Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Truck and 4Runner
Old 05-30-2006, 10:06 PM   #1
zuknstien
zuknstien's Avatar
Member # 31331
high altitude engine smoke
my 85 runner 22re smokes blue smoke at a high altitude anthing above 3500 feet it starts blowin smoke and some times it acts like its almost being flooded out? at a start up what could cause this?
2 zuk buggys
hammer #1155
zuknstien is offline   Reply With Quote
Old 05-31-2006, 07:24 AM   #2
zuknstien
zuknstien's Avatar
Member # 31331
anyone had this problem before ????
2 zuk buggys
hammer #1155
Old 05-31-2006, 08:48 AM   #3
paradisekid
weekend warrior
paradisekid's Avatar
Member # 50618
I've had the same problem with my 85 4runner in higher altitudes, but it doesn't smoke when I am in lower elevations. I am also curious to why this happens.
paradisekid is offline   Reply With Quote
Old 05-31-2006, 09:11 AM   #4
Terrys_85_Toy
RIP Bo
Terrys_85_Toy's Avatar
Member # 34022
Send a message via AIM to Terrys_85_Toy Send a message via MSN to Terrys_85_Toy
My '85 22R does the same thing. Don't know why, I've just learned to live with it.
Terry
Originally Posted by fullygruntled
PBB is mostly dumb.
Terrys_85_Toy is offline   Reply With Quote
Old 05-31-2006, 12:54 PM   #5
Coop 50
Member # 5315
Did I read somewhere the 85 fuel injection is analog and the newer ones are digital?
You would think an altitude related problem might be because it runs too rich at high altitude, air is thinner but same amount of fuel. Maybe the system is adjusting it as much as it can to run leaner, but hits the limit of adjustment beyond a certain point.
86 22R Weber carbed Toy Truck
Coop 50 is offline   Reply With Quote
Old 05-31-2006, 01:41 PM   #6
Gnarly4X
Member # 4677
At higher elevations the engine will generally run rich, which will "wash" the cylinders and combustion chambers with more fuel, this will cause a little extra "smoke" including some oil slipping past the rings into the combustion chamber and get burned. It probably happens more with high mileage engines and carb'd engines.
Gnarls.
Gnarly4X is offline   Reply With Quote
Old 05-31-2006, 01:49 PM   #7
TWOZEROFOUR
Member # 73440
Mine dose it as well, mostly decending. Im ok with it.
TWOZEROFOUR is offline   Reply With Quote
Old 05-31-2006, 01:49 PM   #8
TWOZEROFOUR
Member # 73440
Old 05-31-2006, 05:30 PM   #9
zuknstien
zuknstien's Avatar
Member # 31331
ok its somewhat normal then
2 zuk buggys
hammer #1155
Forum Jump
