#1 |
Member # 80590
monday ?
my 22re at startup is running rough, sputtering. i parked it before i went away on my trip. it sat for 5 days. i just recently swapped in the new complete engine. its been running great up until this morning when i got in it to go to work. i made it to work but bairly. its lagging power big time and the exhaust sound totally different from ever before. sounds like a quieter lawn mower when revving it up. it revs up fine with no sputter but sounds weird! like maybe its missing or something. it was struggling to make it up hills that it should have no problem with. its take forever to get up to speed. and taking off from a stand still is the worst. like i rev it up start to let the clutch out and it starts going like everything would be fine but it starts sputtering and shit almost as if it isnt getting enough fuel, but if it just wasnt getting enough fuel like a bad fuel filter then why was it fine when i parked it 5 days ago and why would it run at all now. the spark plugs are tight, and all wires are connected.
any suggestions? |
#2 |
Pirate4x4 Addict!
Member # 30
Location: Roseville, CA,To many Yuppies, Not enough Hippies
Fuel filter or clogged cat is where I would start. Is your Gerbil missing?
David & Theresa, Roseville, CA, Excellent Parts Source http://www.davezoffroadperformance.com/ http://www.marlincrawler.com/ http://www.12voltguy.com/web/ |
| Sponsored Links |
#3 | |
Member # 80590
i have straight back exhaust off the header with a brand new oem muffler |
#4 |
Member # 80590
im at work right now but just went to mess with my truck again. where is the fuel filter located?
#5 |
Member # 3154
Maybe distributor is loose?
HomeGrown Racing XRRA Team #36 sleeoffroad.com marlincrawler.com pitbulltires.com homegrowninc.us |
#6 |
4xInnovations.com
What we have here is a sever case of the Mondays. Let your truck sit until tomorrow.
Or check the fuel filter, located on the pass side block below the intake. How far did you drive it and did it seem to get worse? I had a filter clog up from being able to drive 55mph to only being able to crawl with in about 5-10 miles.
4x Innovations - Quality Custom Toyota based tube products at a fair price
Check out the 87 Runner trail rig. -Adam- 1-608-348-4880 |
#7 |
Member # 80590
nevermind i figured it out! 4th cylinder plug wire was grounding out on the header.
#8 |
Member # 3154
Thats what you get for not running the factory wires with the keepers!
| Thread Tools | |
| Display Modes | |
