Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Chevy
Old 08-28-2007, 03:03 PM   #1
ngrimm
Member # 48718
4L60E only takes off in 2nd or 3rd
94 Chevrolet 1/2 4X4. I determined thru searching this site that the shifting is electronically controlled but we suddenly have a problem with the truck not shifting to 1st gear when it slows down or stops. As a result if you put it in drive it starts out in 3rd and if you move the selector to 1st or 2nd it will start out in 2nd. What I don't know is if the electronics also control which gear you start out in . Thankyou for your help. Norm
92 Tracker auto 4x4 Soft top
ngrimm is offline   Reply With Quote
Old 08-28-2007, 07:49 PM   #2
suckcreekoffroad
Member # 98730
Sounds like the shift silenoid the tranny isnt working .You can oull the codes and it will tell you withc one isn't working
suckcreekoffroad is offline   Reply With Quote
Old 08-28-2007, 08:09 PM   #3
KWTMECH
Member # 13786
Disconnect the battery for about 5 minutes then try it again
KWTMECH is offline   Reply With Quote
Old 08-28-2007, 08:15 PM   #4
sha_ba_do_bang
Member # 69347
You need to hook it up to a REAL scanner(not autozone or walmart, a $7000 snapon or otc) Then see if the computer is commanding 1st or second gear, then you can determine if the problem is internal or external.
I have actually seen a bad MAF sensor causing those symptoms(i'm not saying this is your problem, i'm just showing you that tons of things could effect the shifting)
Brendan
sha_ba_do_bang is offline   Reply With Quote
Forum Jump
