Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Suzuki
Old 02-04-2007, 09:27 AM   #1
Nowhere
Member # 15908
Send a message via AIM to Nowhere Send a message via Yahoo to Nowhere
1.6 16v STARTING issues in samurai, runs GREAT?!
Ok, I've got my 1.6 16v in my samurai but I have a STARTING problem...
She cranks nice and fast, the injectors seem (unconfirmed..) to pulse, sparks seem to fire, but it does NOT COLD START...
Once the engine is running, she idles perfectly, the cold fast idle works, no stumbles, hesitations, and sounds GREAT with an open header
She'll HOT start PERFECTLY, maybe 1.5 seconds on the starter and vroomm, fast idle for a sec, then settle down to 800 ish rpm..
I am ONLY able to COLD start the truck by squirting carb cleaner into the brake booster line (then reconnect the hose..), open the throttle a bit, then fire. It'll cough for a second (carb cleaner is not gasoline..), then the gas/normal operations kick in and she's perfect.. wtf?
If I shut it down COLD after it is running by itself, I can not restart it (like 10 seconds after starting/running off the carb cleaner, when the engine is running off the gasoline..).
Again, once she's warmed up, starting is NOT an issue. When @ operating temp, idles great (maybe a little pop here and there, no o2 sensor, open header..), and will restart PERFECTLY..
Any sugguestions on where to start? ECU coolant temp? air temp? distrib, timing?
help?
Your flesh is a relic, a mere vessel. Hand over your flesh and a new world awaits you. We demand it.
Nowhere is offline   Reply With Quote
Old 02-04-2007, 09:45 AM   #2
Hvy_Chevy
Hvy_Chevy's Avatar
Member # 14094
Send a message via AIM to Hvy_Chevy
temp sensor?
how cold is cold?
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is online now   Reply With Quote
Old 02-04-2007, 11:52 AM   #3
cajunsuzukispider
Member # 48911
do you have one of those valves to let hot air into the intake from a jacket on the exhaust manifold? suppose that valve is malfunctioning, it's possible maybe your intake is closed. ?????
i think it would be vacuum actuated, check the vacuum lines everywhere.
cajunsuzukispider is offline   Reply With Quote
Old 02-04-2007, 07:04 PM   #4
Nowhere
Member # 15908
Originally Posted by Hvy_Chevy View Post
temp sensor?
how cold is cold?
Not @ operating temp.. maybe 70 ~ 80* f.. What temp sensor? The ecu or air temp?
Irrilevent on the hot air setup.. The 16v does not have a hot air pickup on the header.. I have NOT checked the vacuum lines as it runs PERFECTLY when it warms up or after it first "catches" on the carb cleaner in the brake booster line.. I can make it run BAD by making a vacuum leak... She puuuuuuuuuurs...
Old 02-04-2007, 10:13 PM   #5
abwmike
Member # 80752
ugh. not that im some sort of expert. but our 16valve header came with a hot are pickup tube thing? so that would lead one to believethat it does?
hammer down.
abwmike is offline   Reply With Quote
Old 02-05-2007, 04:39 PM   #6
ka4yqi
Member # 38153
Does you fuel pump run when you first turn the key? Should run for a few seconds and quit till you crank it.
ka4yqi is offline   Reply With Quote
Old 02-05-2007, 06:45 PM   #7
Gonzalo Bravo
Gonzalo Bravo's Avatar
Member # 26772
Is it connected the black/Yellow wire to the starter fron the ecu? It feeds extra fuel during starts.-
Suzuki Samurai ,2JZ GTE 3.0TT, A340 tranny, NP231 Doubler, TLC Tcase, Coils up front, Q-elliptic, Toys 8" ,5.12, ARBs, Iroks 36.
Gonzalo Bravo is offline   Reply With Quote
Old 02-15-2007, 07:46 PM   #8
Nowhere
Member # 15908
The fuel pump is hardwired on with a different battery for testing purposes..
Old 02-18-2007, 02:36 AM   #9
Peter H
Peter H's Avatar
Member # 67881
Does your fuelpump give enough pressure? When pressure is below specs, ECU prohibits starting... .
It's not a car, it's not a jeep, it's a legendary Sam...
Peter H is offline   Reply With Quote
Old 02-18-2007, 09:58 AM   #10
Nowhere
Member # 15908
Yes, verified with an inline EFI pressure gauge.. I think it was 30 ~ 40 psi...
Once it STARTS, she runs GREAT, just no start without a fuel boost..
Forum Jump
