Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Classifieds > Axles/Tires/Wheels For Sale
Old 05-21-2007, 11:56 AM   #1
Pete M
Member # 65911
~60" wide rear Dana 44 with disks, 4.30 gears, 6-on-5.5"
Out of a 97 Isuzu Rodeo with 77k miles. Perfect match for a Grand Waggy front end. It's a Dana-44 that's about ~60" wide, open diff, disk brakes, 4.30 gears, 6 on5.5" bolt pattern. Disks/pads/rotors seem to be in good shape. Dust guards are removed. ring-pinion.com carries LP Dana-44 4.27 gears in case you're wondering about matching the 4.30 ratio to your Waggy front axle. It has a flange yoke, but that can be swapped for a U-joint yoke. The vehicle I got this from didn't have a driveshaft, so tomorrow I hope to hit up the pull-your-part and see what exactly this flange bolts to and if it's of any use.
Asking $275.
I'm located in 48193, just south of Detroit, Michigan. Delivery is possible out to 4 hours away if you pay for gas (and only for gas, my time is free). Shipping is also possible if you're further away. Shipping ranges from $90-120 depending on where in the country you are.
Thanks,
--Pete
Pete M is offline   Reply With Quote
Old 05-21-2007, 07:52 PM   #2
Pete M
Member # 65911
I'm traveling from Detroit to Chicago to Springfield IL on Thursday or Friday.
--Pete
Forum Jump
