLIGHTS, WIRE MESH HEADLIGHT GAURDS. MODIFICATIONS- ADDED 15 GALLON REAR FUEL TANK, SWITCHING VALVE, MOVED HIDDEN HITCH UP INTO FRAME, FRONT BEHIND PLATE HITCH. ADD-ONS- REAR CARGO LIGHT, (2) 5 GALLON JERRY CANS IN POWDERCOATED HOLDERS, TRUCK BOX W/ INSIDE LIGHTS, HIDDEN HITCH TRAILER BRAKE SETUP, 8 PORT AND 4 PORT ELECTRICAL TOW PLUGS, HI LIFT JACK. EXTRAS – I ALSO HAVE A SPARE FE BLOCK AND HEADS, MISC FE ENGINE PARTS AND BRACKETS THAT GO WITH THE TRUCK. LOTS OF EXTRA PARTS.ALSO HAVE A 460 C.I. ENGINE COMPLETE IF INTERESTED. PICS AVAILABLE UPON REQUEST. I AM SELLING THE TRUCK TO FINANCE A NEW PROJECT. I AM LOOKING FOR A 66-73 EARLY BRONCO. I HAVE 12K INVESTED. I AM ASKING $4,500.00 O.B.O AND I AM WILLING TO TRADE IF THE RIGHT EB COMES ALONG. HERE IS A LINK TO SOME PICS OF MY RIG http://www.fordification.com/galleri....php?cat=10252 CTC TONY AT 559-322-8460 OR EMAIL ME AT BROKE_OKIE@HOTMAIL.COM
[B]J.P.[/B] -"HAPPINESS IS.. NOT BEING SMART ENOUGH TO KNOW WHAT TO WORRY ABOUT." |
#2 |
Member # 47169
ttt
| Sponsored Links |
#3 |
Member # 47169
O ff the market due to a pay raise. Thanks all .
[B]J.P.[/B] -"HAPPINESS IS.. NOT BEING SMART ENOUGH TO KNOW WHAT TO WORRY ABOUT." Last edited by Broke_Okie; 05-15-2006 at 08:49 PM. |
| Thread Tools | |
| Display Modes | |
