Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Miscellaneous > General Chit-Chat
Old 02-11-2007, 06:14 PM   #1
6869704x4
6869704x4's Avatar
Member # 14584
Army SF wants Super Swampers
Army bean counters say no. Who will win?
http://www.special-operations-techno...cfm?DocID=1895
PRINTER FRIENDLY...
« Go back
Please contact Kerrigan Media for a reprint of this article.
Tangles Over Tires
If a special operations unit wants a specific kind of tire for a specific off-road application, what are the chances it can get hold of it? The most accurate answer to that question probably is, not anymore. There has been some disagreement over what is the right tire for special operations forces, and what exactly is the best tire and for what type of driving.
By Peter A. Buxbaum
Currently, all tires are supposed to be procured through the Defense Logistics Agency’s Defense Supply Center Columbus (DSCC) from lists of products tested and approved by the U.S. Army Tank-automotive & Armaments Command (TACOM). The management of the Army’s tire supply chain in the process of being privatized, but TACOM’s central role in tire testing and selection will remain unchanged.
Special ops forces have been known to skirt the Army’s acquisition bureaucracy and get their preferred tires on their ground mobility vehicles. But that was before a certain unofficial tire became so popular that it appeared on TACOM’s radar screen.
The Army’s official line is that special operations get the highest priority for tire testing and approval. But that doesn’t mean the tires that the special ops units want will be approved. One reason for tire failure might be that TACOM tests for a broader scope of applications than intended by the special ops unit.
Tire experts say that special ops units ought to seek tires that suit the particular mission at hand. But the issue is more complicated than that. If a tire is to be used on multiple terrains, for example, it may not be possible to provide the optimal tire for each and every circumstance a vehicle will encounter.
In 2001, Mike Cooney, a master sergeant with a U.S. Army special operations unit who has since retired, was overseeing a ground vehicle mobility project using a modified Humvee when he concluded that the Goodyear tire the Army had provided was substandard for his requirements. “Most military movements are over the road rather than cross country,” Cooney commented. “But a lot of driving in special operations is done off road.”
Cooney went through a selection process and identified an alternative tire, the Super Swamper, manufactured by Interco Tires of Rayne, La. “It wasn’t specifically built for us,” Cooney related, “but we did ask for a special size and they told us they could do it.”
The main difference between the Super Swamper and the Army’s tire is that the Super Swamper is a bias ply tire while the Goodyears were radials. In recent years, the trend has been away from bias plies and towards radials, according to Will Leaman president, BCDS Inc., a defense contractor headquartered in Roanoke, Va., specializing in off-road driver training.
“Radials have taken over the passenger tire market because they offer a significantly smoother ride and give significantly longer tread wear,” he said. “From an industrial or off-road perspective, bias plies still have a place because their thicker sidewalls resist puncture and rolling. But the quality of their ride and handling are lower than radials and they also reduce fuel economy.”
But in this case, the bias ply tire fit the bill, according to Cooney. “Radials will generally last longer,” he acknowledged, for 40,000 to 60,000 miles versus 20,000 to 30,000 miles for bias ply. But bias ply’s better load-carrying characteristics and puncture resistance put them over the top.
“The radials were blowing out all the time,” Cooney said. “They had no puncture protection against driving on sharp rocks. The Super Swamper did not puncture as easily and when they did they were reparable. The Army tire just got ripped apart.”
As a result of Cooney’s evaluation, a number of special operations units, operating perhaps one thousand vehicles, chose to replace the Army tires with the Super Swamper without going through DSCC or TACOM. “That was way below the radar,” Cooney said. “It was no burden to the Army and nobody seemed to care.” The Army was actually saving money on the deal, he added: in 2003, the Army was paying as much as $235 per tire for Goodyears but only $185 for the Super Swampers.
All this occurred before September 11, 2001. After that date, and with the run-up to the invasion of Afghanistan, things changed markedly, recalled Boo Leblanc, a marketing official with Interco. Before the terror attacks, the company would get military orders for tires in the dozens, but afterwards, “things got into high gear within a month,” Leblanc said. “The phones started ringing off the hook and it didn’t stop for at least a year.” The company received orders for hundreds of tires and tens of thousands of dollars at a pop.
Most of the calls came from special ops units looking to purchase tires on their government credit cards, according to Leblanc. “We feel that people using our stuff back home might have told military people they knew of a better tire, a tire that outperforms Goodyear in certain circumstances,” he said.
Interco is a small tire manufacturer specializing in off-road tires that can withstand the rigors of everything from rocks to mud. Leblanc described the Super Swamper as an “old time” type of bias ply tire, one made of thicker and much tougher material than the currently popular radials. Those older tires can accommodate lugs in the sidewalls, for example, a feature impossible to build into the thinner radial tire. Because Interco is small and specialized, it doesn’t need manufacturing runs of thousands of tires to make a sale worthwhile.
“We could pop in a run of fifty and get it out,” Leblanc said. “Our company strategy is not to be number one but to have our own niche in the marketplace.” Moreover, he added, the larger manufacturers have discarded their tooling for bias ply tire manufacturing.
Before September 11, Interco was approached by TACOM to have its tire tested at the companys expense. “If we passed we possibly could get a government contract, and if we failed we were out the money,” said Leblanc. “We didn’t think it was worth it. After 9/11, all that went out the window,” he continued. “It seemed like TACOM said it was okay to get whatever works.”
The Super Swamper was eventually tested by TACOM, a test paid for by USSOCOM, and it failed. But Leblanc complained that Interco never saw the test results nor under what conditions of speed or tire pressure the tires were tested at.
Off-road operations typically proceed at much lower speeds than highway movements. In addition, tire performance is enhanced off-road when tire pressure is reduced, according to Will Leaman. “At low speeds and on soft or rough terrain, you want to reduce tire pressure in order to increase the contact patch and the tractability of the tire,” he explained.
Why might a tire beloved by special ops units get rejected by TACOM? Leaman’s comments provide a clue: that they may not have been tested under the conditions for which they were intended.
Matthew Geary, BRAC tire privatization project manager at DSCC, the agency that acquires tires for Army units across the board, claimed that TACOM and the U.S. Army Tank-Automotive Research, Development and Engineering Center (TARDEC) are sensitive to the needs of special operations. “They want to give special ops units what they want,” he said. Geary is in charge of managing a pending solicitation which will chose a private contractor to manage the Army’s tire supply chain, a process mandated by the BRAC recommendations of 2005.
Might the Interco tire have failed because of TACOM and TARDEC’s testing methodologies? “Tires are used in a variety of circumstances,” Geary explained, “and before they are approved they need to make sure they perform across a spectrum of uses. A tire may be used off-road one day and on a highway the next. This can cause different performance characteristics.”
DSCC’s job, is to “buy what they approve,” Geary noted, referring to TACOM and TARDEC. “We will become involved in the process to make sure they take our customers’ wishes seriously,” he added, “but the bottom line is that we cannot buy a tire that has not been approved.”
Geary also acknowledged that “TARDEC tries to go to the primary manufacturers,” Goodyear, Michelin and Bridgestone Firestone, and that “they go with the tire that gives them better performance and that is tracking toward radials.”
Leaman agreed that radials will provide better performance on the highway, but “in a pure off-road situation I recommend bias ply,” he said. Leblanc, for his part, admitted that the Super Swamper could not match the performance of a radial tire on the highway.
The instruction provided by Leaman’s company is geared primarily toward acquisition of vehicles and tires by special op units after they arrive in country. “We instruct them on what tires work best on different types of terrain,” he explained. For example, a heavy lugged tire is good in mud and on rocks but not in sand. The lugs provide a self-cleaning mechanism to remove mud from the tread bars so that they are clean when they come back down to the contact patch. Operating on snow and ice calls for a tire with siping, small razor cuts in the surface of the tread to provide additional traction on snow and ice.
“If operating in mixed conditions of pavement, sand, dirt and rocks I would recommend radials, and if operating at high speed, then definitely radials,” Leaman added. “On the other hand, if you’re going to be in the boonies for a long period of time, bias plies might be best because of their puncture resistance.”
The issue of tire selection, for Leaman, is not a cut and dry decision, but one that requires the balancing of several factors. Not so for Mike Cooney, who insists that “you need different kinds of tires just like you have different kinds of shoes.” He blasted the Army logistics types for providing only one option “because it makes it simpler for them logistically.”
The upshot of the Super Swamper episode was that, after some give and take, the tires were pulled off the Humvees and replaced with standard Army issue.
Interco, meanwhile, has soured of doing business with the U.S. Army. But that’s not to say that its entire military business is kaput. Boo Leblanc stated that defense organizations in Canada, Saudi Arabia, Egypt, the United Arab Emirates, Jordan and Kuwait all buy Interco tires for their off-road needs.
Yes my truck is environmentally friendly.
It lets most of the environment in the truck with you!
6869704x4 is offline   Reply With Quote
Old 02-11-2007, 06:21 PM   #2
usmcdoc14
Spork Wrath
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
umm we buy swampers all the time with no issue. Whats the army's problem?
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote
Old 02-11-2007, 06:24 PM   #3
InfantryYJ
Member # 2650
Location: Home is where the Marine Corps sends you,...right now, it's Kernersville, NC.
Seen plenty of Hummers in Iraq with Swampers.
Nothing important
InfantryYJ is offline   Reply With Quote
Old 02-11-2007, 06:30 PM   #4
apeters89
Moderator
apeters89's Avatar
Member # 7647
government bureaucracy at its best.
We'd rather buy a tire that's better logistically for us (oh, and that costs us a lot more) than one that will keep our soldiers alive
KF5EQF
Big thanks to www.rwkhaussupply.com
apeters89 is offline   Reply With Quote
Old 02-11-2007, 06:32 PM   #5
6869704x4
6869704x4's Avatar
Member # 14584
Did you read the article?
Old 02-11-2007, 06:38 PM   #6
4544x4
4544x4's Avatar
Member # 34587
Send a message via AIM to 4544x4 Send a message via Yahoo to 4544x4
That shit should stop right now.
[QUOTE=Chris;9538785]Working on it.[/QUOTE]
Buy my ubolts
[url]http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=180336445558[/url]
OR
[url]http://www.pirate4x4.com/forum/showthread.php?t=769654[/url]
4544x4 is offline   Reply With Quote
Old 02-11-2007, 06:43 PM   #7
usmcdoc14
Spork Wrath
usmcdoc14's Avatar
Member # 13344
YES
smart soldier would use his credit card or do a vendor sale and not buy them from DSCC.
Like I said WE BUY THEM ALL THE FUCKING TIME !!
We put in the proper request and we get a pallet with tires, TAADAAAA
Old 02-11-2007, 06:49 PM   #8
Bondage
Member # 21100
I didn't realize you are a socialist.
RIP Art Lilley "dulce bellum inexpertis "
#1070
#811
Is it a progress if a cannibal uses knife and fork?
Stanislaw Jerzy Lec
Bondage is offline   Reply With Quote
Old 02-11-2007, 06:50 PM   #9
4544x4
4544x4's Avatar
Member # 34587
No just they are selling to some of OUR soon to be enemies
Buy my ubolts
OR
Old 02-11-2007, 06:52 PM   #10
Bubba Ray Boudreaux
M.C.M.
Bubba Ray Boudreaux's Avatar
Member # 5132
The problem is the crackasses who are in the decision making process who have spent a grand total of 0 seconds in the bush........................
The 7.62mm minigun. Sending love to your fellow man 3,000 times a minute.
A Great American
Bubba Ray Boudreaux is offline   Reply With Quote
Old 02-11-2007, 06:57 PM   #11
Scott@Rockstomper
The winch rope guy
Scott@Rockstomper's Avatar
Member # 1889
Once GSA figures out how to do business like normal business, I'll think about quoting their stuff again.
In the meantime, I'm with Interco... the government can buy what they want, with plastic or cash, or they can shop elsewhere.
Screw me once, shame on you. Screw me twice, shame on me.
Winch rope, DIY beadlock kits, hydraulic steering, and much more: Shop Rockstomper online
Scott@Rockstomper is offline   Reply With Quote
Old 02-11-2007, 07:19 PM   #12
6869704x4
6869704x4's Avatar
Member # 14584
YES
I not going to use the "I think Im smarter than you" roll eyes.
smart soldier would use his credit card or do a vendor sale and not buy them from DSCC.:
Don’t know what DSCC is but what they did in the beginning is just buy them. Did you skip the part that said the tires were pulled from the vehicles?
Read the article again. When they bought small quantities of tires they stayed “under the radar’ when larger amounts were ordered the bean counters noticed.
Old 02-11-2007, 07:33 PM   #13
nate379
nate379's Avatar
Member # 20099
Military purchasing is dumb IMO.
Alot of the GSA stuff is from the blind, disabled or minority/women owned business.
Like the spray paint we buy is $8 a can, come from the blind. The paint is pretty crappy, basically what you'd expect to buy at Wally world for $0.99.
So you'd think I could go buy some decent paint at the local hardware store for $3-4 a can.. save the AF some money, and we'd have decent paint.
Nope... can't do that.
nate379 is offline   Reply With Quote
Old 02-11-2007, 07:36 PM   #14
6869704x4
6869704x4's Avatar
Member # 14584
You scored a direct with that one.
Old 02-11-2007, 07:41 PM   #15
usmcdoc14
Spork Wrath
usmcdoc14's Avatar
Member # 13344
did YOU read your own article ?
Dude, we (Navy) still order swampers and there is no way in hell some fucker is going to tell us to pull them off the rigs unless they roll up and remove them.
and we will just order more
And no where does it say that they (army) is outright banned from buying them.
Old 02-11-2007, 07:48 PM   #16
Snowbird13
Member # 44136
Are we going to war with Canada?
Hammers Thread post #1388
Tellico Rallypost # 285
Snowbird13 is offline   Reply With Quote
Old 02-11-2007, 07:51 PM   #17
Bondage
Member # 21100
I have the first week of August available
#1070
#811
Stanislaw Jerzy Lec
Old 02-11-2007, 07:53 PM   #18
Bubba Ray Boudreaux
M.C.M.
Member # 5132
Just Quebec at this moment, but some parts of Ontario could very well be involved, although Thunder Bay is holding the rest of the province at bay...........
A Great American
Old 02-11-2007, 08:09 PM   #19
SeanP
Member # 7354
read up on world affairs much?
not one of those countries is, or will likely be in the future, an enemy of the US.
If you are not pissed off, you are not paying attention.
SeanP is offline   Reply With Quote
Old 02-11-2007, 08:10 PM   #20
pmurf1
Member # 2463
I used to work for a contractor at Luke AFB here in AZ. He went after the government contracts on base for HVAC hard and got them in Phoenix, Yuma, and even some in Cali. The owner ( a white male, no disabilities) simply transferred the business's possession and ownership to his wife who is a mexican woman, and they locked in for 7 years of preferred contracts. In the governments eyes, it was a minority owned business, even though everyone else in the company was a white male, except for one mexican helper. Didn't even matter if they were more expensive than another company, they got first dibs. It's a really broken system.
pmurf1 is offline   Reply With Quote
Old 02-11-2007, 08:10 PM   #21
6869704x4
6869704x4's Avatar
Member # 14584
The article was about the ARMY
Oops I missed the Defense Logistics Agency’s Defense Supply Center Columbus being knocked down to DSCC, my bad.
Also, dude, you, (Navy) don’t have a lot of use for Super Swampers except for some small units. And they can buy pretty much what they want and need.
Old 02-11-2007, 08:14 PM   #22
rock mafia
Jim's Garage
Member # 70555
I purchased 25 hummer BL's and Goodyear POS 36's from Govliquidation. All of them had a tag listing the price (what we as taxpayers pay) of $1495 per 1 wheel and tire. Four of the ones I got still had the tits on them. What a great use of our $$$.
clicky--- Jim's Garage
rock mafia is online now   Reply With Quote
Old 02-11-2007, 08:21 PM   #23
Rockcrusher
Member # 1372
The Army's supply system always was, is now and always will be a clusterfuck of the highest magnitude. I truely believe that there is an AR that specifically prohibits the application of common sense . . . or the saving of money.
Of course the Navy occasionally comes up with some off the wall shit, too.
Rockcrusher
My home may be a gun-free zone . . . Care to gamble?
Rockcrusher is online now   Reply With Quote
Old 02-11-2007, 08:26 PM   #24
Snowbird13
Member # 44136
But they are arab countries. They must be terrorist farming, US hating, talibaners.
Old 02-11-2007, 08:30 PM   #25
CronusTRD
CronusTRD's Avatar
Member # 11141
Send a message via AIM to CronusTRD
Shit, just buy them open market. Find 3 small businesses who sell interco and the government will be satisfied.
And the Interco should stop selling to Canada. How the fuck are swampers supposed to fit on their horses?
Mike H.
Solid Axle Taco
www.midatlantictoyotacrawlers.com
www.rightcoast4x4.com
Originally Posted by bigdreamin
Anyone want to take bets on how pissed Lance will be when gets back from where ever he went to find Camo running around like a 5 year old who just ate 5 pounds of sugar?
CronusTRD is online now   Reply With Quote
Forum Jump
