#1 |
Bottle Washer
Member # 18262
Cooler Rack from garbage!
Well I finally got tired of warm water and got myself a cooler. Now in a 40 you know theres not alot of room for one. So I had already made my tire carrier a gas can holder so I decided to add to it. I started by adding inch square tubing uprights. One side I used the hinge bolts , the other side I used the old tire holder holes.
![]() ![]() I had to space out the gas holder to clear the inch tubing ![]() Then I made a cooler holder from a bed frame I stole from someones garbage. ![]() I welded the cooler holder on the truck to make sure it would bolt on and off ![]() Then I had to make the 45 degree supports I used the top bolt of the bottom hinge this time and made a new hole in the carrier for the other side ![]() ![]() I then welded thesupports on the truck also. Then I painted everything and bolted it back up. ![]() Then I loaded it up and its solid as a rock. My cruiser is a 70 so I have the heavy tire carrier. With the bolts going thru the diamond plate its very solid. I use to run my 35" spare on it and had no problems. Im moving my spare to the wheelwell behine my seat. This took me about 5 hours mostly looking for bolts! ![]() Got to use some scrap I had laying around and can actually bring stuff to eat now on the trail!
Adam C. 70' FJ40 ORION!, NV4500, FJ80 LECTRIC LOCKER, 350, SO,SR, (for sale!) 2007 FJ Cruiser "My tapeworm has anorexia!" ToyLand4x4.com |
#2 |
lookin good man! Those are nice coolers too. Kodi
| Sponsored Links |
#3 |
Member # 6816
righton!
looking for Advance Adapter parts? send me a pm! |
#4 |
Member # 1926
Interesting use for bed frames.. I see people throwing those away all the time at the city garbage dump. Nice cooler rack.
'69 FJ40 with very few stock parts. 2000 Cummins with some goodies to make it smoke..... Trail Gear's Bad Ethics=Bad Business. |
#5 |
Member # 78189
good job !!
its nice to make stuff without a blueprint !! it gives you that WOW feeling !!!
#6 |
Member # 21749
Lets see some pics of the yellow ford hotrod in the background!
73 FJ40 -Under the knife --http://www.pirate4x4.com/forum/showthread.php?t=607442 65 FJ45 -Patiently waiting |
#7 |
Bottle Washer
Member # 18262
![]() Thats my 30 Model A ,all steel, chopped 4 inches, 427 Big Block and 5 speed and 2.8 rear end gears. Idles at 70 I take it all over , this pic was in lincoln Ne for Americruise and I asked this little cutie for a pic. No air throuh Utah in August is real fun, I run an old Thermador on the pass window , takes up the whole window!
#8 |
Member # 21749
Very Cool!!
Thanks!
| Thread Tools | |
| Display Modes | |
