#1 |
Member # 82410
Angled lower arms on a 4-link?
Do I really need angled lower arms on a 4-link, because of rearsteer? And if yes how much? The upper arms got a (2x20`) 40 degree angle.Thanks
#2 | |
| Sponsored Links |
#3 |
Member # 66873
i think that is supose to be degrees.
I wanted it, I built it, Home use or not, I don't care, it's bad ass. 92 Chevy, tubed front and rear, boat sides, sitting on rockwells. Link to my build http://www.pirate4x4.com/forum/showthread.php?t=568414 |
#4 |
Member # 82410
Yes, that`s degrees....
#5 |
well the more triangulated they are then the less chance they will interfere with your rear steer. I don't have rear steer but I have about 22 degrees of triangulation on my lowers, and 35 degrees on the uppers. I think that 40 degrees on the uppers allows you to pretty much do whatever you want on the lowers, even put them straight if you wanted.
#6 | |
The mountains are calling and I must go. -John Muir |
#7 |
Member # 38200
If the lowers are not triangulated they have to be nearly parallel to the ground to avoid flex steer. That probably means low hanging frame mounts, or high axle mounts.
To get technical, you want the intersection point of the lower links to be near the same height as the intersection of the upper links. If the lowers are not triangulated the intersection is at infinity, so your roll axis is parallel to the lower links. The farther the lowers are from horizontal, the more roll steer the suspension has. Triangulating the lowers allows them to be at an angle from horizontal while keeping minimum roll steer. Last edited by Quick & Dirty; 12-04-2006 at 03:21 PM. |
#8 |
Member # 82410
Thanks for all the replys...I think it saves my some trouble if I put the lower arms angled as well.
| Thread Tools | |
| Display Modes | |
