#1 |
Spork Wrath
Doc's new Project: 9mm AK-47
This is for the advance level build your own fucking assualt weapon students
what I am doing is building an 9mm blowback operated rifle using a suomi 9mm sub-machinegun barrel and magazines and ak-47 reciever and fire control group. The project started as a from scratch upper and using a FAL lower but it brought the suck and what was odd is at the same time I was saying "Fuck it, I will use an AK reciever" is when I saw other nutjobs doing the same thing on gunsnet.net. One person over there made my life a LOT easier but we will get to that later.Here is a rough mock up of the weapon to show what it will sorta look like when done. Please note that the barrel in the pic is just a chunk of spare AK barrel not the one to be used when its done. Components: AlohaRover AK-47 Receievr blank Romanian AK-47 front trunnion, grip,bolt carrier,Gas tube and rear sight block milled AK trigger guard Tapco G3 FCG FAL front gas block Tapco FAL picatinny dust cover (YES it will work)Suomi barrel and drum magazine AK-74 bolt Now I am making a blowback weapon so the gas portion of the AK is being kept for weight (inertia and delay) and for alignment. But the AK is a locking bolt weapon and I need a fixed bolt. TAAAADAAAAA!!!!! mill out the bolt carrier for the 74 bolt to fit in the locked position. Now the reason I am using a 74 bolt is its face diameter is 10mm so it will fit and feed a 9mm round perfect. you WILL have to sleeve it to fit the 47 carrier. here it is is the rear locked position: And side view: I also REMOVED the locking lugs inside the front trunion. first by just leaving the flats but then as I fit and finished I found I had to shorten the distance fron the barrel to the feed ramp to assure good feed. I ended up taking a good inch off the back of the trunnion. The bolt is now guided and kept in track by well...the fucking guide rails
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage. Last edited by usmcdoc14; 08-24-2006 at 05:47 PM. |
#2 |
Spork Wrath
Now you can go and cut up an old soumi magazine well OR
you can cheat and use this guys' http://www.lichtenbergresearch.com/index.html His shit is pimp and very well made and has a feed ramp built in. and If you slide his right up to the bottom of the guide rails it is a perfect fit and feed Now here is the distance from the magazine to the barrel position Now I kept the side part of the trunnion as it will be part of my bolt block that will act as a stop for the forward movement of the bolt and assure correct headspacing and not wear the bolt face. Here is the veiw from the magwell to the ejector And this is how much the trunnion is moved BACK !! so YES I will have to cut down the bolt the firing pin and the recoil spring. Now for something neat I had a spare Tapco FAL rail cover and was mocking it near the ak and found that if I add side dust "skirts" it is a FAWKING PERFECT FIT !! So it will have a full rail and will hinge off where the old rear sight used to be. it mates perfectly so it will hinge on the front and have a solid mount on the rear. The recoil spring will NOT touch the dust cover. And once I find some cheap STEEL picatinny rails I will chop the FAL front gas block and run rail on that AND the gas tube and use AR flip up sights that will co-witness with an EO Tech
When it absolutely, positively needs to be made from random crap found in the back of my garage. |
| Sponsored Links |
#3 |
Genuine Dickhead
That is what I would call "Frankensubgun". It just screams out, "BETCHA CAN'T WAIT TO SEE ME BLOW UP!", though I am confident enough in your work to know it won't.
Fawking sweeeeeet.
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an 'unlicensed pharmacist' Molon Labe, motherfuckers. |
#4 |
I've got a spare AK receiver and a suomi parts kit just collecting dust...
so once you get yours finished I might have to copy it
I make stuff. |
#5 |
Member # 10632
Holy shit Doc, you are definitely to the PhD level of "gunfuckery". I hope the thing works out for ya! I got to shoot a real (FA) AK a couple weeks ago, it was ok but my semi AK pistol is just as much fun, bumping a 75 rd drum rocks.
#6 | |
I make guns
Member # 14561
Colorado Springs FFL-07/SOT
The Front Range Anti-Zombi Specialist Custom Rifles and Class-II/III EvilBlackRifleShop.com Inventory Reduction Sale I am selling off inventory, but I still sell/make a wide range of EBR parts, accessories, and fully functioning firearms. So PM for quotes. New Guns On Gun Broker "You worry too much, eat more Bacon!" Last edited by aloharover; 08-25-2006 at 06:11 AM. |
#7 | |
I make guns
Member # 14561
The Front Range Anti-Zombi Specialist Custom Rifles and Class-II/III EvilBlackRifleShop.com Inventory Reduction Sale I am selling off inventory, but I still sell/make a wide range of EBR parts, accessories, and fully functioning firearms. So PM for quotes. New Guns On Gun Broker "You worry too much, eat more Bacon!" |
#8 |
Hop Head
Just curious, how does the chubby jesus-lover roommate react when she comes home and finds you sitting at the coffee table with evil black gun parts spread all over, deathmetal cranked on the stereo and porn on the computer screen?
#9 | |
Perfect examples of why I'm single..
I make stuff. Last edited by animator; 08-25-2006 at 07:49 AM. |
#10 |
Member # 5829
Wow - that's some hard-core weapon fab shit right there, man.
So much for interchangeable parts! I'd love to see a vid when you get it working
If you are reading this, YOU are the Resistance - |
#11 | ||
Spork Wrath
dammit, no emotional truma
#12 | |
Spork Wrath
#13 |
OSRSW ?????
I was looking the same direction a couple weeks ago...I love the suomi shroud and comp...
4.3runner ---A golf course is a pointless exploitation of a perfectly good rifle range--- buy my ultra rare Omega III presentation rifle special price $47500.00 |
#14 |
OSRSW ?????
oh yeah, the comp...
#15 |
OSRSW ?????
or you could get sidetracked...
#16 | |
Spork Wrath
I too love that barrel shroud but that fucker is HEAVY !! so I decieded to slim that heavy pig down a bit.
#17 |
Everyday is Tuesday.
Member # 47
questions:
a. legality? paperwork necessary? b. are you using anything more precise than a Dremel for your 'machine work'? |
#18 |
Member # 10632
One funny coincidence is that a good friend of mine just bought a 9mm AK. I have no idea what pieces or parts are in it, but if you'd like some pics for comparison purposes I'm sure he won't mind.
#19 | |
Spork Wrath
but to save you that time in its cliff note form = yes legal, no papers needed. b) is there anything more precise ? yes dremel the only machine work that has to be balls on is the barrel and the headspacing. everything else in an AK can be "off" and work just fine...ok it can be bent in an arch and still work Like I said, I am sitting on the living room floor and doing this build
#20 | |
Spork Wrath
#21 | |
Member # 10632
#22 |
Member # 64421
ugh, I hate loading sten mags
Paper is a mortgage on wealth that does not exist, backed by a gun aimed at those who are expected to produce it. |
#23 | |
Spork Wrath
I need to get some soumi stick magazines too
#24 | |
Spork Wrath
open magazine rotate center thing to the level you want to load fill with rounds place cover on lock cover thats it
#25 |
Member # 64421
yup, easy like a chicom AK drum, great stuff. once I get my PPS-43/AKM hybrid done I'm definitely doing one of these, soumi drums just rock.
| Thread Tools | |
| Display Modes | |
