Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > Newbie General 4x4 Discussion
Old 05-17-2006, 06:28 PM   #1
800MJ
800MJ's Avatar
Member # 64089
Send a message via AIM to 800MJ
average start-truck-up-after-5-years procedure
85 bronco II carb 2.8v6. it has been 5 years since it has been driven. "started occasionaly". its a free b2 they want it out of their yard. gonna be a basic/cheap offroad funbox. so i got the basics down. drain and/or drop gas tank to clean out w/fresh gas. inspect fuel lines. somone help me on this one. obviously excessive rust is bad but what should i look for? that are warning signs of bad fuel lines? clean carb, inspect air filter/intake, replace: hoses, belts, valve cover gaskets. inspect radiator, oil pan gasket, replace fluids (brakes radiator engine tranny tcase diffs) and replace bad brake lines. i want to throw oil conditioner in for seals and such and some of the antileak stuff in the radiator when i top it all off. i already know the b2 traits. weakness' of heads and d28 and the famous ticking, ect, so lets just focus on this complete refresh after sitting 5 years. did i miss anything? thanks
Originally Posted by roastbeef View Post
last night, this girl was sucking my dick and she stated licking my balls and then she starteld likcing my ass. i almost nuttd right on top of her fucking head before i got to stick it in her.
im drunk.
Originally Posted by sucker View Post
ok straight six and reliable don't go together. But have fun with that one.
800MJ is offline   Reply With Quote
Old 05-18-2006, 01:26 PM   #2
broncobilly_69
broncobilly_69's Avatar
Member # 61468
are you sure you want to put stopleak in the radiator? If it isn't leaking I wouldn't. I've heard has a tendency to plug some of your radiator and heater core fins.
broncobilly_69 is offline   Reply With Quote
Old 05-18-2006, 05:36 PM   #3
800MJ
800MJ's Avatar
Member # 64089
well i want to do it becasue if there is almost a head gasket leak or a waterpump leak on the way it will stop it untill it can be adressed later properly. this way ill have time to drive it and adress other issues it will have and not be kept back by a leak. thanks for the warning tho. ill skimp on the amount i put in. if it does clog up then ill see it on the temp gage, and ill just flush it all out. i am assuming the clutch and main seal and all are ok hopefuly. i know there are people out there who can either tell me "dont forget..." or "yeah you got it down. you should be fine". gimme some feedback. thanks
im drunk.
Old 05-18-2006, 09:13 PM   #4
awauld
Member # 53189
Send a message via MSN to awauld
well, Berrymans in the fuel system will generally clean out the varnish, and marvel mystery oil in the cylinders, as well as in the crankcase isnt to bad of an idea
[CENTER][I][COLOR="Yellow"]"Damn the torpedoes, Full speed ahead!"[/COLOR][/I][/CENTER]
awauld is offline   Reply With Quote
Old 05-18-2006, 09:26 PM   #5
NetBSD
Member # 50360
Send a message via AIM to NetBSD Send a message via Yahoo to NetBSD
new gas, oil, antifreeze. clean the carb a little and fire it up
89 Ranger, 2.9 5 speed, 6" lift d35/8.8 swap, 315/75r16 micky baja claws
NetBSD is offline   Reply With Quote
Forum Jump
