Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 01-07-2007, 07:13 PM   #1
carwash
pimpin' IS easy
carwash's Avatar
Member # 21939
Send a message via AIM to carwash Send a message via Yahoo to carwash
How tall is your buggy?
Simple questions. I only ask because mine is getting taller and taller and i'm not liking it... I need clearance for pinon brakes, etc...
What is the tallest part of your rig, how tall?
How high is the belly?
How tall is the bottom of the door panel?
I just need some reassurance that i'm not building a monster truck...
thanks in advance.
carwash is offline   Reply With Quote
Old 01-07-2007, 07:24 PM   #2
mikey_d05
Unoriginal
mikey_d05's Avatar
Member # 46588
Send a message via MSN to mikey_d05
My rig sits a touch over 80" tall at the main hoop on 40's but it should come down an inch or two when it gets off jackstands. It's also on 1-tons so I don't have to clear rockwell chunks.
Belly is around 24", slider is around 30".
EDIT: oh yeah, I'm 6'5" so the hoop could be 4" or so lower if I was average height.
Tech Articles: 4x4mecca.com
Kickass Parts at a Kickass Price: DIY4X.com
Buy My Beretta CX4
mikey_d05 is offline   Reply With Quote
Old 01-07-2007, 07:25 PM   #3
Rock Ape
Member # 23843
thanks in advance.
My buggy(2 seater)is 72inches(6 ft)at the top of the cage,22inches under the belly,door panel is 30 inches,39.5 tires!!!Single seater(in progress)has 18 inches under the belly and top of the cage is 63 inches
and the truggy....
http://www.pirate4x4.com/forum/showt...454424&page=12
44 inch tires,top of the cab is 84 inches,belly has 22,boat sides 48 inches!!!
THANKS TO MY SPONSORS....TFAB,TRAIL-GEAR,YUKON,TORCHMATE AND RUFFSTUFF!!!
Rock Ape is offline   Reply With Quote
Old 01-07-2007, 07:53 PM   #4
35xj
Member # 14780
mine is 71" at the higest point of the cage, 19.5 at the belly on 40's.
again, im not clearing rockwells!
04.5 cummins lb,qc,white, 4x4,,bddl, outlook,, exhaust 315 bfg's
02 WRX caged etc
new buggy
http://www.pirate4x4.com/forum/showt...43#post5890143
save tellico post #830
35xj is offline   Reply With Quote
Old 01-07-2007, 08:00 PM   #5
elf_cruiser
elf_cruiser's Avatar
Member # 2857
I am clearing rockwells. High point on the cage is 85" - but it was built with too much headroom. It could be 80" and I'd have room for my noggin. My frame is about 25" Haven't measured the door bars - but I have a decent boat-side (see avatar)
I was a dog. But - I was really good, so they let me come back as a human. Sort of...
elf_cruiser is offline   Reply With Quote
Old 01-07-2007, 08:07 PM   #6
Ramrock
Member # 20276
83' to the top of cage. And 28" to the belly and slider are at 31". I run my pinon brake on the front of the axle so it clear's the oil pan. Rear i run it on the front of the diff to. It has no guard on it. My on rockwells and 42" Irocks. I run with alot of other rockwell rigs. And they are way taller then mine. Just remember that they are unspung weight. Hell mine only weighs in at 4700pds load with tools and me.
01 RAM 2500 Q/B 2WD 24V CUMMINS
85 YOTA 2.5-ROCK's TBI-4.3/tb-350/doubler/42"s/H1's/4LINK/1 LINK
Ramrock is offline   Reply With Quote
Old 01-07-2007, 08:24 PM   #7
patooyee
Pirate4x4 Addict!
patooyee's Avatar
Member # 4821
I'm using rocks, too. My belly is 22" off the ground at the highest point and the tip-top of the cage is 73" from the ground. I'm running 42" IROKs. I could go lower if the driveshaft wouldn't hit the damn PS pump pulley. I love how low mine is and I love my new Rockwells!
J. J.
www.patooyee.com
Build thread
patooyee is offline   Reply With Quote
Old 01-07-2007, 08:30 PM   #8
psychotoy
psychotoy's Avatar
Member # 20309
Send a message via Yahoo to psychotoy
Mine is at 70" at the top of the cage with 5 psi in the 37" Krawlers and 21" flat belly, I assume you are running Rocks so you could probably run me over........
Toy/Zuk buggy-4linked rear, 3 link front fox air shox, 37" krawlers on 17" sky alum. beadlocks, 16v 1.6 auto to kick case mated to d300 twin sticked toy e-lockers, elec. line locks, cutting brakes, and a dumb Mexican behind da wheel
psychotoy is offline   Reply With Quote
Old 01-07-2007, 08:38 PM   #9
carwash
pimpin' IS easy
carwash's Avatar
Member # 21939
Thanks for all the replies guys, i was worried that 80-84" was going to be ridiculous, but i guess not.
Old 01-07-2007, 08:39 PM   #10
X-Rated
X-Rated's Avatar
Member # 72707
92, and that is ridiculous... I am pretty pissed. I was shooting for 82, but it did not happen
X-Rated is offline   Reply With Quote
Old 01-07-2007, 08:43 PM   #11
patooyee
Pirate4x4 Addict!
patooyee's Avatar
Member # 4821
I wouldn't say that is high, especially for a rockwelled rig. And I don't know what type of rig you are building either. (EG what types of constraints you are in.) But I do know one thing ... any amount of effort that you expends in getting that thing even 1" lower is worth it. You will hate life making all the notches and gussets around everything now, but when you wheel it and it is totally and completely stable where all your friends are rolling, it will all become worth it.
J. J.
www.patooyee.com
Build thread
Old 01-07-2007, 08:50 PM   #12
X-Rated
X-Rated's Avatar
Member # 72707
i am stuck where it is, the motor is too big (8.1L) it is wide and TALL as all get out. The intake is almost a foot tall, and the oil pan is also almost a foot tall. To keep the oil pan up, the hood got high. TO see over the hood my seats went up. I could have lowered the top of the cage another inch or 2, but my visibilty would go from shit to non existant. I am running unimog u1300 axles, and 49" iroks. So that puts everything up high. I think my floor pan is about 45" off the ground. http://www.pirate4x4.com/forum/showthread.php?t=493043
but my rims and tires weigh between 250-300 pounds I think. (49's are 177 and the 20" staz double beadlocks with a 3/8" rock ring are not light weight.) The axles weigh 800 a piece, and then I added another 50 pounds per axle of brackets and steering rams and the such. So 27000-2800 pounds of unsprung weight and being 102" wide and 130" long I hope will keep me planted. I have the drive train centered arround 42" or so, and dont really have anything but tube above that, so the CG should be real low... Figure 2700 lbs centered at 26" off the ground, and the drive train is 1200 centered at 42, and the cage about 2000 centered at 50" should give me a CG arround 37" off the ground. if that number is right, and the supension can not unload, I should be able to stay on all 4 tires even on a 50 degree side hill. Assuming the weight is 60 40 front to back, ascend 65 degrees, and descend 55 degrees. We will see how it goes
if I suck the suspension down 6" that lowers my CG to 34, with that 67 ascend, 57 descend, and side hill arround 55 or so.... Biggest thing is with the susspension sucked down it cant unload, which changes everything...
Old 01-07-2007, 08:55 PM   #13
carwash
pimpin' IS easy
carwash's Avatar
Member # 21939
oh my holy crap that's tall... i feel like a shorty now.
Old 01-07-2007, 09:21 PM   #14
Hero
Hero's Avatar
Member # 22799
Im not going to mention my tall ass bitch.
Ok, I am. Dont have actual measurements but here are close guestimates:
Roof is around 92
Doorsill is around 36
belly around 28
And yes, I want it lower. Getting close to ripping it apart and building a buggy.
Hero
Hero is offline   Reply With Quote
Old 01-07-2007, 09:31 PM   #15
socalchef
Member # 19652
Send a message via AIM to socalchef
about 78" tall, 23" under the belly. A few inches taller then I'd like, and the back definitely sits taller then the front
Shaffers Diablo Sport chassis on a 4.0L YJ frame
Read the buildup at http://www.abendig.com
socalchef is offline   Reply With Quote
Old 01-07-2007, 09:47 PM   #16
Fl-Krawler
Fl-Krawler's Avatar
Member # 47337
88" to the top of the "B" pillar with 49" iroks.. 28" under the belly and 38" to the floor pans..engine sits low(so low that the top of my LT-1 is 1" below the front fenderline) and 5" back into the firewall to clear the rockwell.. both my f/r driveshafts operate at a 3* downslope at ride height
Fl-Krawler is offline   Reply With Quote
Old 01-07-2007, 09:48 PM   #17
RockTonka
wheeler
RockTonka's Avatar
Member # 33155
Another 92 high, 102 wide, at a 136wb checking in...the width/length does make it seem lower than it is though. Still pretty fawking tall...somebody's gotta clear the trails for all you short fawks
73 CJ5 @ 136" wb, 502/th400/WMS 3:1 203/205, f&r narrowed, clearanced, steering Rockwells, f&r 3-link w/ coils, 49" Iroks, full hyd.
RockTonka is offline   Reply With Quote
Old 01-07-2007, 09:53 PM   #18
Captain Crunch
Authority!
Captain Crunch's Avatar
Member # 17369
Highest part of the roof is 60" Belly is 20" With 39" Krawlers.
Single Seat Buggy LS1 Atlas HP 60's 39" Krawlers
Captain Crunch is offline   Reply With Quote
Old 01-07-2007, 10:13 PM   #19
TeenyCAR
Member # 63225
58 inches to the top of the roof. 20 inches of belly clearance. 20 inches to the "door bottoms". 39" Krawlers.
TeenyCAR is offline   Reply With Quote
Old 01-07-2007, 10:49 PM   #20
Gunmetalcruz
Member # 6569
76 top of the cage, 24.5 at the skid with 44 tsl's
Team FOH KOH Competitor # 321
Thanks to the people making it happen
Trent Fabrication,CTM Racing Products,Levrett Transmission,Viosport.com,WFO Concepts,ARB,West Coast Differentials,ProComp Wheels,Reid Racing,BFGoodrich Tires,Talking Threads Embroidery
Gunmetalcruz is offline   Reply With Quote
Old 01-07-2007, 10:50 PM   #21
Tydes
Tydes's Avatar
Member # 9255
Send a message via Yahoo to Tydes
5 Foot 3 to the top of the cage
23 to the belly
This is with 4d4 boggers
www.4Lockedfilms.com
Tydes is offline   Reply With Quote
Old 01-07-2007, 11:10 PM   #22
psychotoy
psychotoy's Avatar
Member # 20309
23 to the belly
LIAR!!!!..........you suck...
Old 01-07-2007, 11:56 PM   #23
White Rubicon
Member # 23832
65" top, 17" belly , 109" WB, 78" wide, 39" Krawlers
Now: MoneyMark......the Mod's won't change my name. F-Toy Team #32
White Rubicon is offline   Reply With Quote
Forum Jump
