Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > Shop and Tools
Old 08-14-2007, 02:39 PM   #1
Killerpee
Member # 14712
1/2-18 Left Hand Tap Source
I'm looking for a LH 1/2-18 Tap to use a few times..any ideas on a good source?? My local tool dealer can get me one for 30$..I'm thinking I can find it cheaper than that. Thanks
Needed:
Volvo chromo portal gears
Killerpee is offline   Reply With Quote
Old 08-14-2007, 03:46 PM   #2
SPEEDCRAVIN
Member # 30432
shane there is an aircraft tool supply / machine shop supply house that has a lot and I meen a lot of used dies, drill bits, mill and lathe parts and that kind of thing...
From 75 take beltline to the east, go past the Richardson police department on the left (you been there???) continue east for another 500 to 600 yard cause you will be in a older residential area. On your left in the first little strip mall it is on the very end... They will have what you want. It may be used but they sharpen everything they sell and it is good stuff... I think you would be able to pick one up for 10 or 15 bucks... SOrry I dont remember the name. You could call my old shopforeman (Mark) at Huffines and he could tell you thier name and give them a call to make sure they have it but the visit in that place is worth the drive... I never get out of there under 50 bucks...
Yourwelcome, JOSH
[B][SIZE="5"][COLOR="Blue"]WWW.ANVILRECOVERY.COM[/COLOR][/SIZE][/B]
GOT TULIP? yep and he's GOT HIPPIE!!!
[SIZE="3"]CHECK OUT MY SHOP BUILD WITH APARTMENT[/SIZE] [url]http://pirate4x4.com/forum/showthread.php?t=589523[/url]
SPEEDCRAVIN is offline   Reply With Quote
Old 08-14-2007, 04:58 PM   #3
Jeepermat
Member # 67907
When I bought my 3/4 LH tap I went to a local tooling place. The guy was into Jeeps, so he gave it to me at cost. $24
67' Jeepster
Jeepermat is offline   Reply With Quote
Old 08-14-2007, 05:26 PM   #4
speedo
speedo's Avatar
Member # 23262
Since UNC for 1/2" is 13 and UNF for 1/2" is 20 what are you using that will require a LH 1/2" x 18?
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
--Herbert Spencer, English Philosopher (1820-1903)
speedo is offline   Reply With Quote
Old 08-15-2007, 08:35 AM   #5
olchev4x4
Member # 95408
Yea..check you pitch. Thats a odd size.
1/2-13
1/2-20
1/2-28
But no 1/2-18 that i see
Randy
1972 Blazer
olchev4x4 is offline   Reply With Quote
Old 08-15-2007, 08:53 AM   #6
PTSchram
Member # 12499
Location: In the office writing letters to Land Rover's attorney, trying to stay in business,
Fellas! Bastard thread pitches abound. A very popular pitch for 1/2" is 12 TPI for machine tool builders. Think about the lead of a 12 pitch screw!
Wrenchin' to riches!
PTSchram is offline   Reply With Quote
Old 08-15-2007, 10:29 AM   #7
Killerpee
Member # 14712
1/2-13
1/2-20
1/2-28
Good call guys. Its 1/2 -20 LH..its for a 1/2 heim.
Needed:
Old 08-15-2007, 10:39 AM   #8
beartj
beartj's Avatar
Member # 30026
Send a message via AIM to beartj
http://www.speedwaymotors.com/p/3106...tml?itemNo=tap
I used that brand of tap to make a small run of tie-rods for some jeeps in our club. Worked fine for limited use but I can definitely tell the difference b/w those and the taps we have at the shop that were designed for 500k cycles.
PORCer Fuggy
The Coyote
beartj is offline   Reply With Quote
Old 08-15-2007, 02:30 PM   #9
ronnie bennett
Member # 47944
msc will have it ship it overnight
ronnie bennett is offline   Reply With Quote
Old 08-19-2007, 05:19 PM   #10
James_Fendley
James_Fendley's Avatar
Member # 15281
X2 Use them all the time. At work and at my shop at home.
"The secret to a happy ending is knowing when to roll the credits, better roll them now before something else goes wrong" Patterson Hood DBT
James_Fendley is offline   Reply With Quote
Old 08-19-2007, 05:33 PM   #11
JeepinDoug
JeepinDoug's Avatar
Member # 13028
J&L industrial online, the "value" taps rock.
I may lack much in way of integrety but I make up for it with pure denial.
[URL=http://www.pirate4x4.com/forum/showthread.php?t=377480][B][COLOR="Red"]Malvado Grande #1[/COLOR][/B][/URL]
JeepinDoug is offline   Reply With Quote
Forum Jump
