Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Ford
Old 05-18-2007, 09:01 AM   #1
Blown349
Member # 85036
Ride height for serious rock trails???
Title pretty much gets it. If you are a rock crawler (Qualified by 5+ or 10's on both rating scales for trails), with a wheel base of 100-110", How high is your belly pan, skids, center or break over point???? I got around 9" of lift.
I think I am a little high in a big rig and could lower it some by raising spring/shock mounts. No fenders so I got room for the wheels to travel up! 39.5 Iroks.
With the big meats:
More done on the exo/ino cage and street meats:
Da "Carcass"
Built by Swat.
[url]http://www.supermotors.net/vehicles/registry/3612[/url]
Blown349 is offline   Reply With Quote
Old 05-18-2007, 10:49 AM   #2
fuggy
Member # 80664
belly clearance
The best belly clearance height depends on wheels size, but most hard core guys are running 40" tires with a belly clearance of 28"-30" works great. Down-travel is more important than up-travel.
fuggy is offline   Reply With Quote
Old 05-18-2007, 12:42 PM   #3
michigander
michigander's Avatar
Member # 8402
39.5 boggers with a 21" belly here, 108" WB.... front susp has 8.5" droop, 5.5" comp at static height, rear has 5" droop, 7" comp at static.
-Ford 3.8L supercharged buggy
-1999 F250 Stroker
michigander is offline   Reply With Quote
Old 05-18-2007, 02:10 PM   #4
Gummi Bear
Member # 26216
Send a message via Yahoo to Gummi Bear
21" belly height on 38's, 3" of lift on an EB. I'm shooting for no suspension lift on my wife's, with 36" Iroks. I'll be using 3" lift springs, but raising the mounts making everything nice and low with lots of flex potential.
Build good skid plates, and keep it nice and low.
[SIZE=2][b]His - [COLOR="DarkOrange"][o===o][/COLOR] 1976 Bronco
Hers - [url=http://classicbroncos.com/forums/showthread.php?t=81955][color="DeepSkyBlue"][[/color]o[color="DeepSkyBlue"]===[/color]o[color="DeepSkyBlue"]][/color] 1968 Bronco "Doodlebug"[/b][/SIZE][/url]
[SIZE="1"] [URL="http://www.lonestar-ebc.com/LEBCPortal.asp"]Lonestar Early Bronco Club[/URL][/SIZE][SIZE="4"]
[URL]http://www.endeavorbaja.com[/URL][COLOR="DarkOrange"]
[CENTER][URL="www.reidracing.biz"][B]Reid Racing, Inc. - Dedenbear Products [/B] [/URL] [/COLOR] (925) 935-3025 [/CENTER][/SIZE]
Gummi Bear is offline   Reply With Quote
Old 05-18-2007, 08:43 PM   #5
Proeliator
Under your bed.
Proeliator's Avatar
Member # 12042
Send a message via Yahoo to Proeliator
Low GOG is your friend. That said, your ride height doesn't look exceptionally ridiculous. I'd say run it if it works on your trails. You start dumping it over or on its side then lower it.
Originally Posted by 94stepsideford View Post
Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.
'73 F-250, 533 on N2O, 35spln Superior/CTM D60/D70U, twinsticked, hydro-assist, f&r lockers, 45" Titan R1s, rear mount rad, etc. Vid: YouTube - bad ass ford
http://www.myspace.com/proeliator_rex
Proeliator is offline   Reply With Quote
Old 05-18-2007, 08:53 PM   #6
wtr40rock
Member # 85265
the lowest point on my truck with rockwells and 42's is ~22" depending on my tools and occupants.
the beatings will continue until morale improves.
wtr40rock is offline   Reply With Quote
Old 05-19-2007, 12:40 AM   #7
Danger Ranger
OMG! Flying Mini Van
Danger Ranger's Avatar
Member # 1234
112" wb
42" tires
23" belly
30" slider
80" height (but with 4-6" of head room in relation to tubing)
sorry, I'm on my laptop and this was the best pic I could find of the "right" angle
2010 KOH/LCQ Team #1911
Aaron Beckstead/Rick Bailey
www.DangerRangerRacing.com
2010 Sponsors!
Tarlton and Son 4 Wheel Parts-Cleveland Ohio Susanville Transmission Bobby Walter Reid Racing Dennis and Son Trucking Automatic Gates by Morgan URJB Friends and Family! Dysfunctional Rockcrawlers
Danger Ranger is offline   Reply With Quote
Old 05-19-2007, 12:50 AM   #8
WHITE RHINO
Member # 71446
haaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa!
Need Fab Work in the South Bay? E-mail me at Defiantmotorsports@yahoo.com
section8krawlers.com
WHITE RHINO is offline   Reply With Quote
Old 05-19-2007, 11:24 PM   #9
crawldaddy
crawldaddy's Avatar
Member # 50098
I dont know of many people running 28"-30" under the belly With 40's 20" under the belly is good with a flat smooth skid plate..
crawldaddy is offline   Reply With Quote
Old 05-19-2007, 11:46 PM   #10
lil-bronc
lil-bronc's Avatar
Member # 21881
I currently am running a 113" wheel base, 3" farther than what you asked for. I am running 23" belly and a total hieght of 78". I am running full width axles and the buggy is only 52" at its widest point. I have figured my CG point is about 30". I am running 39.5" IROKS.
302 on propane, 42" Grooved TSLs, HP D60 & True-Hi 9" Detroit lockers w/4.88's, Alloy 35 spline, CTMs, StaK 2 speed, 4 seater.
Just trying to keep up with the Jones'.
lil-bronc is offline   Reply With Quote
Old 05-21-2007, 08:50 AM   #11
Blown349
Member # 85036
Thanks for the replies! The responses I got here and another board range from 20 to 25" My rig is at about 25". I think it is a little high but I will wait till I wheel it more. It will get a four link rear later and I will probably wait until then to lower it a 3 or 4".
Da "Carcass"
Built by Swat.
Old 05-21-2007, 11:24 AM   #12
michigander
Member # 8402
FYI- here is a pic of 20" belly
-1999 F250 Stroker
Forum Jump
