Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Chevy
Old 11-01-2006, 06:25 PM   #1
VividVisions
Member # 81721
Q's on swapping TH-400 with 700R4
my current setup is '86 3/4 chevy 350 TH-400/208tcase
My trans is junk it doesn't move anymore, i want to go overdrive, the main use of the truck is to tow my sandrail to my cabin (200 miles) 90% of the way is highway. my question is do i have to get a different adapter?? what year transmission do i gotta get?? i heard there are diffrent spline output shafts?? do i have to do something to the t-case?? Nothern autoparts have a kit to make the lock up work for $130, is that a good deal?? any help would be appreciated, thanks
V.V.
VividVisions is offline   Reply With Quote
Old 11-02-2006, 06:50 AM   #2
millerxc
Member # 27762
700s have a 28 spline output, 400s use 32, so you need different input gear for tcase and different adapter, length is real close so drivelines are probably gonna be Ok, good luck making a 700 last for towing, get a good warranty??
millerxc is offline   Reply With Quote
Old 11-02-2006, 07:44 AM   #3
Bo185
Vortec 6.0L Scout II
Bo185's Avatar
Member # 48545
Actually you mean 27 spline output shaft!
It will last for towing if you final drive gears are good and keep up with maint. and get a good cooler. And towing in OD is ok if it's pretty flat. I got 175,000 miles on mine with alot of towing and the guy I bought the truck from towed a hugh camper with it for 75,000 of those miles.
'73 Scout II Vortec 6.0L 4L65e np241
'01 VW Beetle TDI-50mpg or better!
GM Gen III/IV V8 swap info
Bo185 is offline   Reply With Quote
Old 11-02-2006, 05:38 PM   #4
VividVisions
Member # 81721
any idea where to find an input shaft??
Old 11-02-2006, 07:03 PM   #5
imiceman44
Member # 17568
I have a 27 spline input shaft if you need one.
You will also need a different adapter, the th400 adapter is 6 bolt round pattern, the 700R4 is a 4 bolt.
I might have that one as well.
Send me a Private message if you are interested in either of these parts.
IceMan
imiceman44 is offline   Reply With Quote
Forum Jump
