#1 |
Member # 16162
I have been searching through the Pirate4x4 arcives and have yet to find pics of FJ60 axles under an FJ40 SOA. Please post your pics on this thread. Thank you
#2 |
there is a pic of my FJ60 axle soa'd on the rear of my 40 in this thread. Works real well
![]() http://www.pirate4x4.com/forum/showt...threadid=31416 -Rick
A slightly modified 69 FJ40.. |
| Sponsored Links |
#3 |
Member # 6588
are you after specific pics of anything, or just some axles that are 85mm wider?
ive posted specific pics of the front inner u-bolt on the pumpkin side, the rest is CAKE, its as easy as doing a normal SOA, except for brake modifications, and stuff, depending on your year, and hubs and one and on
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR] [COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR] |
#4 | |
Member # 1858
Kurt Williams Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt ExpeditionUtah.com U4WDA - Member TLCA #10662 Wasatch Cruisers #028 Mountain Yoats Red Rock 4 Wheelers #789 Mojave Underground kurt@cruiseroutfitters.com |
#5 |
Member # 4818
Here are a couple of mine shot while I was working on it. When I swapped the axles, I also stretched the wheelbase out to 104".
Cheers, tp
www.tompenningtonphoto.com |
#6 |
Member # 4818
Here is the second one.
Cheers, tp
#7 |
Member # 16162
Thanks for this pics. Keep em coming
If you have pics of your spring hangers, that would be helpful.
#8 | |
Member # 4818
Re: Thanks for this pics. Keep em coming
1 of 4 Cheers, tp
#9 |
Member # 4818
2 of 4
Cheers, tp
#10 |
Member # 4818
3 of 4
Cheers, tp
#11 |
Member # 4818
4 of 4
Cheers, tp
#12 |
Member # 16162
Widening the spring hangers??
I see that you didn't widen the spring hangers. Was it much of a problem with the mount on the pumpkin?
#13 |
Member # 4818
Pics of FJ60 axles under a FJ 40 SOA
I didn't want to outboard the springs so I built the spring perch into the pumpkin.
Are there other ways to do this swap??? ABSOLUTLY!!!!! Has this worked for me??? HELL YEA!!!!!! Pics: 1 of 5 Cheers, tp
#14 |
Member # 4818
2 of 5
Cheers, tp
#15 |
Member # 4818
3 of 5
Cheers, tp
#16 |
Member # 4818
4 of 5
Cheers, tp
#17 |
Member # 4818
5 of 5
Cheer, tp
#18 |
Member # 16162
BJ THANKS FOR THE PICS
Looks like a great set-up. What type of steering are you running?
#19 |
Member # 4818
Right now I am running a FJ60 box, which is alot like the scout box, and a saginaw PS pump on my 2F. As soon as I have time I will be adding a ram assist on to help push the 38.5's in the rocks.
Cheers, tp
#20 |
Member # 1926
Looking good Shaggy..
Charles
'69 FJ40 with very few stock parts. 2000 Cummins with some goodies to make it smoke..... Trail Gear's Bad Ethics=Bad Business. |
#21 | |
Member # 6588
![]() did you catch how to drill the box, i can email you the pics if you want!! you probly already know though!!
#22 |
Member # 6588
one pics of mine
#23 |
Member # 6588
another pic
dont knock it you h0m0s!!
#24 |
Member # 6588
this was stripped down after over a year of running (actually probly just on a year at the time) it ran 35s, 36s and 38s, each for about 4 months
its now on 42s, and this is holding up a lot better than the axles,
#25 |
Member # 13514
TP, I noticed you extended the front frame a tad, what size material did you ise for that.
Thanks Gerg |
| Thread Tools | |
| Display Modes | |
