Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Jeep - Hardcore Tech
Old 03-01-2007, 06:45 PM   #1
JKOZ
Member # 12463
John's YJ ground up build..Stroked, Stretched, Petted.....another Koz Off Road build
Heres another YJ we are currently working on.
I will get more pictures up in the morning. The cage is mostly done, new axle is build, engine / trans / t-case will be going in very soon.
This will be a very clean / capable trail rig. John brought us a rolling chassis and from there we will complete the vehicle build. There have been quite a few changes through the building, but every one of them has been to get a finished rig that will better suite the customer needs / wants.
We changed from a spring under set up to a spring over for much better on road ride quality as well as better performing off road.
Another major change was we have built a new high pinion Dana 44 front that will make for a stronger front axle and be built correct dimensionally.
The wheel base will be stretched 1" in the front and the rear will be stretched somewhere between 1-3" depending on what the corners will allow us to go. If needed we will put one of our HD aluminum stretch tanks in.
John had the entire vehicle sprayed with (I think Rhino Lining) inside and out.
He spent a lot of time researching what he wanted and had quite the pile of nice parts for us to work with when the project was picked up. This will be a trail rig that him and his family will be hitting the trails with----hopefully in a few weeks it will be ready for a snow trip.
Some of the specs:
90 frame-blasted, primed, painted
93 tub from California
8.8, Detroit locker, Moser shafts, LPW girdle, TNT truss 5.13`s
KOZ built Ford HP 44 Tru-Track, Superior shafts, 5.13
37 x 12.50 x 15 Maxxis Creepy Crawler, Moto Metal 950`s 15 x 8, Stauns Atlas, 3.0
Dodge diesel NV 4500 Center Force dual plate clutch
93 4.0 block 12 weight crank, Eagle rods, Custom Diamond pistons +.080, 9.45 compression, Ported head, 274/480 cam, roller rockers, High volume water pump/ thermostat housing, 00 intake with 64mm TB, TB spacer, Live wires
Kilby OBA
HydroBoost braking set up
PSC ram steering with cooler
KOZ Hi steer
KOZ SOA set up using Alcan springs
5150 Bilstein shocks
KOZ Stretched Wheelbase
Spray lined 360*
Mastercraft seats front and rear with Harnesses
TNT armor
Warn 9500
Dual Optima`s
200 Amp alternator
KOZ Full cage with frame tie in kit
In cab fuel pressure gauge
Wide Band 02 sensor for reading A/F ratio
Piaa x 4
Electric fans
3 row HD radiator
KOZ rear bumper/tire carrier with reverse lights
MORE 1" BL
TNT tube fenders, sliders
Mustang GT fuel pump
JKOZ is offline   Reply With Quote
Old 03-01-2007, 06:46 PM   #2
JKOZ
Member # 12463
Old 03-01-2007, 06:58 PM   #3
wes8517
texASShole
wes8517's Avatar
Member # 14196
Send a message via AIM to wes8517 Send a message via MSN to wes8517 Send a message via Yahoo to wes8517
you said its a springover but it still looks sprung under to me?!?
Nothing worth noting here
wes8517 is offline   Reply With Quote
Old 03-01-2007, 07:02 PM   #4
akozman
akozman's Avatar
Member # 11905
good eye balls, it was brought up spring under and will be converted to SOA.
2000TJ - Rock Jock 60s & More stuff.
akozman is offline   Reply With Quote
Old 03-02-2007, 08:24 AM   #5
matts88yj
YJ Junkie
matts88yj's Avatar
Member # 62615
Send a message via AIM to matts88yj
Very nice!!! I think I saw this build going on over on JU but I cant remember or not. That is probably one of the cleanest looking stroker engines I have ever seen! Gotta love the sleepers!!! Also could you post up a pic of the 8.8 with the truss? Im considering getting one installed on my 8.8 and wanted to get a better angle at it if you can. If not no biggie. Thanks and keep up the great work!
Matt
Anger Management Motorsports
#474 Spotter / Co-Driver
matts88yj is offline   Reply With Quote
Forum Jump
