Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 05-01-2007, 09:42 PM   #1
85mudblazin
85mudblazin's Avatar
Member # 42745
Send a message via AIM to 85mudblazin
Front 3 link upper link location
I am about to start my front links and I cant figure out which side to put the upper link on. I have a passenger drop d60 so should it be on the diff side or does it not really matter??
I have seen it both ways and dont see how one would be better then the other.
Thanks
-Chris
85' Truggy
Links, stickies, etc.
[url]www.KrawlTex.com[/url]
-Chris
85mudblazin is offline   Reply With Quote
Old 05-01-2007, 10:13 PM   #2
Bubba_Jeep
Oldnewbie
Member # 37184
I see you have a red star, so I suggest you search. There is literally a ton of post concerning 3-link set up. I would only br regurgitating what I've read here.
88XJ, Chevy 5.7L, Edelbrock MPFI, NV4500, Atlas, D44's, high steer, ARB's, 7" custom short-arm lift, BFG 33x12.5-15's.
Bubba_Jeep is offline   Reply With Quote
Old 05-01-2007, 10:30 PM   #3
85mudblazin
Member # 42745
You dont think I searched?? I have not found one thing that says why to put it on one side or the other. I have found hundreds of people that have done it on both sides.
I just want to know if there is a reasoning behind either side.
85' Truggy
-Chris
Old 05-02-2007, 12:38 AM   #4
Spike5421
Member # 10411
Send a message via AIM to Spike5421
It makes sense to me to put it on the side with the pinion to make sure that your angle does not change causing damage. But if that won't work the middle of the axle is a good place if you are going to run a wishbone style upper link.
82 Cj7 (SOLD)
'04 4wd Taco, S/C, Allpro 3.5", 4.88 gears, ARB bumper, Warn, rocker guards.
Spike5421 is offline   Reply With Quote
Old 05-02-2007, 12:51 AM   #5
FISHMOUTH FABWORKS
PARIS'
FISHMOUTH FABWORKS's Avatar
Member # 43776
Send a message via Yahoo to FISHMOUTH FABWORKS
It must go on the diff side to keep your pinion from rotating. if you run a wristed arm on both sides it binds. just 2 on the diff side and one on the other.
Dan Trout- Dave Halabuk RIP
Why does everyone have tig welding avatars? Don't you know Gas welding is where it's at
FISHMOUTH FABWORKS is offline   Reply With Quote
Old 05-02-2007, 02:57 AM   #6
Bubba_Jeep
Oldnewbie
Member # 37184
Well, don't know what you used for search "argument", but they're there. Based on what I've gleaned from the various posts, you can put it on either side, BUT, your attachment points at the frame-end are at different heights, depending on what side they're located. The angles of the arms differ in order to get "ant-dive" correct, and to keep from raising the passenger-side tire, if you mount the UCA on the driver's side.
Old 05-02-2007, 03:27 AM   #7
Bubba_Jeep
Oldnewbie
Member # 37184
Here's a couple of threads to get you started.
http://www.pirate4x4.com/forum/showthread.php?t=534764
http://www.pirate4x4.com/forum/showt...ht=track+mount
http://www.naxja.org/forum/showthrea...t=3+link+front
Old 05-02-2007, 06:11 AM   #8
vetteboy79
Pigs fly!
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
Huh?
Plenty of people run a 3-link on the opposite side of the diff.
Two wristed arms won't bind, you'll just have no wrap or braking control. One wristed arm works fine in a radius arm setup, and a 3-link has no wristed arms anyway because it doesn't need it.
'94 XJ with 4.6 stroker, NV4500, NP231doubler/D300, D60/14B, 4.56s and Detroits, 38.5 Creepies, 4-link rear & 3-link w/panhard front, dual roll cages. FOA coilovers all around. bacon express
TELLICO RALLY POST #18
vetteboy79 is offline   Reply With Quote
Old 05-02-2007, 08:56 AM   #9
TRD
TRD's Avatar
Member # 8286
I have posted a bunch of times about which side to put it on.
Here it goes again:
By having one upper you can use it to counteract driveshaft rotation torque. But the front suspension is really loaded in braking and not acceleration. So there isnt any significant driveshaft rotation torque to counteract. Even in 4wd it really isnt that big of a deal. So put it where it fits. Does NOT have to be on the same side as the pinion.
TRD is offline   Reply With Quote
Old 05-02-2007, 12:37 PM   #10
85mudblazin
Member # 42745
Thank you
85' Truggy
-Chris
Old 05-02-2007, 12:48 PM   #11
Keith
Rock Zombie Smurf!
Keith's Avatar
Member # 52
Here it goes again:
There has to be some kind of driveshaft torqe, esp when the rear output is disco'd. So if that were the case, which side would be better to counter act the torque?
Keith is offline   Reply With Quote
Old 05-02-2007, 12:58 PM   #12
vetteboy79
Pigs fly!
vetteboy79's Avatar
Member # 31621
In a high-traction situation, if I go in reverse in front-wheel-drive only and really get on it, I can get some decent torque jacking out of mine. That's the extent that I've noticed it.
Old 05-02-2007, 01:12 PM   #13
OX
Member # 3113
Here it goes again:
Main reason I like it on the pinion side is you can truss it to spread that load out and also keep the tubes from spinning all in one shot.
74 Bronc build, 351w/C6/Black Box/205/406 mogs/42 SX's (I can dream on the SX's, right!!!!)
78 Bronco Custom, 460/T-18/14 bolt/D60 w/4.56's, detroits/44" Boggs (the mudder.......)
79 Bronc XLT, 400/C6/404 Mogs/42 roks
OX is offline   Reply With Quote
Forum Jump
