#1 |
CU$TOM ROCK CRAWLIN
2007 Twizted Fab Buggy on 49"s
Brand new Rock Buggy Built By Twizted Fabrication. The Buggy and all components are either brand new or remanufactured, and has never been operated off road, and was just finished being built. Everything is profesionally painted or polished show quality. Motor and components have only 3-4 hours of break-in time on them. This rig is 100% Turn-Key and is ready to take on the 2007 Wheeling season.
A fully balanced and blueprinted fuel injected Chevy 383 stroker, with Tuned Port Injection provides 540+ Hp, and is screaming fast. Behind the engine is a Sm465 Transmission with a Np203 & Np205 Transfercase Doubler(4:1) Providing a bullet proof drivetrain, and a 166:1 crawl ratio. Also the triple stick transfercase gives you shift ratio's from crawl low to freeway speeds. This rig also has front and rear hydro steering which lets you have ultimate steering control, from crab walking to turning on a dime. This rig will conquer any obstacle you can find, and is built to take abuse If You Have Any Questions Call Cody At 925-339-6035 Or pm Rig Is ready to be deliverd or picked up ASAP Will Deliver in Continental US For A negotiated Price, before end of auction Major products used in the fabrication of this buggy- Engine- SBC 383 Stroker Fully Balanced and Blueprinted short block Speed Pro Forged Aluminum Pistons 10:1 Cr Lt1 Hardened Rods All ARP Bolts and Studs PBM Striker Aluminum Race Heads(200cc 64cc) Proform Roller Rockers Comp Cam Pushrods Comp Cam Triple Spring Kit Stainless Valves 2.02 1.64 Elign Pro Stock Cam 2000-6000 Rpms Aluminum Water Pump All Chrome Pulleys Hedman Headers Flow Master 40 series Muffler MSD 8.5 mm Plug Wires Accel Shorty Plugs All Felpro Gaskets Used Fuel Injection- Tuned Port Injection MAF style Edelbrock Highflow Manifold Fully Polished Pleneum and Runners BBK 58mm Throttle Body Gardelli High Flow MAF Sensor MSD Blaster Coil Accel 30 Lb Hr Injectors Custom Burned Computer chip By Harris Performance Adjustable Fuel Pressure Regulator Mallory Competition Fuel Pump Chassis- Fully TIG Welded Tube Chassis Constructed out of .125 wall DOM Tubing For Superior Strength 2 Seat Design Radiator Mounted In back Water Runs Through Frame Rails Front And Rear Double Triangulated Four Link Suspension Lower Link Material- 2" DOM 1/2" Wall With Large Flexx Joints Upper Link Material- 1 3/4" DOM 1/4" Wall With QA1 7/8 Heim Joints Sway-Away Air Shocks 18" Travel Transmission- Sm465 W/ Granny Low LUK Highperformance Clutch Lightend Aluminum Flywheel Np203+Np205 Doubler W/ Triple Stick Kit Custom Billet Shifter Knobs Rear HD Flange For Drive Shaft Axles- Front- Narrowed 2.5 Ton Front Rockwell, Mowhawked, Wilwood Pinion Mounted Brake, Detroit Locker, 1410 2 Piece Driveshaft Rear- Narrowed 2.5 Ton Front Rockwell , Mowhawked, Dual Wilwood Calipers W/ Modded F550 Rotors at the wheels, Detroit Locker, 1350Cv/1410 DriveShaft Dash And Center Console Stainless Steel Construction Iquies performance Guages..Water, Oil, Fuel, Volts, 5" Tac Pioneer Cd Player Grant Steering Wheel Roof Mounted 6x9 Speakers Steering- Charlynn Orbital Valve 2 Cheif 2x8 Single Ended Rams KRC Cast Power Steering Pump W/ Aluminum Pulley Aluminum Powersteering Resivour Inline Steering Cooler Rear 12 Volt Power Pack Pump(Toggle Switch in Center Console for control) Wheels And Tires 20" STAZ WORKS Double Bead Locks 49" Superswamper Irok's Extra Stuff- CcAC Racing Seats, Reclinable/Sliders RCI 4 point Harnesses Wilwood Triple MC Hanging pedals With Aluminum Resivour CNC Clutch Slave Cyl. Stainless Steel Brake Lines(Hard&braided) Painless Wiring Harness All Circuts ON Fuse Block Front and Rear Line Locks Optima Red Top Battery Billet Specialties Battery Mount Rock Lights Under in all Corners 2 Procomp Spot Lights 16 Gallon Aluminum Fuel Cell Howe Aluminum Raditator Flexalite Dual Electric Fans 100 Amp Alternator PowerMaster Mini Starter Located In Fremont, Ca $33K OBO ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
We've got you covered 925-339-6035 Turn-Key Rock Crawlers and Sand rails, Custom Chassis, Roll cages, CNC Plasma Cutting, CNC Milling, Exo-Cages,Suspention & Link Set-ups, Lowering/Air Ride, Welding, Custom Machining, 4x4 Parts and sales, Air Ride parts and sales
#2 |
that things bad ass!
[COLOR=DarkOrange]fj40/45 buildup in the works. [/COLOR] |
| Sponsored Links |
#3 |
Member # 22368
fucking sweet ass buggy.
Knowledge is power [url]www.pirate4x4.com/forum[/url] New Project in the works, 85' 4runner aka ? R.I.P to ALL our brothers that have lost their lives doing what they love. |
#4 |
Sick Azz hell...............................damn, damn, damn!!!!
#5 |
Member # 18915
Let's see a side view...
#6 |
CU$TOM ROCK CRAWLIN
Sure , here you go...
Some pics were taken With out shafts and Limiting straps, It sits about 6" Lower now... ![]()
#7 |
Member # 6816
nice work cody!
looking for Advance Adapter parts? send me a pm! |
#8 |
Pirate4x4 Addict!
a whole lot shinier than mine
looks good man!
www.myspace.com/sillyneck www.sillyfabservice.com www.rockzombies4x4.com ECV 7-11 ROCKZOMBIE Sillyfab- FREE SHIRT WITH ANY PURCHASE OVER 1 MILLION DOLLARS 916 635 3485 |
#9 |
CU$TOM ROCK CRAWLIN
ttt- thanks---- on ebay
#10 |
Damn sits high! Those air shocks fully extended just sitting there?
TJ/Wrangler MUTT... Dana 80 37 Spline, Discs Bling HP60 Dendenbears,Chromos/Longfields FULL HYDRO 47LTB's Locked with C&R BreadLocks 350TBI Sm465 203-205 Gen2 Doubler ROCKZOMBIES4X4.com R.I.P. Dave "Kyle" That was one hell of a ride, I will never forget! |
#11 |
CU$TOM ROCK CRAWLIN
Haha, definatly not, It doesnt sit that high now, It dident have limiting straps in the pics, It sits with only 6" Of shaft showing now
#12 |
CU$TOM ROCK CRAWLIN
ttt,,,, make me an offer!!!
#13 |
CU$TOM ROCK CRAWLIN
some one wants a sweet rig???
#14 |
Member # 9868
You use the limiting straps to set ride height?
KOH '09 winning Co-Dawg. Thanks to Jason Scherer and the Campbells for keeping me in the sport. Its an honor to be a part of both your teams. |
#15 |
CU$TOM ROCK CRAWLIN
Adjustable limit straps,,, and lowered psi in shocks. Just dident have them adj. in pic.
same concept as using front & rear winches to sinch down
#16 |
CU$TOM ROCK CRAWLIN
ttt new Price
#17 |
Member # 23545
You couldnt of got more creative on upper link mounts in the rear? I dont think the square tube is going to hold up to rockwells and 49s?
#18 | |
bla bla bla
Member # 20027
![]() how did an east coast buggy end up out of freemont ![]() cool shit however. edit; does it come with a 6' ladder?
miss ya tommy, RIP Last edited by yotee; 11-28-2007 at 07:42 PM. |
#19 |
Member # 23545
anybody else notice that there isnt a winch on it? Id like to see these adjustable limit straps. Do you have to get out and adjust them? The whole purpose of the winch to your front axle is to be able to adjust it depending on the obsticle. Also why didnt you run the rearsteer lines down the control arm instead of hanging out the back?
#20 |
Member # 17177
did anyone notice it DOESNT look 6" lower?
00 Superduty 4x4, 02 F-150 4x4, 73 Bronco |
#21 |
rock monkey
sweet ride, good luck with the sale
87 XJ, exo'd, 60s, atlas, arbs, boatsides, 40" creepy crawlers, full hydro steer, dual pink kid seats ext........ chicks dig body damage, especially my wife. |
#22 |
Member # 4056
Where is the lowered shots like rednck21 asked about.
Never heard of a limit strap holding the shocks down? Mine have like two inches of play in them, with a small winch to suck the front or ass end down when needed... Also shouldn't the shocks be at a slight angle inward??? Hell I don't think you could tow that high beast without taking out a bridge... 33K???? Good luck. |
#23 |
he already sold this and got quite a bit of cash for it....
#24 |
Member # 23545
poor sucker who bought it. I havent seen too many dragsters with the engine that far foward. I think my nose would bleed just sitting in it.
#25 |
Member # 96437
would you consider a trade for a m715. i have it on here for sale
| Thread Tools | |
| Display Modes | |
