Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Land Rover
Old 11-27-2006, 12:36 AM   #1
ferdinand
Member # 82917
holey bushings?
so i was looking through the archives and read some posts about bushings with holes drilled through them for extra flex. how have they turned out? any durability issues?
i'm sure that this topic has been discussed but i couldn't find a thread and honestly, i'm still a bit too cheep to get a star. lame, i know.
thanks for answering something that may have been answered already.
andy
ferdinand is offline   Reply With Quote
Old 11-27-2006, 01:23 AM   #2
wilsby
Member # 17053
Yes, they work.
Yes, they wear fast.
Try to get hold of Sam's holey bushes that are cast with oblong holes in the rubber. Find him here or on the Outerlimits board.
Christer Wilsby
Range Rover 4.6 Vogue 2001 - still shiny
Defender 110 CSW Td5 2001 - expedition/radical family wheeling
Suzuki LJ80 1982 - "Standard" trialer
Volvo C304/Tgb 13 6X6, portals, on 35" - stocker
"Grammar is the body language of the internet."
The Pendy
wilsby is offline   Reply With Quote
Old 11-27-2006, 03:33 AM   #3
Agrover
Member # 68649
It seems to me that holey bushings remove rubber in exactly the same area that rubber is required to resist drive and braking forces No ?
Agrover is offline   Reply With Quote
Old 11-27-2006, 03:48 AM   #4
wilsby
Member # 17053
Not really. When they are new, they are fine. When worn - terrible. All the rubber front and rear is left intact. The purpose is to remove some of the anti roll bar effect of the radius arms.
Christer Wilsby
The Pendy
Old 11-27-2006, 02:38 PM   #5
SeaRover
Member # 9817
andy, welcome to pirate
i tried to get my hands on a set of holey bushings but wasn't persistent enough, apparenty. They're difficult to obtain, I don't think Sam ever found a distribution point stateside that he was happy with ... unless someone got a stash of 'em around here and didn't tell anybody.
jeeps gone. Rangie in 2010 :smokin:
SeaRover is offline   Reply With Quote
Old 11-27-2006, 02:53 PM   #6
ferdinand
Member # 82917
well thank you isaac
i remember we talked about it a little but then it slipped my mind. thought i'd check in here. seemed like such a cool idea...
Old 11-27-2006, 03:06 PM   #7
DiscoDino
DiscoDino's Avatar
Member # 15296
Don't Scrap Iron have a copy of these in ORANGE?
'92 Land Rover Disco truggy:
Beadlocked 42" Iroks, V8, ZF, dual cases, ARBs, Longfielded, M8274-50s with ropes, etc...
'98 Land Rover Discovery:
29" BFG ATs
'02 D90 TD5 ST:
33" BFG ATs
'08 BMW 328i:
64" Wife
'07 BMW G650X Challange:
Interco Terraflex 29" rear tire
DiscoDino is offline   Reply With Quote
Old 11-27-2006, 03:42 PM   #8
ferdinand
Member # 82917
thanks again for the info. maybe i'll attempt to replicate them myself as i'm sure the stock bushings that are on my truck are on their way out...
ike-sorry for the overly hostile smiley! didn't realize you piraters had two flipoff icons.
a
Old 11-27-2006, 04:06 PM   #9
SeaRover
Member # 9817
a
fawking newbie
with flogged out bushings i could max out 10" shocks, which were mounted with about 35% uptravel, and the rest all down. didn't need the drill. unless you're going to look into 3-linking the front ... keep the rear suspension fairly stock and run longer shocks on the front. when the rear maxes out it'll force the front to work harder to compensate.
most people do the opposite, installing longer shocks in the rear to take advantage of the factory 3-link on the older trucks, and then complain about the front end being stiff. it's not true! if you let the rear drop-out with no resistance, the front-end has to be really flexy to see much articulation.
Old 11-27-2006, 09:38 PM   #10
ferdinand
Member # 82917
Originally Posted by SeaRover
fawking newbie
what do you expect? getting the rear to work hard is easier, maybe that's why most people work that way. if craig's new heim joints hold out on his blingsteins, maybe i'll go that route.
andy
Old 11-28-2006, 08:26 AM   #11
Johnny5
Member # 27926
Yes they do, right now Mike H. (D-90) has a set and will be testing them on his D90. Larry G has a set of Sam's slotted bushings on his truck and should have some results for us pretty soon.
John C.
Johnny5 is offline   Reply With Quote
Old 11-28-2006, 11:37 PM   #12
Agrover
Member # 68649
The bushings would need to be fitted with all 3 holes concentric with the axle shafts to allow the axle housing to roll for and aft more freely during articulation. To my way of thinking this introduces an undesirable characteristic of the diff pinion toggling up higher during heavy braking, reducing castor angle which would cause instability, particularly on lifted vehicles without castor correction. The pinion would also toggle down further with drive loads, and when the front end is scrabbling for traction I feel axle hop would be exaggerated with the the pinion toggling from one exteme to the other. Any counter arguments welcome.
bill.
Old 11-29-2006, 12:29 AM   #13
tobbjo
Member # 15924
I've seen the effect you are describing, Bill.
On Wilsby's 110, while struggling to get out of a mud hole, later named "Wilsby's ditch", for this feat.
As a side story it was the way it was because the army used theese grounds for training their drivers on the 6x6 Volvo portals, with snow chains.
A fully locked 4 ton 6x6 portal rig on 35" + HD Snow chaings dig some serious ditches.
Anyway, Wilsby was running drilled or Sam's bushings at the time and was powering pretty heavily to get over the undercut ledge at the end of the ditch. The pinions yawing could be clearly seen. Might even be a video of it somewhere.
T
www.hotchallenge.se
"Road salt is like the automotive equivalent of chain smoking unfiltereds and guzzling Jack Daniels...might make ya feel good for awhile, but there's shit going on inside that you don't want to see." ProsQtor
tobbjo is offline   Reply With Quote
Old 11-29-2006, 01:51 AM   #14
wilsby
Member # 17053
These are also the grounds where I broke my only AEU2522, but that is another story.
It is a tradeoff, and the holey bushes are acceptable when fresh. They allow my front axle to articulate the full stroke of my 12" Blingensteins with stock radius arms, poly at the frame end and fairly stiff King Springs. The rear is on 14" shocks, so the whole thing is fairly compliant. At close to 3 tons, is still jumps gracefully in the sand, as seen on one of Tobias' video clips.
I did a registration inspection with winch and full exo cage two years ago, and one of the guys was fascinated by the agile front pinion when braking in the inspection hall. I have changed bushings since...
On road behaviour gets interesting if you allow anything to wear on this rig, but if you keep everyting up to snuff, it is quite driveable. I plan to take the family on a Sweden- Morocco-Sweden trip with it in a year or two, but that may say more about us than the truck.
Christer Wilsby
The Pendy
Old 11-29-2006, 12:03 PM   #15
SeaRover
Member # 9817
andy
they won't. heims and 4-season road-use do not mix. we've talked about it a few times. when i ran these on gatsby, the only road use it saw was getting to the trail-head so i didn't really care. if you want to keep a "mixed-use" purpose for your rig, skip the bling and just fit some OME's.
Old 11-30-2006, 12:57 AM   #16
ferdinand
Member # 82917
i still think we should cut off the heims and install regular mounts on the ends. since they're all rebuildable and what not, we could just remove the shafts if craig gets concerned about the two of us working on it that way there's no chance we'll bugger up that one shock...
in all seriousness, i would have a pro do the work but i think it's doable, and worth it if it works.
andy
oh, and thanks for all the updates in the bushings and their performance.
Old 12-05-2006, 05:12 AM   #17
Strange Rover
Member # 7962
Hey.......great to see this stuff still gets kicked around!!!
So an update - yes we still get them made, yes they increase articulation, yes they wear out and yes they are very hard to get hold of if you dont live in Australia.
Aaaah - those were good times.
Was actually in the US last month....could have brought some over with me.
http://www.we-rock.cc/comps/06_artic..._postwrite.php
Sam
Land Rover SIIa, 302W, NP435, NP205, MOG404s, 42in Swamper TSLs, 112in WB
"An expert is somebody who learns more and more about less and less until one day they know absolutely everything about nothing."
Outerlimits4x4.com - home of aussie rock crawling.
Strange Rover is offline   Reply With Quote
Old 12-11-2006, 03:19 PM   #18
wilsby
Member # 17053
I spoke to Bilstein the other day. When I told their lifted truck expert that my heims on 7100's died young, he suggested I use Protane bushings as a replacement for the heims. Available from Buglist, and possibly others.
Christer Wilsby
The Pendy
Forum Jump
