Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 07-06-2006, 07:20 PM   #1
derherr65
Member # 75099
New crawl ratio.
I was doing a little theorizing...
"So that we're all on the same page:
Crawl ratio = lowest transmission ratio X transfer case ratio X differential ratio
Crawl ratio is a nice number, but if you have 29" tires instead of 53"(or vice versa) it may not mean much. For example a crawl ratio of 79 is obviously better than a crawl ratio of 43. But if that 79 ratio is on 53" tires and the 43 ratio on 29" tires then they are the same EFFECTIVE ratio! Both trucks at 3000 rpm would be doing 6mph!
This is why you need bigger gears with bigger tires, as most of you know. So, is there a better 'ratio' for crawling prowess? What are good crawling ratios with different size tires?"
And a bright soul offered the obvious solution...
"I've often wondered the same thing. It is a unitless number which doesn't mean much to me. Maybe crawl ratio per inch tire diameter would compare apple to apples. That is often a measure I have used to keep things straight in my mind. For example: 79/53 = 1.49/in or 43/29 = 1.48/in"
So, what are your crawl/inch numbers? (I'm especially interested in stock body vehicles that have done things like Moab.)
derherr65 is offline   Reply With Quote
Old 07-06-2006, 07:23 PM   #2
Hvy_Chevy
Hvy_Chevy's Avatar
Member # 14094
Send a message via AIM to Hvy_Chevy
depends on terrain, engine, auto/manual, driving style, blah, blah, blah
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote
Old 07-06-2006, 07:28 PM   #3
American
American's Avatar
Member # 12257
Send a message via AIM to American
Seriously. If you start messing with things, like tire sizes - well let's just say you'd also have to start figuring in torque, HP, torque convertor, auto/manual, driveline HP loss, etc, etc... do you want to do that? I don't.
But maybe you are on to something. I just odn't think it's as simple as a ratio/tire comparison.
'74 Scout
'00 Ram
American is offline   Reply With Quote
Old 07-06-2006, 07:30 PM   #4
kwrangln
DOUBLEWIDE ENGINEER
kwrangln's Avatar
Member # 6971
We've been down a similar road here before, here's the link.
http://www.pirate4x4.com/forum/showt...ht=crawl+ratio
I'm the "tack tack tack" welding nazi.
http://www.pirate4x4.com/forum/showp...&postcount=218
"I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside
kwrangln is offline   Reply With Quote
Old 07-06-2006, 07:40 PM   #5
vetteboy79
Pigs fly!
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
205:1, or 5.18/in by your method.
.84 ft/sec @ 1000 RPM by that other thread.
This has not yet been tested.
'94 XJ with 4.6 stroker, NV4500, NP231doubler/D300, D60/14B, 4.56s and Detroits, 38.5 Creepies, 4-link rear & 3-link w/panhard front, dual roll cages. FOA coilovers all around. bacon express
TELLICO RALLY POST #18
vetteboy79 is offline   Reply With Quote
Old 07-06-2006, 07:58 PM   #6
derherr65
Member # 75099
Good link kwrangln.
Yes, there are a ton of other factors. So my thought was if you know the ratios(ratio/inches that is) people are running sucessfully, you know about what's needed for your rig. If you have a wimpy engine, use the top third of the results. A really stout engine and you can use the bottom third.
Forum Jump
