Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Suzuki
Old 07-01-2007, 07:58 AM   #1
ftoy507
Member # 92235
No front wheel drive
I have the petroworks 4.89-1 transfer case with the split H pattern. Petro did the entire build up of the case. Yesterday, in a competition my front end quit pulling. Making it impossibnle for me to close the gap on second or first place.
When the front quits pulling
I still have rear wheel drive
I am still in low 4 with only rear wheel drive
The lever is not bumping the sheet metal
To get the front end to pull again I have to shift into 4wd then select low or hi
At first int only happened about every 20-30 ft, by the end of the day it was every 5-8 feet
Has anyone seen this problem? Is the split H any good? Or is it a weak link. My guess is it is the modification or removal of the detent ball causing this.
ftoy507 is offline   Reply With Quote
Old 07-01-2007, 08:06 AM   #2
moveaside
moveaside's Avatar
Member # 11983
Has this been going on since you installed it or did it start yesterday?
I'll kick the shit out of you if I find you throwing trash out on the trail!
My crappy build
[url]http://www.pirate4x4.com/forum/showthread.php?t=587635[/url]
moveaside is offline   Reply With Quote
Old 07-01-2007, 08:15 AM   #3
bogger61
Member # 37182
You may have broke the little end on the front out put gear let it move around under load.
88.5 sami,stock type4
bogger61 is offline   Reply With Quote
Old 07-01-2007, 08:56 AM   #4
weedwacker
NOOB
weedwacker's Avatar
Member # 15945
I'll bet you have a bent front output shaft. It can bend just a tiny bit and cause the problems you describe. It is vert difficult to see the bend, you almost have to remove the gear put it in some "V" blocks and check it for runout.
Dodge 3500 cummins tow rig, toy axled zuk 2.0 powered, 160:1+ home brewed buggy, DR650 two wheeler, Piper Cherokee daily flyer
weedwacker is offline   Reply With Quote
Old 07-01-2007, 06:15 PM   #5
ftoy507
Member # 92235
Problem started last week on a trail ride. I broke a transfer case mount and had to limp back to the trailer. I will be tearing it down this week. Any additional things to look for?
Old 07-02-2007, 06:01 AM   #6
moveaside
moveaside's Avatar
Member # 11983
Well go get some hard facts and tear the thing apart before you post up all mad at Petroworks. Small companies like that live and breath on a good reputation. So to answer the question is that a smaller pre 90's front output shaft you have in there? I don't see any mention of changing that out on their website. Hell it should be your responsibility anyhow to ensure that is done not them anyhow.
Reference
http://www.trail-gear.com/zuk-tcasegears.html
My crappy build
Old 07-02-2007, 08:13 AM   #7
ftoy507
Member # 92235
I am not mad at petroworks. The case has survived over two years of hardcore abuse.
I am trying to find out if anyone has ever had a problem with the split H or is it typically the detents. I never thought the shaft would cause this. Also I wanted to know more of what to look for.
So thanks for the input.
Old 07-02-2007, 10:04 AM   #8
msmoke
Member # 50137
Send a message via AIM to msmoke
Mine started doing the exact same thing this weekend. When i pulled it apart it was full of metal.
Seems my rear output bearing grenaded, and the rest of the bearings sucked metal and now spin like shit. I would also gather to believe my front output might be bent.. mine would stay in long enough for me to go about 5 feet.. talk about pissed off.
I feel your pain man. Hope yours isnt as bad as mine was. Those front shafts are known to break and bent, and they are easy to change.
msmoke is offline   Reply With Quote
Old 07-02-2007, 12:10 PM   #9
1madzuk
Member # 72294
Split H pattern
Been running the GRS II for 8 years. No problem with the "H" pattern. It can be a pain in the a$$ some times to shift. My friend was having the same issue you have. Tore down the case the nipple on the front out put shaft broken.
86 S/T 6:1 T/c, 5:13 diffs,yota P/S Spooled & locked
86T/Top GRSII,5:13 Diffs,yota P/S, Spooled & locked
87S/T EXCO,4:1,5:13,Welded,Locked,yoda P/S BLAH,BLAH,BLAH,ETC,ETC.
MAD ZUKS-Modified & Aggressively Driven
SUZUKI SAMURAIS
1madzuk is offline   Reply With Quote
Old 07-02-2007, 02:08 PM   #10
ftoy507
Member # 92235
Thanks for all the input. The consensus seems to be the front shaft is bad. I will dig in this week and post the answer.
Forum Jump
