Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Land Cruiser
Old 07-19-2002, 01:34 PM   #1
fj40guy
fj40guy's Avatar
Member # 9576
Pulling Cedar tree's with the FJ40....
Don't hassle me too much on this one... but am trying to figure the best way to pull out some #$%^ Cedar's on the property. Contractor wants $$$ to clear the area for the shop of Cedar's (Juniper bushes to you Northwest Folks... in Oregon I had a 60' Cedars in my backyard. Here it is a damn bush that sucks the water out of the ground killing off the good trees).
Thought was to wrap a CHAIN around the friggin bush, and just PULL it... except I am paranoid about anyting with "pull and chain"
in the same thought!
Suggestions appreciated (slooooooooowwww day).
Thanks,
Tom
Too many projects, never enough time nor money. :flipoff2:
fj40guy is offline   Reply With Quote
Old 07-19-2002, 01:49 PM   #2
TLCObsession
TLCObsession's Avatar
Member # 3245
Kubota B21 w/Backhoe!
I did about half of my pulling with the tractor. The other half, I realized that I was going to pull the frame of my Cruiser apart unless I changed my technique. I was using a 3 ft tree as an anchor with a strap between it and my 40. I was using a tree saver around the stumps and bushes I was pulling.
Then I figured it out: most root systems can take tremendous side loads, but the backhoe worked because I could pull them UP. So I got a railroad tie, and on each pull, I would take a shovel of dirt out othe ground, and stand the tie up at greater than a 45 degree angle with the cable going over the top. When I winched, the the tie would rise (go to 90) and at the same time it would pull those stumps right out.
I used the same technique to get a buddy out of a mud bog up here - it helped break the suction.
HTH,
Jim
Never subscribe to a conspiracy theory when the stupidity theory will suffice.
TLCObsession is online now   Reply With Quote
Old 07-19-2002, 01:54 PM   #3
fj40tom
Member # 4818
Tom,
Just wrap the up and pull 'em out. Just don't pull them out in reverse if the Goose is locked in the front. Birfields go
Cheers,
tp
fj40tom is offline   Reply With Quote
Old 07-19-2002, 02:56 PM   #4
sixty
Member # 912
A blasting cap & a few pounds of amonium nitrate fertilzer soaked in diesel & you'll have no more shrubs to worry about
or you could just try w/ your cruiser & hook your chain/cable as high up the trunk as you can. just don't shock load it too much & you'll be fine. if that doest work, go rent a small tracked tractor or backoe. still should be much cheaper than a contractor.
sixty is online now   Reply With Quote
Old 07-19-2002, 03:39 PM   #5
Cruiser Ken
Member # 1797
Send a message via ICQ to Cruiser Ken
I've pulled shrubs and trees with 40, 60, and 80 series cruisers. For the shrubs I just get under the bulk of the branches, right at ground level with a short tow strap (a freebie from cool cruisers) wrapped around the trunk a few times then hook on to a longer strap and start pulling. A few tugs usually loosens them and then a slow pull and they are out. I took out an arctic willow that was about 10" in diameter. For the trees I usually fall them and then dig the roots a bit. I like to run the strap under one of the roots and around the trunk, same technique a few tugs and a slow pull. The trees stumps I pulled have been about 6 to 10" diameter evergreens.
Cruiser Ken is offline   Reply With Quote
Old 07-19-2002, 03:47 PM   #6
GloNDark
Pirate4x4 Addict!
GloNDark's Avatar
Member # 2482
Get a tow strap, wrap it around the stump of the bush in a noose like fashion (So it will tighten and tighten the more you pull) throw the other end on the rear clevis of the cruiser and go to town.
I pulled out 6 on property, a few sage brushes, a couple trees....and lot's of big bushes. All in one day. Piece of cake. Just make sure the ground is nice and wet around the base and you shouldn't have a problem. I am sure you ground ain't even as hard as the Nevada soil.
Oh yeah, make sure and take pics.
GET IT Dave!!
save me a spot bro......i'll miss you...
GloNDark is offline   Reply With Quote
Old 07-19-2002, 05:30 PM   #7
Jason M
Member # 5286
Send a message via Yahoo to Jason M
Do not pull from the center of the rear x member.
It will bend..
Mine is linely bent out from a tree stump that I used to have in the front yard.
Cruiser 0/ Stump 1
Crewcab F350 1/ Stump 0
Get a bigger hammer
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote
Old 07-19-2002, 05:57 PM   #8
Sundance
Member # 152
Send a message via Yahoo to Sundance
It is possible.......
Hey! is that our wheel that just past us??!!
Sundance is offline   Reply With Quote
Old 07-19-2002, 10:38 PM   #9
fj40charles
Member # 1926
Tom,
Use a Cummins powered 4x4 or 6x6 to pull the tree out.
Charles
'69 FJ40 with very few stock parts.
2000 Cummins with some goodies to make it smoke.....
Trail Gear's Bad Ethics=Bad Business.
fj40charles is offline   Reply With Quote
Old 07-19-2002, 11:00 PM   #10
Bulldog
Member # 8106
Sounds like you have your work cut out for you. I have allways cut a few roots out first and then slowly put tension on the base. But pulling upwards does work the best. Good luck.
Bulldog is offline   Reply With Quote
Forum Jump
