Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Ford
Old 11-21-2006, 10:09 AM   #1
craigellis77
Member # 31763
EB High-Clearance winch mount????
My EB has an 8274 mounted on the same tree pushing JBG bumper that came on the Bronco when I bought it. It sticks out way too far and I constantly hang up because of the bumper and have to back up.
I'd like to see pics or hear ideas for a winch mount/ bumper that moves the winch up and maybe provides for the possibility of sliding over rocks instead of hanging on them. Does anyone have advice?
I'll post pics of my EB after I leave work today.
craigellis77 is offline   Reply With Quote
Old 11-21-2006, 12:38 PM   #2
68crawler
Member # 38845
I've got the 8274 too and I built my own front bumper with all of those things in mind. I wanted a good approach angle and didn't want it hanging down too low. I made it out of some 2x8 rectangle tubing. It might not be the best design, but it was easy to make and functional. Here are some pics.
68crawler is offline   Reply With Quote
Old 11-21-2006, 02:15 PM   #3
welndmn
Well Done Man!
welndmn's Avatar
Member # 398
Send a message via ICQ to welndmn Send a message via AIM to welndmn Send a message via Yahoo to welndmn
Cut a hole in the grill and cut the frame horns off, push it back until it hits the radiator
Mark
71 Bronco. 42's and bolt on goats.
welndmn is offline   Reply With Quote
Old 11-21-2006, 02:41 PM   #4
wheelin66bronco
wheelin66bronco's Avatar
Member # 44308
Better yet, cut a hole in the grill, put the radiator in the back and put the winch all the way up to the fan. That's the direction I'm going
66 EB, SEFI 351W, C6, Atlas, D60's, Full Hydro, Linked, C/O front, Narrowed F&R, forty duces.
05 Dodge Smoker
Originally Posted by Buckon37s View Post
Related question:
Can you use DOM to poop in? Will that work? Anybody done it?
wheelin66bronco is offline   Reply With Quote
Old 11-21-2006, 02:49 PM   #5
BroncoShawn
Member # 82395
I like the 2x8 tube ideal
BroncoShawn is offline   Reply With Quote
Old 11-21-2006, 08:35 PM   #6
craigellis77
Member # 31763
thanks for the replies so far guys- 68crawler that's like something i'm thinking of building...here's what i'm working with:
http://i4.photobucket.com/albums/y13...s/IMG_0834.jpg
Old 11-21-2006, 08:36 PM   #7
craigellis77
Member # 31763
Old 11-22-2006, 07:36 AM   #8
Gummi Bear
Member # 26216
Send a message via Yahoo to Gummi Bear
If you don't/can't fab one, American Bronco offers a bumper that lowers the winch cradle quite a bit, and is a high clearance bumper.
http://www.americanbronco.com/index.html
[SIZE=2][b]His - [COLOR="DarkOrange"][o===o][/COLOR] 1976 Bronco
Hers - [url=http://classicbroncos.com/forums/showthread.php?t=81955][color="DeepSkyBlue"][[/color]o[color="DeepSkyBlue"]===[/color]o[color="DeepSkyBlue"]][/color] 1968 Bronco "Doodlebug"[/b][/SIZE][/url]
[SIZE="1"] [URL="http://www.lonestar-ebc.com/LEBCPortal.asp"]Lonestar Early Bronco Club[/URL][/SIZE][SIZE="4"]
[URL]http://www.endeavorbaja.com[/URL][COLOR="DarkOrange"]
[CENTER][URL="www.reidracing.biz"][B]Reid Racing, Inc. - Dedenbear Products [/B] [/URL] [/COLOR] (925) 935-3025 [/CENTER][/SIZE]
Gummi Bear is offline   Reply With Quote
Old 11-22-2006, 02:24 PM   #9
Dusty
Token Bronco Guy
Dusty's Avatar
Member # 16474
Why would you still have the fan there if you're moving the radiator to the back?
Dusty Sharp
Poison Spyder Customs
951-849-5911
Connect with us on:
Facebook / Myspace / Twitter
Dusty is online now   Reply With Quote
Old 11-22-2006, 03:04 PM   #10
wheelin66bronco
Member # 44308
OK Smart Guy, you got me! Put it all the way back to the fan PULLEY. Better?
05 Dodge Smoker
Related question:
Old 11-22-2006, 09:52 PM   #11
Rockit
Rockit's Avatar
Member # 6052
To help keep the winch cool!!
'73 Bronco
Work in progress.
Rockit is offline   Reply With Quote
Old 11-24-2006, 08:30 PM   #12
craigellis77
Member # 31763
Gummi Bear, something like that would work too, but I'll be building it myself. I don't think anyone makes a bumper for a bronco that has 18" taken out of the grill. The 2x8 idea seems like a good idea right now.
Old 11-24-2006, 08:34 PM   #13
craigellis77
Member # 31763
68crawler, I do like your design, but I want to raise my winch and build a slider. Do you use your bumper to slide over rocks?
Old 11-25-2006, 12:26 AM   #14
68crawler
Member # 38845
Yeah I've used it as a slide a couple of times. I put a skid plate under the bumper that follows the angle of the bumper down under the the frame (if that makes sense) You can kind of see it in my last pic. So if I drive up to something steep, the bumper will slide up/over the rock.
Old 11-26-2006, 08:28 PM   #15
Jmaples
Newbie
Member # 50781
My Bumper
I have a low profile winch, but it could be easily adapted.
Jmaples is offline   Reply With Quote
Old 11-27-2006, 02:17 PM   #16
Gummi Bear
Member # 26216
One other thing you could do is adapt a bumper like I did for my rig. I've got a TJ front bumper on there, that has 2x4 brackets welded into it, and it bolts to my frame. I plan to bob the bottom corners off of my grille when I push the front axle forward, so it won't look quite as out of place then. It's 47" wide, and at no point is it below the bottom of the framerail. I keep it touched up. Both my wife and I have bonked it pretty hard on the trails. It was designed by a friend of mine, and put together by another buddy. He's got a few left over. They're not too tough to adapt to fit on the EB.
I'm hoping that since Yahoo reorganized, I can hotlink this pic. If not, it's in this album:
http://new.photos.yahoo.com/rockhopp...60762349901362
Old 11-30-2006, 02:07 PM   #17
craigellis77
Member # 31763
Yeah, mine isn't lower than the framerail, but it sticks out at least a foot from the grill. just trying to get something up higher than the bottom of the grill with the lowest part of the bumper angling down to the bottom of the frame.
Forum Jump
