Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Jeep - Hardcore Tech
Old 12-22-2006, 07:28 PM   #1
currupt4130
Member # 39371
Send a message via AIM to currupt4130
Built a new skid plate
It's about time for a new one, I took the old one off to fix where the traction bar ripped a chunk out of it, and it was under so much tension it popped out an inch after I took the last bolt out of the first side.
So anyway. Built a new one. It's 3/16 plate (mainly, some 10g in there) has a one inch drop in the center thats four inches wide, and goes back up to the frame rail on each end. It has a nice little tranny gaurd, to help keep from cracking my massive case... not that thats gonna happen, I've sat the whole Jeep on it all four wheels off the ground at Paragon.
Sorry the pics are so blurry, I'm gonna draw it up in Solidworks just for fun, I'll post that too and I'll take better pictures when its entirely done. I still have to add little pieces of pipe to surround the bolt heads, make a new mount for the traction bar, and I'm gonna brace it back to the frame with some tube and plate, it'll be super stout when its enitrely done.
Flat view, no tranny gaurd yet
With tranny gaurd
Back driver corner view
Close up of the tranny gaurd
Bad picture, but this is the passenger side where I left it open for the fill plug on the tranny.
The mountains are calling and I must go.
-John Muir
currupt4130 is offline   Reply With Quote
Old 12-22-2006, 11:15 PM   #2
smurison14
Member # 82861
im thinkin of drawin up some parts for my Tj and was wondering how is solidworks? im either going to use that or american inventor
2002 Jeep TJ, Ford 8.8, Clayton Rear suspension, 4" stretch, Build-up Coming Soon
smurison14 is offline   Reply With Quote
Old 12-23-2006, 03:57 AM   #3
currupt4130
Member # 39371
Solidworks isn't bad, I like it a lot. I also use AutoDesk's Inventor, they both have their pros and cons.
-John Muir
Old 12-23-2006, 09:18 AM   #4
willysworker
willysworker's Avatar
Member # 23409
Nice job. I had the same notion. But I let mine hang down a little.
Because of boxed frame I had to mount inside frame rails. I welded a pillow block with captured 5/8" nut on rail. Skid plate has corresponding block with 3/4" hole for 5/8" bolt. 4 bolts and it's on.
[url]http://www.cardomain.com/ride/2451568[/url]
[url]http://www.cardomain.com/ride/2174452[/url]
willysworker is offline   Reply With Quote
Forum Jump
