Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Classifieds > Vehicles and Trailers For Sale
Old 02-07-2007, 09:34 PM   #1
skinny_pedal
Member # 40027
Send a message via AIM to skinny_pedal
85 toyota 4x4 efi longbed. lcengineering engine
well i have decided to try and sell my toyota instead of building it. i really want a samurai or wrangler. i just like the idea of having a tub. so yes i would consider possible trades for those. here are the details
85 Toyota 4x4 longbed fuel injected 5 speed
ENGINE-
The LCE EFI Pro long block is a 2.5L high-performance engine designed for street applications. It includes the ported and polished EFI Pro Cylinder Head (new casting) with stainless steel valves, big bore forged pistons and ARP head studs for more power and reliability. Like every LCE product, it's designed for performance and reliability.
Features:
2.5L - 135 HP @ 4,900 rpm
Extremely strong, predictable, low rpm throttle response
Perfect for 4WD's & 4-Runners
Very smooth idle
Here is a brief list of components in this engine.
Top End:
1021024 Street Performer Cylinder Head (85-95)
1022021 EFI Pro Camshaft
1023042 45.5mm SS Intake Valves
1023033 37.5mm SS Exhaust Valves
1023201 Street Performer Valve Springs
1023006 Street Performer Retainers
1023090 Hardened Valve Keepers
1023099 Toyota Valve Seals
1045030 New Exhaust Studs
1023018 Complete Rocker Arm Assembly
Custom Valve Cover (Red/Silver/Black)
Bottom End:
1011003 Pro Cylinder Block
1024069 Pro Head Stud Kit
1014343 94mm Pro Forged Piston Set
1013003 Street Performer Connecting Rods
1013048 Street Performer Crankshaft
1013072 Clevite 77 Main Bearings
1013132 Clevite 77 Rod Bearings
1013165 Clevite 77 Thrust Bearings
1016019 Brass Freeze Plugs
1015012 Dual Row Timing Chain Conversion Kit
1016033 Complete Engine Gasket Set
also has big bore throttle body and intake
lc header
2.25" exhaust all the way back w/ catco cat and magnaflow muffler
15000 miles tops
Transmission-
W-56 5 speed transmision
Top shift transfer case
napa clutch
napa slave cyclinder
napa clutch master
Axles-
stock 4.10's front and rear
rear axle out of an 87 4runner so it has the bigger brakes and is wider
front axle has 1.5" wheel spacers on either side to match rear with
heavy duty tie rod
have marlin knuckle rebuild kit w/ wheelbearing in box un opened for it
Suspension & Body-
2" body lift
1" suspension
Rear tow package and wiring
Front brush gaurd bumper
Interior-
Bucket seats
sr5 cluster( speedo and temp gauage do not work)
clock
cb radio
no stereo, but has speakers in dash for stereo
tilt column
aftermarket sunroof (does leak on hard rain)
dent on drivers side door, hood, and 2 on bed
drivers corner light is on
Misc-
15x8 black steel wheels
32x1150r15 old style bfg mud terrain 30-40% tread
tinted windows
1 piece rear drive line by High Angle
tool box
asking $3250
Gavin
2067159551
skinny_pedal@hotmail.com
need any other pics or more details, just ask
if trade is of more value, i can throw some cash or have duals and a 5.29 3rd w/a detroit, and a set of us marlin 4" springs for the rig
skinny_pedal is offline   Reply With Quote
Forum Jump
