Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Miscellaneous > General Chit-Chat
Old 07-31-2006, 12:35 AM   #1
Chopperman
Cage Fighter
Chopperman's Avatar
Member # 2634
Took some cool pics of Fordyce Lake Dam today
Shot of the outlet from on top of the dam
Pic from the center of the dam looking onto the lake
Pic of the over flow gates
I decided to hike down to the outlet and check it out. That shiat was LOUD, kind of like a jet dragster. This pic is shot from about 10-15 feet from the jet stream.
Close up of the exhaust nozzle. CRAZY
Chopperman is offline   Reply With Quote
Old 07-31-2006, 12:38 AM   #2
Richard
Book em Dano
Richard's Avatar
Member # 233
nice pics , do you have any larger ones
The Weather Is Here , Wish You Were Beautiful
Richard is online now   Reply With Quote
Old 07-31-2006, 12:40 AM   #3
Chopperman
Cage Fighter
Chopperman's Avatar
Member # 2634
They show up fine on my monitor 400 x 300 pic size
Old 07-31-2006, 12:49 AM   #4
Richard
Book em Dano
Richard's Avatar
Member # 233
I meant more like 1024x768 you pics make good wallpaper
Old 07-31-2006, 03:45 AM   #5
AthlonAJ
AthlonAJ's Avatar
Member # 10462
Damn that last one is cool. Wonder how much pressure that is?
www.AJ's Offroad Armor.com
AthlonAJ is offline   Reply With Quote
Old 07-31-2006, 08:09 AM   #6
indulf
indulf's Avatar
Member # 6156
california is a beautiful place. nice pics
"whatever doesn't kill me postpones the inevitable"
92 xj in the works, '10 mazdaspeed 3
indulf is offline   Reply With Quote
Old 07-31-2006, 09:04 AM   #7
SanDiegoCJ
Cranky Old Moderator
SanDiegoCJ's Avatar
Member # 840
Yup, lots of beautiful country here.
Originally Posted by TrueBlueXJ View Post
Ain't that the truth. Nothing destroys human intellect like a heavy dose of Christianity.
Originally Posted by Chris View Post
"Ooh bang me in my left nostril, Dave":laughing:
SanDiegoCJ is offline   Reply With Quote
Old 07-31-2006, 09:09 AM   #8
Pooge
Pooge's Avatar
Member # 30019
Send a message via AIM to Pooge
That water looks beautiful in that second picture :jealous:
[COLOR="Red"]"Your kids have all touched me, and I'm pretty sure that I've touched them."[/COLOR]
-94.5 PSD - Daily beater
-94 Impala SS - Old man pimp-mobile
Pooge is offline   Reply With Quote
Old 07-31-2006, 09:16 AM   #9
SilverZuk
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
How deep is the water (from water surface to outlet)?
For every 2.31 feet of water depth is 1 PSI.
23.1 feet = 10 PSI
231 feet = 100 PSI.
SilverZuk is online now   Reply With Quote
Old 07-31-2006, 09:19 AM   #10
SilverZuk
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
Do they not have a hydro-electric turbine on the discharge?
If not, that is a huge waste of very cheap power, even though it is only intermittent.
Old 07-31-2006, 09:29 AM   #11
Screwzer2
The Antithesis
Screwzer2's Avatar
Member # 38193
23.1 feet = 10 PSI
231 feet = 100 PSI.
No sh!t?
What do you suppose the pressure is of the Powerhouse near my place (Deer Creek Powerhouse). Here's approx. specs:
The water flows into the powerhouse from a 30" pipe from an up-stream forebay approx. 1000' higher than the powerhouse.
This 30" stream of water gets reduced to two 2" streams. (30" dia. down to two 2" dia. streams)
These in turn, blast against a couple of big-ass Pelton wheels to drive two generators about 15-20' in diameter.
Shoots a stream about 100' long from each "bay" on the output side, before its picked up again in another series of pipes and flumes which provides (western) Nevada County with their drinking water. Truckee is on its own seperate system.
Screwzer2 is online now   Reply With Quote
Old 08-01-2006, 12:25 AM   #12
Chopperman
Cage Fighter
Chopperman's Avatar
Member # 2634
pic of my junk going through the cut out
Old 08-01-2006, 05:43 AM   #13
ScottFJ40
ScottFJ40's Avatar
Member # 11268
Agreed, tat's way cool, nice pics.
"What do you mean, I ain't kind?
I'm just not your kind."
Help Mason!
Help Zach and Alec!
ScottFJ40 is offline   Reply With Quote
Old 08-01-2006, 05:54 AM   #14
Mustard Dog
Chubby Chaser
Mustard Dog's Avatar
Member # 7889
Send a message via AIM to Mustard Dog
I'd be more impressed if you posted a pic of you putting your hand in the flow from the nozzle
Eric Anderson
TIN BENDERS
Hendrix X Chassis #013
Spotter F-Toy #028 Team Marlin Crawler
KOH #66 4Wheel Parts, Raceline, Bilstein, Marlin Crawler, LightFORCE, BFG, HendriX, 12voltguy, Longfield
Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse.
Mustard Dog is offline   Reply With Quote
Old 08-01-2006, 07:03 AM   #15
SilverZuk
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
If the elevation difference between the surface of the lake and the discharge is 1000 feet, then the pressure is 432.9 PSI static. It will actually be less because friction losses in the piping.
If you have a water storage tank with an elevation of 1000, and have a 1000 miles of pipe that goes to 0' elevation, the static pressure will be 432.9 PSI. Doesn't matter if it is a large lake or a 3/4" pipe full of water, static pressure is simply elevation.
Pipe sizes and volume don't mean a thing to static pressure. The 30" reducing to a 2" doesn't increase the pressure either, all it does it cause proportion pressure loss based on the velocity of the water in the pipe and the diameter of the pipe.
So you start with 432.9 PSI, but as soon as the water starts moving pressure is lost due to friction. The pressure loss through the 30" is minimal because the larger diameter. The pressure loss through the 2" is tremendous.
In that case, they are using the 2" as an orfice plate (restrictor plate) to limit the flow.
Old 08-01-2006, 09:41 AM   #16
Turboduck01
Member # 56573
If the dam is 1000 ft high, that water is coming out at 173 mph based on Velocity = sqrt (2*gravity*height) that's definitely worth of sticking your hand out in front of it and telling us about it
Turboduck01 is offline   Reply With Quote
Forum Jump
