Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > Tow Rigs and Trailers
Old 03-24-2007, 10:01 AM   #1
Renaud33
Renaud33's Avatar
Member # 23389
Send a message via AIM to Renaud33
axle bearing preload
I searched and it didn't work. Problem with pirate or my computer connection? I also looked at the trailer tech information and couldn't get the Dexter axle information links to work.
What is the procedure for setting the bearing preload? Bearing size is 1-3/8". I am sure the procedure is very similar to setting the wheel hub bearings on my Toyota axle.
Thanks
85' 4Runner - AP extreme lift, 37" PB Rockers, duals
88' 4Runner SR5 - current project
97' Tacoma - 2.5" OME lift
TLCA Member# 16265
Renaud33 is offline   Reply With Quote
Old 03-24-2007, 12:35 PM   #2
BillaVista
Web wheeler/welder
BillaVista's Avatar
Member # 3547
Two methods from: http://www.pirate4x4.com/tech/billav...er/Trailer.htm
Method 1
6. You are now ready to slide the hub or hub drum onto the spindle. Clean the spindle with a rag. (NOTE: The inner surface of the bearing and the spindle shaft are machined to close tolerances. If the spindle is marred, unclean, or if the rear bearing is not square with the spindle shaft, the bearings may temporarily hang up as you slide the hub in place. Once the hub or hub drum is fully in place on the spindle, slide the outer bearing onto the spindle and into the hub. (Match the cone of the bearing to the race. DO NOT INSTALL THE BEARINGS BACKWARD!
7. At this point you are ready to pre-load the bearings. Whenever you install new hubs onto an axle, or whenever you install new bearings and races into existing hubs, you should pre-load the bearings. Pre-loading the bearings assures that the races in the hub are 100% in place against their machined stop points and keeps the hub from wobbling after a few miles.
8. To pre-load the bearings, install the spindle washer and spindle nut onto the spindle with the hub and bearings in place. Tighten the spindle nut finger tight (until snug) and then with channel-lock pliers or a crescent wrench, tighten the spindle nut another 1/4 turn or about 15 to 20 ft pounds of torque. Now turn the hub five to ten revolutions. This will fully seat the races. Now loosen the spindle nut very loose, then re-snug to finger tight, and engage the nut retaining device. (Some reverse lubricating spindles use a tab washer for the retaining device)
9. After 20 to 40 miles of highway travel, check to see if the hub is loose on the spindle. Pull the tire in and out a few times. If your hub is loose, you will need to re-snug the spindle nut and re-engage the nut retaining cotter pin or tab washer. NOTE: Never reuse the same tab on the tab washer. They are designed to be used one time only).
Never run your spindle nut to tight, this will cause your bearings to over heat. And never run your bearings too loose. A very slightly loose spindle nut will run adequately, but too loose and the individual rollers may come apart in the bearings, causing the hub to fracture.
You are now ready to install your dust cap. A short piece of 2" I.D. water pipe makes a good tool to install either a plain dust cap or the SPINDLE-LUBE® dust cap for the 3500# axle.
If you are installing brakes on a "plain" spindle axle, we recommend that you use plain dust caps and not "bearing protectors" (Bearing protector refers to the spring loaded dust cap device with a grease zerk fitting in the piston.) Bearing protectors add two to four PSI of pressure inside the hub cavity and in many cases, they cause grease to leak past the seal. If sufficient grease leaks past the seal on a brake hub drum, it will centrifuge out with some grease getting on the brake shoes. Grease on your brake shoes will drastically decrease your braking capacity.
Method 2
If the hub has been removed or bearing adjustment is required,
the following adjustment procedure must be followed:
1. After placing the hub, bearings, washers, and spindle nut
back on the axle spindle in reverse order as detailed in the
previous section on hub removal, rotate the hub assembly
slowly while tightening the spindle nut to approximately
50 lbs.-ft. (12" wrench or pliers with full hand force.)
2. Then loosen the spindle nut to remove the torque. Do not
rotate the hub.
3. Finger tighten the spindle nut until just snug.
4. Back the spindle nut out slightly until the first castellation
lines up with the cotter key hole and insert the cotter pin (or
locking tang in the case of E-Z Lube.)
5. Bend over the cotter pin legs to secure the nut (or locking
tang in the case of E-Z Lube)
6. Nut should be free to move with only restraint being the
cotter pin (or locking tang.)
BillaVista is offline   Reply With Quote
Forum Jump
