Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Miscellaneous > General Chit-Chat
Old 03-04-2007, 09:01 PM   #1
comeonstart
comeonstart's Avatar
Member # 49939
Send a message via AIM to comeonstart
Need some help with a school project
Hey guys if any of you get a chance would you mind filling out the survey that best pertains for you. The results are due in the morning and I havent had much luck getting results.
If you are in a long distance relationship, answer the first set of questions. If you have ever been in a long distance relationship, but are not currently in one, answer the second set of questions. If you are in a relationship, but it is not long distance, answer the third set of questions. If you are not in any sort of relationship, answer the fourth set of questions.
After you are done answering your appropriate section, please copy and paste the questions and answers and message them back to me.
1st Set
1) How old are you?
2) Are you a male or female?
3) Would you classify yourself as a: freshmen, sophomore, junior, or a senior?
4) How long have you been in your long distance relationship?
5) What is your opinion of long distance relationships?
6) How far away (answer in hours of driving) are you two apart?
7) How often do you get to see your partner?
8) Do you feel that long distance relationships cause more stress? Please explain your answer.
9) How would you rate your overall stress level on a scale from 1 to 10 (1 being the lowest and 10 the highest)?
10) Do you feel that the long distance relationship has affected your academics?
11) How would you rate your trust level with your partner on a scale from 1 to 10 (1 being the lowest and 10 the highest)?
12) If you could do it all over again, would you still pursue the long distance relationship that you have now?
13) Do you ever see yourself pursuing another long distance relationship?
14) What has been the hardest thing about your long distance relationship?
15) Do you and your partner make set times to talk or to hang out?
16) If yes, does this help?
17) Do you think long distance relationships affect college students’ grades?
18) Do you think long distance relationships affect college students stress levels?
Thank you for taking the time to fill out my survey!
2nd Set
1) How old are you?
4) How long were you in your long distance relationship?
6) How far away (answer in hours of driving) were you two apart?
7) How often did you get to see your partner?
9) How would you rate your overall stress level on a scale from 1 to 10 (1 being the lowest and 10 the highest) while you were in the long distance relationship?
10) How would you rate your overall stress level on a scale from 1 to 10 (1 being the lowest and 10 the highest) while you are currently not in a long distance relationship?
11) Do you feel that the long distance relationship that you were in had an affect on your academics?
12) How would you rate your trust level that you had with your partner when you were in a long distance relationship on a scale from 1 to 10 (1 being the lowest and 10 the highest)?
13) What was the hardest thing about your long distance relationship?
14) Could you ever see yourself in another long distance relationship?
15) Did you and your partner make set times to talk or to see each other?
16) If yes, was it beneficial?
3rd Set
1) How old are you?
4) How long have you been in your relationship?
6) Do you feel that long distance relationships cause more stress? Please explain your answer.
7) How would you rate your overall stress level on a scale from 1 to 10 (1 being the lowest and 10 the highest)?
8) Does your relationship have an affect on your academics?
9) Do you think long distance relationships would have an affect on your academic performance?
10) How would you rate your trust level with your partner on a scale from 1 to 10 (1 being the lowest and 10 the highest)?
11) Do you think that your trust level would be lower if you were in a long distance relationship? Explain why or why not.
12) Could you ever see yourself in a long distance relationship? Why or why not?
13) What would you do if your partner had to move away? Would you break up with him/her, work it out, go on a “break”, the relationship would remain the same, or other?
14) What do you think the hardest thing would be about the long distance relationship?
15) Do you think long distance relationships affect college students’ grades?
16) Do you think long distance relationships affect college students stress levels?
4th Set
1) How old are you?
4) What is your opinion of long distance relationships?
5) Do you feel that long distance relationships cause more stress? Please explain your answer.
6) How would you rate your overall stress level on a scale from 1 to 10 (1 being the lowest and 10 the highest)?
7) Do you think long distance relationships would have an affect on your academic performance?
8) Could you ever see yourself in a long distance relationship? Why or why not?
9) What do you think the hardest thing would be about the long distance relationship?
10) Do you think long distance relationships affect college students’ grades?
11) Do you think long distance relationships affect college students stress levels?
Obama - Just another black man living in government housing
comeonstart is offline   Reply With Quote
Old 03-04-2007, 09:43 PM   #2
Pazuzu
Member # 54
What if I'm currently in a relationship, was once in a long distance relationship, and this relationship was once a long distance relationship??
Do I have to answer sections 1, 2 AND 3???
That's too damned much, do your own homework.
Pazuzu is offline   Reply With Quote
Old 03-04-2007, 09:56 PM   #3
Mo
Everyday is Tuesday.
Mo's Avatar
Member # 47
just do what Paz does. invent your data.
nothing on ebay
justadad
Mo is offline   Reply With Quote
Old 03-04-2007, 10:41 PM   #4
apeters89
Moderator
apeters89's Avatar
Member # 7647
how do you answer if you're not in school?
KF5EQF
Big thanks to www.rwkhaussupply.com
apeters89 is offline   Reply With Quote
Old 03-04-2007, 11:27 PM   #5
Shawnboy
Get that into ya.
Shawnboy's Avatar
Member # 9545
Needs bacon.
That which implies the stated or presumed acceptance of a single standard a person claims to hold themselves accountable to, but which in practice may be disregarded is a double standard.
Shawnboy is online now   Reply With Quote
Old 03-05-2007, 06:42 AM   #6
Pazuzu
Member # 54
My data is real purdy like...
Old 03-05-2007, 03:12 PM   #7
comeonstart
Member # 49939
Thanks to all who filled one out.
I could fake them, but when I do that they pretty much turn out exactly the same.
Old 03-05-2007, 03:24 PM   #8
ev13wt
evil twit
ev13wt's Avatar
Member # 52443
1st Set
1) How old are you?29
2) Are you a male or female?both
3) Would you classify yourself as a: fnone
4) How long have you been in your long distance relationship? 0
5) What is your opinion of long distance relationships? fuck that
6) How far away (answer in hours of driving) are you two apart? huh?
7) How often do you get to see your partner? daily if i want
8) Do you feel that long distance relationships cause more stress? Please explain your answer. no
9) How would you rate your overall stress level on a scale from 1 to 10 (1 being the lowest and 10 the highest)?10
10) Do you feel that the long distance relationship has affected your academics? yes
11) How would you rate your trust level with your partner on a scale from 1 to 10 (1 being the lowest and 10 the highest)?2
12) If you could do it all over again, would you still pursue the long distance relationship that you have now? no
13) Do you ever see yourself pursuing another long distance relationship? webcam
14) What has been the hardest thing about your long distance relationship? ?
15) Do you and your partner make sex times, talk or to hang out? yup.
16) If yes, does this help? yup
17) Do you think long distance relationships affect college students’ grades? yea really, totally dude, i'm stressed.
18) Do you think long distance relationships affect college students stress levels? see above answer.
Thank you for taking the time to fill out my survey! xxx
Matte Black TOYOTA 86 4Runner // Technics ST-9600 - RS-1506 - Turntable BL3 Linear - to SU-8600 as preamp into 2x SE-9060 driving SB-6000s. From 1977.
Originally Posted by Chris
You got it wrong. Here, the retards are locked in.
ev13wt is offline   Reply With Quote
Old 03-05-2007, 03:28 PM   #9
Bobzooki
Member # 9419
So, I have to answer the first, second, AND third sets of questions?
EDIT: Oh, wait - just the first and third?
Bob
Thus spake the village idiot.
Bobzooki is online now   Reply With Quote
Old 03-05-2007, 03:33 PM   #10
ev13wt
evil twit
ev13wt's Avatar
Member # 52443
yea, i fawked that up too.
but i "did the survey"...
Old 03-05-2007, 03:47 PM   #11
Bobzooki
Member # 9419
Well, do I have to fill out section one for each long-distance relationship I'm in, and section three for each local relationship I'm in?
Bob
Old 03-05-2007, 09:10 PM   #12
wranglerboy93
Member # 49547
Send a message via AIM to wranglerboy93
1) How old are you? 19
2) Are you a male or female? MALE
3) Would you classify yourself as a: freshmen, sophomore, junior, or a senior? FRESHMAN
4) How long have you been in your long distance relationship? 5 MONTHS
5) What is your opinion of long distance relationships? Very tough to keep going
6) How far away (answer in hours of driving) are you two apart? 20-22 hours
7) How often do you get to see your partner? 1 time in 5 months
8) Do you feel that long distance relationships cause more stress? Please explain your answer. Yes right now I feel like I want the relationship to be over so I am stressing alot more then usual. It also doesn't help it's a weird relationship where I tell one girl I love her yet go out on the weekends and drink and hook up with other girls.
9) How would you rate your overall stress level on a scale from 1 to 10 (1 being the lowest and 10 the highest)?7
10) Do you feel that the long distance relationship has affected your academics?Not really maybe sometimes if I'm thinking about her to much
11) How would you rate your trust level with your partner on a scale from 1 to 10 (1 being the lowest and 10 the highest)?10 she can't find anyone as good as me apparently
12) If you could do it all over again, would you still pursue the long distance relationship that you have now?I highly doubt it
13) Do you ever see yourself pursuing another long distance relationship?Nope
14) What has been the hardest thing about your long distance relationship? keeping the feelings alive when you kind of don't want to anymore but think they might be the one
15) Do you and your partner make set times to talk or to hang out?Yes usually at night after class and tv time
16) If yes, does this help? Sorta
17) Do you think long distance relationships affect college students’ grades?Most likely
18) Do you think long distance relationships affect college students stress levels?Again most likely yes
wranglerboy93 is offline   Reply With Quote
Forum Jump
