Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 05-23-2006, 10:06 PM   #1
NORCALFJ40
NORCALFJ40's Avatar
Member # 51625
Send a message via AIM to NORCALFJ40 Send a message via Yahoo to NORCALFJ40
TPI Speed dencity. wont run in altitude?
Well I dont have this problem but... We recently swaped in a TPI 350 into a 73 landcruiser fj40, We havnt had a chance to run it in the altitde yet , but i have heard a few rumors that speed dencity doesnt like to run in the in the altitude, Due to it being a MAP instead of a MAF fuel injection? i might e way off but just wondering if any of you guys heard anthing or experenced anything like this before? BTW its a stock computer setup that i am running not a programmable one. Thanks , Kodi
NORCALFJ40 is offline   Reply With Quote
Old 05-23-2006, 10:48 PM   #2
JeepinDoug
JeepinDoug's Avatar
Member # 13028
Sounds like you're expecting the worst.
If this was the case, all MAP sensored FI set ups wouldn't work at altitude.
What's the reasoning behind this?
Vaccum pressure is comprimised when air density is lower?
If all is set up properly you should be fine, just expect a small amount of power loss at altitude.
I may lack much in way of integrety but I make up for it with pure denial.
[URL=http://www.pirate4x4.com/forum/showthread.php?t=377480][B][COLOR="Red"]Malvado Grande #1[/COLOR][/B][/URL]
JeepinDoug is offline   Reply With Quote
Old 05-23-2006, 10:55 PM   #3
Ghetto Fab.
Member # 6170
Should run just fine. The slightly lower map sensor values will lean out the mixture to compensate for altitude. My speed density fuel injection system(early jeep 4.0) does just fine at altitude(dusy ershim 10,000ft?). What do all those poor souls crossing the rockies through the eisenhower tunnel on I70 through colorado do? How high are you planning on going?
Kevo
Ghetto Fab. is offline   Reply With Quote
Old 05-23-2006, 11:01 PM   #4
NORCALFJ40
NORCALFJ40's Avatar
Member # 51625
Its set up right, runs exellent at my house at about 100 ft above sea level. I had just heard some rumord about this. i guess they are just rumors then. Thanks for the help so far
Old 05-25-2006, 12:31 AM   #5
Eagle-Mark
Web Wheeler For Hire
Eagle-Mark's Avatar
Member # 26999
I think the Mythbusters would bust this myth!
Founder North Idaho Off Roaders
Webmaster North Idaho Trail Blazers
KAT Team Member Blue ribbon Coalition
Member Idaho State 4x4 Association
Kootenai County Idaho Off Road Advisory Committee Member
Former Idaho Executive Director PNW4WDA
Eagle-Mark is offline   Reply With Quote
Old 05-25-2006, 07:23 AM   #6
Bubba_Jeep
Oldnewbie
Member # 37184
When you first turn the key on, before the engine starts, the ECM uses the MAP signal to calibrate for altitude. It's built in. No worries, mate.
Bubba_Jeep is online now   Reply With Quote
Old 05-26-2006, 11:30 AM   #7
MrWillys
Member # 9991
The only thing here that should be kept in mind though is: If you start at sea level and drive continuiously without shutting off the vehicle it will continue to adjust for sea level. I always make sure and stop at some point and shut the vehicle off and restart to allow the computer to reset. Some have said newer vehicles do compensate for this when at WOT. It's said they take a new reading at this time of no vacuum. I do know that no provisions for this exist in the early TPI ecm's.
My scanner reads 4.72 millivolts here at 400 feet, and at 10,000 feet it read around 3.9.
MrWillys is offline   Reply With Quote
Old 05-26-2006, 11:58 AM   #8
Balsax
Member # 22345
I live at around 10,000 and run a MAP TPI on my 383 without any problems...My TPI system has ran fine above treeline (about 12K') without any issues. It's much better than any carb setup as far as self adjusting for changes in altitude.
my weekend rides...
just another 1 ton CJ being towed by a '52 M-37.
Balsax is offline   Reply With Quote
Forum Jump
