#1 |
Member # 10977
FS: 1989 Jeep Wrangler Walkabout
1989 Jeep Wrangler “Walkabout”
Location: Spring, TX (NW Houston) Pics: http://photos.yahoo.com/grinch_champion Background: Time to sell! I built this Jeep while in college, it was also my daily driver; I graduated and priorities changed. I am the original owner. The “Walkabout” has been GARAGE KEPT for the past 4 years, started once a week. I swapped in the front axle right before having to abandon the project—the Jeep is drivable and is street legal (registration/inspection sticker is expired). This Jeep has been taken care of VERY WELL!! There are few odd/ends that should be tied up, but very minimal work: * Rear axle needs to be re-geared to 5:13s (front drive shaft is removed, but is included) * Front drive shaft probably needs to be shortened ~1.5” * Front shock mounts may need to be lowered or shorter shocks installed. A very small list of items to attend that probably can be completed in a weekend. In addition to the Jeep, you will receive LOTS of extras (see list below), including a ready-to install DOM roll cage. Please contact me via email: grinch@houston.rr.com or cell, 832-541-1070-- ask for John Asking Price: $7500 Extra Items Included with Jeep: Tennessee Off-Road TOR weld-in roll cage: * TWO front hoops * 4 spreaders * 1 Dash spreader * Rear hoop speader * 1.75” DOM tubing * Pre-notched, ready to install * Grab handles and gussets M.O.R.E. Frame Tie-in Kit with poly bushings Two additional wheels, matching rear American Eagle Rims; aluminum alloy Two extra pairs-4 total- of driver and passenger windows; Beige and Black HD Hi-Lift Jack Full-size Jeep cloth cover 5x Original Steel Jeep Wheels 4x Hoosier 255x75R15 Tires; Virtually new, ~5000 total miles—mounted on Jeep wheels 1x OEM Jeep Spare Tire Front OEM driveshaft Drive train: ~70k original miles Fuel Injected 2.5L 4 Cylinder AX5 Manual Transmission NP231 Transfer case (w/Slip Yoke Eliminator) HD CV Joint Driveshaft Front Axle: Dana 44 (From ’80 Jeep Wagoneer) Full Detroit Locker 5:13 Yukon Gears Disc Brakes Warn Premium Hubs High Steer Flat Top knuckles Shaker Built High Steer Arms 1-Ton HD TREs HD DOM Tie-rod/draglink 6-lug Timken Bearings Gears/Locker professionally installed Completely rebuilt myself (except gear install)—brand new seals, bearings, brakes/pads, ball joints, and rotors Less than 10 total miles on this axle, super clean! Rear Axle: Ford 8.8” (From ’98 Ford Explorer) 31 Spline Disc Brakes 4:56 Yukon Gears Full Detroit Locker Gears/Locker professionally installed 5x4.5” lug TA Performance HD Diff Cover w/carrier pre-load (VERY NICE) E-brake installed and working Custom formed rear brake lines Axle was professionally rebuilt w/new bearings, seals, brakes/pads, gears. Total of ~5k miles on this axle. Very good shape (didn’t see off-road very much) Suspension: 2.5” Old Man Emu Leaf Springs (medium) Spring over Axle (Total 6.5” suspension lift) 1” Body Lift 1” Motor Mount Lift (w/polyurethane bushings) Custom Rear shock mounts Rancho 9000 Adjustable Shocks - Front Bilstein 7100 Shocks (Remote Reservoir) - Rear M.O.R.E. Anti-kickback shackles (front) 33” TSL Swampers (can fit much bigger) American Racing Steel Wheels (2) - Front American Eagle Alloy Rims (2) - Rear Misc: Off-your rocker HD quarter panels Flush Tail lights Integrated license plate lights York On Board Air (plumbed—pressure switch/check valve/blow off valve, etc; access front and rear) – runs power tools no problem. Factory installed AC (Yes, there is a York and Sanden compressor under the hood) Bulletproof Bumper w/integrated 5gal air tank (VERY stout) and tow hitch Ramsey 9000 Platinum Winch (w/Remote) KC Stainless Steel Daylighters Steel Horse Console Insta-trunk Mounted Hi-lift jack K&N Air Filter Chrome Grill Fire Extinguisher New Valve cover Water pump replaced < 1000 miles ago Engine is in great shape Immboilizer Anti-theft 4x6 Blaupunkt Speakers No RUST!! Body: Body is in good shape—paint is still holding up. Passenger side fender slightly damaged Passenger rocker has light damage Last edited by thegrinch; 09-07-2006 at 06:47 PM. |
#2 |
Member # 10977
Bump!
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
