#1 |
Member # 32468
more oil filter options
I hope this isnt R
Motorcraft FL-1A or equivelant will fit a 22RE...The filter holds well over half a quart and has a silicone anti-drainback valve. The FL-1A is on just about every Ford RWD V8 and RWD V6 from late 90s and back. If the FL-1A is too long for your application there is also the FL-300 that is about 2 inches shorter and was used on 5.0 cobras in the early 90s
Ford for employment-Toyota for enjoyment HeavyE Fourdice4x4.com Last edited by shooter; 05-26-2007 at 10:39 PM. |
#2 |
Cranky B.F.U.M. Mod
Looks the same size as the Fram PH8a and others. I run the same filter in a Napa gold, it also has the silicone drain back, or I use stock toy filters
85 Toy Xtracab "I DON'T want to understand !!" Click here to donate to the Rubicon Trail Foundation Rubicon Trail Foundation Rubicon Trail Patrol Rock-N-Roll 4X4 Club "Wow this is unbelievable" |
| Sponsored Links |
#3 |
Member # 53227
wix 51515
#4 |
Member # 6726
How is the start up rattle with the ford filter? My timing chain rattles like hell most over night starts even with the Toy filter. Motor is fresh and makes great oil pressure once it gets the filter full. Just seems to drain no matter what. I think it is pulling back through the pump. For some reason its not as bad when it is pointed nose down on a hill.
I am thinking about going to a remote filter so I can have the filter vertical. Add a oil cooler at the same time. Buddy has been trying to talk me into Amsoil (he is a dealer) remote set up for a while.
[COLOR="Black"]Did you expect to find something deep and meaningful here?[/COLOR] "He has all the virtues I dislike and none of the vices I admire." -- Winston Churchill |
#5 |
Member # 102
the napa gold filter is a wix filter. pretty good filter
#6 | |
Member # 64421
Paper is a mortgage on wealth that does not exist, backed by a gun aimed at those who are expected to produce it. |
#7 |
Member # 32468
yes PH8A is the fram equivilant to a motorcraft FL-1A...i work a a ford dealer so motorcraft filters are redily avalible..
Ford for employment-Toyota for enjoyment HeavyE Fourdice4x4.com |
#8 | |
Member # 32468
#9 | |
H.A.N.U.
Member # 20631
No sig for you! |
#10 |
Member # 2537
I may be remembering wrong but if I remember correctly in the 80s Toyota sold the same size filter as the FL-1A. Sometime in the early 90's it was dropped and went to the smaller filter.
KAJOBUILT Authorized dealer for the following companies: Corbeau Seats, Pitbull Tires, Trail Gear PM me, email me at kajo@kajobuilt.com for quotes and or orders SFC, US Army (Retired) Cancer Survivor since 2002 |
#11 |
Member # 6726
Toyota
#12 |
Member # 74042
call me a snob i run lexus filters immported from Japan
It's a Jaap thing....You wouldnt understand |
#13 | |
Member # 1088
1st place Pro-Mod WEROCK WORLD Champion Diamond Axle http://www.diamondaxle.com Diamond axled buggies take 2 1st's, at Worlds WEROCK!! Front Range Off-Road Fab with NEW forum! http://www.frontrangeoffroadfab.com NEW BUILD FTOY #44 http://www.pirate4x4.com/forum/showthread.php?t=562295 |
#14 | |
Book em Dano
Member # 233
if you're looking for a basic oversized Ford filter, the number would be 85515 CARQUEST, 51515 NAPA. That's been the basic small block Ford V8 filter for nigh on 20 years...5.0L, 5.8L, even the 300c.i. straight six used it. Do me a favor though, although they're all the exact same WIX filters,
The Weather Is Here , Wish You Were Beautiful |
#15 |
Member # 47072
I was wondering the same. I thought the smaller ones were better.
#16 |
Member # 53319
napa/wix , motorcraft all great filters
fram is garbage
84 22R 4x4 X-Cab G52 4.10s SR5 |
#17 | |
Turtle SALE
Member # 5579
I run factory Toyota filters. Been doing it for years. BigMike
HAVE YOU CHECKED OUT THE MARLIN CRAWLER END OF THE YEAR SALE? Marlin Crawler 4.70:1 Xtreme Duty Gear Set is here! The Success of the Marlin Crawler | Support The Rubicon Trail Foundation | 1981 Hilux, 3RZ, Triple Marlin Crawler, 511:1 |
#18 |
www.12voltguy.com
Member # 40
10+ year old RRRRRRRRRRRRRRRRRRRRR,,,,,,lol
LOTS of GUNS 4sale ! 12voltguy.com / ![]() Click here to email me New # 530.532.4529![]() http://www.davezoffroadperformance.com/ OFN Fab BB -89 1 ton bronco on 47" LTB's-![]() Hard work often pays off after time, but laziness always pays off right now. |
#19 |
Cranky B.F.U.M. Mod
Why is Fram Garbage? Everyone says that. Let's have some real data to back it up. Never seen any myself, just statements on the internet. Are there any real lab tests that show they won't last an oil change interval?
#20 | |
www.12voltguy.com
Member # 40
how bad could thery be?A guy cut a bunch up, showed that they glue the cardboard filter eleiment & it wasn't secured well enough letting particles get by, why 99% of the people do not know is motors have a bypass mode, & either on start up or when filter starts to restrict............yes it bypasses the filter, it may even part bypass at higher pressure, all IO know is the filter is not working 100% of the time, all the time I HAVE RUN FROM FOR 25 YEARS, NOT SEEN 1 CASE WHERE THE FILTER WAS THE CAUSE OF ENGINE FALUIRE
#21 |
All we use at work is fram unless you specify otherwise "motorcraft,mopar"
Have not had a single issue of failure due to a bad filter......yet.
I have no idea what the fawk I'm doing:homer: |
#22 |
Member # 1088
Cut open a fram, and a wix. Check out the filter element. Im not saying fram is junk, I just see wix being much better. The real question, is the better necassary? Who knows, but I like the anti drain back of the wix for the timing chain, and more surface area in the filter.
| Thread Tools | |
| Display Modes | |
