Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Truck and 4Runner
Old 11-26-2006, 01:52 PM   #1
crazycuda
Member # 70257
'85 Xcab DD bed-build
first Toy, first post in Toy section. had jeeps for a long time. making this into a winter runner, daily driver.
just look at the rust. this rig is in "good shape" for the salt bath i live in.
i laugh when i see desert people say thier shit is rusty because it turned a bit orange. this rig was worth about $1500 in my used market, just because it wasn't broken/rusted in half. just close to it.
the start:
rotten bed. i got this far by hand.
how rotten will it be? nice shackle angles too
had to remove the entire inner frame wall to the cab, both sides. including crossmembers/gas mount/middle crossmember under the cab.
frame repaired:
simple crossmember and shock mount
prep for ubolt flip
now there is something to "start" with. keep in mind this thing won't see over 35's. 33's for immediate future. well aware it would be tinfoil with big running gear and rubber. thx for looking.
crazycuda is offline   Reply With Quote
Old 11-26-2006, 02:01 PM   #2
crazycuda
Member # 70257
generic bumper from under the patio.
built one of those "gottrikes" benders. (this post is not running in real time!)
1.5" sch.40 pipe die.
flatdeck frame. want a usable area back here for, well, "pickup" duties.
buying steel and axles with a car sucks. need this little rig to build more jeeps.
Old 11-26-2006, 02:03 PM   #3
crazycuda
Member # 70257
tube work starting. my first time. go easy.
Old 11-26-2006, 02:06 PM   #4
FullsizeYota
Member # 24876
looks good so far..... keep it up!
just outta curiousity, how much did it cost you to make the bender? i have been looking at the plans, it seems ok, but am still a little skeptical
[COLOR="Lime"]'85 Toyota ext cab. 4 cyl. 5.29s. Chromoly birfs. dual cases. hi-steer. OBA. front ARB. rear welded. cage.[/COLOR]
FullsizeYota is offline   Reply With Quote
Old 11-26-2006, 02:10 PM   #5
lilredrover
Member # 69077
looks good so far, picked up an 83 project that looks very similar, except my frame isn't rotting at all, at least not that I've found (knocking on wood with fingers crossed)
lilredrover is offline   Reply With Quote
Old 11-26-2006, 02:16 PM   #6
crazycuda
Member # 70257
bender cost about $200 for material. i do my own machine work, and had the die already. for me living in Canada, the cost is well below getting a protools or jd2 across the border (brokerage fees) and shipping on 200lbs.
the vertical bending is tits, way less room in the shop needed. but if i was in the states, it would have been easier to just buy one of the commercially avail. ones. can't beat that vertical bend tho. winter is coming! nice to keep the truck in the shop.
Old 11-26-2006, 02:35 PM   #7
BRAD D
Member # 61487
Thanks for the idea dude, Im building one as well, and do not want to drill holes in the tube for the feet.. I will just weld on some of those long nuts.
Truck is looking good
BRAD D is offline   Reply With Quote
Old 11-26-2006, 03:57 PM   #8
Burkeee
Member # 42997
Don't forget to plate the legs of those sliders for those Burnside boulders!
Burkeee is offline   Reply With Quote
Old 11-26-2006, 04:03 PM   #9
Booger Weldz
chicken fucker
Booger Weldz's Avatar
Member # 2931
nice work! got any info on the bender? does it accept protools dyes?
http://www.diamondaxle.com
http://www.F-O-A.com
http://www.12voltguy.com
http://www.addictedoffroad.com
wanted: (2) 12''x3''x250# coilover springs
2002 diamond axled coilover/linked tacoma v6 4door rock taxi with dual cases and beadlocked 37s
Booger Weldz is offline   Reply With Quote
Old 11-26-2006, 04:14 PM   #10
BRAD D
Member # 61487
Yes it uses protool dies
http://www.pirate4x4.com/forum/showthread.php?t=376183
Old 11-26-2006, 05:46 PM   #11
jdrocks
Member # 16719
may be a "salt bath" but it's a beautiful spot-been there. i have seen worse frames believe it or not. nice build. blast, prime, paint before you cover everything up. do folks still fill the frame rails with drain oil up there?
jdrocks is offline   Reply With Quote
Old 11-26-2006, 08:14 PM   #12
crazycuda
Member # 70257
the bender plans are for a protools die. i changed it to use a jd2.
Forum Jump
