Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > Newbie General 4x4 Discussion
Old 02-12-2007, 02:13 AM   #1
BAMF-Z71
Member # 86861
Send a message via AIM to BAMF-Z71 Send a message via MSN to BAMF-Z71 Send a message via Yahoo to BAMF-Z71
What next?
Well, as ya'll can see this is my first post here. I've got a DD right now that I plan on putting some money into in the next year or two while I'm paying it off and then using it as a trail bitch. I'm pretty sure my next upgrade is either going to be a Truxxx 2" lift/level kit or a set of pacesetter headers.
What do you think should be my next upgrade while I'm trying to put the suspension lift off for later this year/early next.. ? The tires are brand new as well as the wheels.. so no need there. I personally think I just need more ground clearance, and I need to replace my shocks.. they are starting to squeak at 95k miles. Hydro shocks when I do the Truxxx lift.. or what kind/type of shocks should I look into? Links, specs, and why I should get them over any other would be good. Also, I always hear shit about Rancho shocks, I'm sure it's just a redneck high school thing.. but are they really that great for their money?
[FONT="Verdana"][SIZE="1"]'99 Silverado [b][COLOR="Red"]Z[/COLOR][COLOR="Silver"]71[/COLOR] [/b] :[INDENT][COLOR="Navy"]Indigo Blue[/COLOR]
RCSB, 4.8L Vortec
285/75 Mud Brutes
16x8 ProComp Crawler 151s [[COLOR="Black"][I]black[/I][/COLOR]]
K&N 77-series
Hypertech Programming
Glasspack Exhaust
[RIGHT]: 2 STRUB :[/RIGHT]
[CENTER]..-=/[U] Pike County Boy [/U]\=-..[/CENTER][/SIZE][/FONT][/INDENT]
BAMF-Z71 is offline   Reply With Quote
Old 02-12-2007, 02:28 PM   #2
BAMF-Z71
Member # 86861
Does anyone have some advice.. any at all?
RCSB, 4.8L Vortec
285/75 Mud Brutes
K&N 77-series
Glasspack Exhaust
Old 02-13-2007, 09:22 AM   #3
NICKC
Member # 67236
You will probably have some better luck in the Chevy forum.
Nick
1984 Nissan 720 - 305/th350 daul 720 cases - D44/14B Welded F/R
NICKC is offline   Reply With Quote
Old 02-13-2007, 02:57 PM   #4
BAMF-Z71
Member # 86861
Thanks, I posted it there too. Hopefully I can get some suggestions before too long.
RCSB, 4.8L Vortec
285/75 Mud Brutes
K&N 77-series
Glasspack Exhaust
Old 02-13-2007, 05:18 PM   #5
Dhmoto111
Member # 42045
what are your plans for it, if you want to clear some larger tires i would do a Solid Axle Swap instead of an IFS lift
depending on the front axle you want a SAS will in most cases be chaper than an IFS lift. It will require cutting and welding though
Dhmoto111 is offline   Reply With Quote
Forum Jump
